Ana içeriğe geç
Xiaomi Mi A2 Battery Replacement
Neye ihtiyacın var
  1. Xiaomi Mi A2 Battery Replacement, Screen: adım 1, 2 resimden 1. Xiaomi Mi A2 Battery Replacement, Screen: adım 1, 2 resimden 2.
    • Turn off your phone before proceeding.
    • Remove SIM card tray from phone.
    • Touch something metallic to ensure you are electrostatic safe.
  2. Xiaomi Mi A2 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
  3. Xiaomi Mi A2 Battery Replacement: adım 3, 3 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 3, 3 resimden 2. Xiaomi Mi A2 Battery Replacement: adım 3, 3 resimden 3.
    • Grab a suction cup tool and place it near the bottom of the phone.
    • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
    • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
    • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
    • Flip the phone screen towards the bottom of the device and lay the screen facing down.
    • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
  4. Xiaomi Mi A2 Battery Replacement: adım 4, 2 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 4, 2 resimden 2.
    • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
    • To access the ribbon cable connectors we must remove the metal bracket.
    • Remove the three 2.4mm Philips #0 screws that hold the panel down.
  5. Xiaomi Mi A2 Battery Replacement: adım 5, 3 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 5, 3 resimden 2. Xiaomi Mi A2 Battery Replacement: adım 5, 3 resimden 3.
    • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
    • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
    • After you remove the ribbon cable the panel should be free to remove and replace.
  6. Xiaomi Mi A2 Battery Replacement, USB Port: adım 6, 2 resimden 1. Xiaomi Mi A2 Battery Replacement, USB Port: adım 6, 2 resimden 2.
    • Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
  7. Xiaomi Mi A2 Battery Replacement: adım 7, 2 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 7, 2 resimden 2.
    • Remove the loud speaker. There are three 2.4mm Phillips #0 screws you need to remove, and one (upper right) is underneath the Xiaomi water sticker.
  8. Xiaomi Mi A2 Battery Replacement: adım 8, 2 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 8, 2 resimden 2.
    • Unplug the antenna wire with a spudger tool.
    • Remove another 2.4mm Phillips #0 screw near vibration motor.
  9. Xiaomi Mi A2 Battery Replacement: adım 9, 2 resimden 1. Xiaomi Mi A2 Battery Replacement: adım 9, 2 resimden 2.
    • The ribbon cable connector is located underneath the sub-board. To access the connector flip the board over towards the battery.
    • Use a spudger tool to remove the cable from the connector.
    • The USB Connector board can now be removed from the device and replaced.
  10. Xiaomi Mi A2 Battery Replacement, Battery: adım 10, 3 resimden 1. Xiaomi Mi A2 Battery Replacement, Battery: adım 10, 3 resimden 2. Xiaomi Mi A2 Battery Replacement, Battery: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • On the bottom of the battery are two pull tabs. They are glued on to the battery similarly like a sticker.
    • To remove the battery pull these pull tabs downwards. WARNING: proceed with extreme caution, avoid bending or puncturing the battery.
    • You can use tweezers to lift the pull tabs from the battery. Pull downwards and the adhesive will slowly be removed from the battery.
  11. Xiaomi Mi A2 Battery Replacement: adım 11, 1 resimden 1.
    • Gently remove battery from its housing.
    • Component can now be replaced.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Julian Sanchez
442 İtibar
1 Kılavuz yazıldı
Ekip
3 Yorum
I tried to remove the battery and tried to remove those strips carefully but the both broke so is there another way i could remove the battery
Meneer Banaan - Yanıt
The link for the replacement battery is wrong, it leads to a battery for the xiaomi mi a2 lite which doesn’t fit into the mi a2 because the connector is at a different position
Hugo Dünger - Yanıt
I just replaced the battery and just a heads up if anyone is struggling to remove the screen from the body - there was adhesive, so warm it up a little if it doesn’t lift easily. Reminded me a bit of iPhone 6s screen removal as the screen was near the same structure, cable was in different place.
Mientiia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 65
Son 30 gün: 286
Her zaman: 17,569
