Ana içeriğe geç
Xiaomi Mi 8 AMOLED & Digitizer Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Rear Glass: adım 1, 1 resimden 1.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 2, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 2, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 2, 3 resimden 3.
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If the glass wont budge, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 3, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 4, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 4, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 4, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
    • Be aware of the fingerprint flex cable and only insert the tip of the opening pick. If insert to deep, you can cut the cable by accident.
    • As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 5, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 5, 2 resimden 2.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 6, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The fingerprint flex cable is still connected to the motherboard.
  7. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 7, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 7, 2 resimden 2.
    • Carefully lift the rear glass and fold it to the left side to access the fingerprint flex connector.
  8. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 8, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 8, 2 resimden 2.
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • Before installing new adhesive for reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond. A stack of heavy books on top of the phone works well.
  9. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Motherboard Cover with NFC: adım 9, 1 resimden 1.
    • Remove the ten screws that secure the motherboard cover.
    • Eight Phillips #00 screws (3.4 mm length)
    • Two Phillips #00 screws (3.5 mm length)
  10. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 10, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 10, 2 resimden 2.
    • Slide an opening pick under the right side of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  11. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 11, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 11, 2 resimden 2.
    • Carefully remove the motherboard cover including the NFC antenna.
  12. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Battery Disconnect: adım 12, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Battery Disconnect: adım 12, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery flex cable located at the bottom of the motherboard.
  13. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Battery: adım 13, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Battery: adım 13, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement, Battery: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
  14. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 14, 1 resimden 1.
    • For the following steps:
    • The adhesive tab underneath the battery can rip very easily. Make sure you pull out the tab in a slow and steady motion and at a flat angle. To prevent the adhesive tab from ripping, it's helpful to twist it around the tweezers.
  15. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 15, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 15, 2 resimden 2.
    • Pull out the first adhesive tab from underneath the battery.
  16. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 16, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 16, 2 resimden 2.
    Plastic Cards
    $2.99
    • Use a pair of tweezers to pull out the second adhesive tab from underneath the battery.
    • In case one of the adhesive tabs rips and it‘s not possible to pull it out completely, you can use isopropyl alcohol or a heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick or a plastic card to pry out the battery.
  17. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 17, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 17, 2 resimden 2.
    • Use an opening pick or plastic card to pry the battery out of its recess until you can get a good grip.
  18. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 18, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 18, 2 resimden 2.
    • Remove the battery.
    • Reusing a deformed or bent battery after it has forcefully been removed, is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
  19. Xiaomi Mi 8 AMOLED & Digitizer Replacement, AMOLED & Digitizer: adım 19, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement, AMOLED & Digitizer: adım 19, 2 resimden 2.
    • Use a spudger to pry up and disconnect the display flex cable.
  20. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 20, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 20, 2 resimden 2.
    • Use a pair of tweezers to peel the display flex cable off the midframe. It is attached with mild adhesive.
  21. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 21, 1 resimden 1.
    • Apply a heated iOpener to the display for two minutes to loosen the adhesive beneath.
    • The adhesive that holds down the screen is fairly strong. You might need to reheat and reapply the iOpener several times to get the adhesive warm enough.
  22. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 22, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 22, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 22, 3 resimden 3.
    • Apply a suction handle near the bottom edge of the phone.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Use the suction handle to pull up the screen and insert just the tip of an opening pick under the bottom edge of the screen.
    • In case you can't manage to lift the screen to insert an opening pick you can try to insert a thinner cutting tool such as a razor blade or a playing card. Insert an opening tool afterwards.
    • Protect your eyes from loose glass shards.
    • Slide the tip of the opening pick to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  23. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 23, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 23, 2 resimden 2.
    • Insert the tip of a second opening pick and slide it to the bottom left corner of the Xiaomi Mi 8 to cut the adhesive. Leave it there to prevent the adhesive from resealing.
  24. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 24, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 24, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 24, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner of the phone.
    • To cut the adhesive at the long edges of the Xiaomi Mi 8 only use the tip of an opening pick (about 2 mm). Don't try to insert the opening pick deeper to avoid separating the AMOLED from the display glass.
    • Slide the tip of the opening pick to the top left corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
  25. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 25, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 25, 2 resimden 2.
    • Apply more heat if the adhesive becomes hard to cut.
    • Insert the tip of a fourth opening pick at the upper left corner of the phone and slide it along the top edge to cut the adhesive. Leave it in the top right corner.
  26. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 26, 2 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 26, 2 resimden 2.
    • Insert the tip of a fifth opening pick at the top right corner of the phone and slide it along the right edge to cut the adhesive.
    • Try not to remove the display all the way yet. The display flex cable is still threaded through the midframe.
  27. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 27, 3 resimden 1. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 27, 3 resimden 2. Xiaomi Mi 8 AMOLED & Digitizer Replacement: adım 27, 3 resimden 3.
    • Slowly separate the screen from the frame and cut any remaining adhesive. Make sure the flex cable is no longer stuck to the frame and carefully thread it through its gap.
    • Remove the screen.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
20 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
230.932 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 58
Son 30 gün: 539
Her zaman: 25,588
