Ana içeriğe geç
Xiaomi Poco M3 Screen Replacement
Neye ihtiyacın var
    1. Xiaomi Poco M3 Screen Replacement, SIM Card tray removal: adım 1, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, SIM Card tray removal: adım 1, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, SIM Card tray removal: adım 1, 3 resimden 3.
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the top left corner of the Poco M3.
      • Press firmly to eject the SIM card tray.
      • Remove the SIM card tray from the phone by pulling it out of the phone assembly.
      • If the tray holds a SIM card it will fall out easily.
      • When reinserting the SIM card, make sure it's in the correct orientation inside the SIM card tray.
      • A thin rubber gasket around the SIM card tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM card tray to protect your Poco M3's internal components.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Poco M3 Screen Replacement, Insert a spudger: adım 2, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Insert a spudger: adım 2, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Insert a spudger: adım 2, 3 resimden 3.
      • Insert a spudger into the charging port at a steep angle.
      • Do not insert the spudger in a flat angle like you would do with a charging cable to avoid damaging the charging port.
      • Use the spudger to create a gap between the phone assembly and the back cover by prying the back cover away from the bottom edge of the screen.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 3, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 3, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 3, 3 resimden 3.
      • Insert an opening pick into the gap between the phone assembly and the back cover.
      • Remove the spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Poco M3 Screen Replacement, Release the plastic clips: adım 4, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Release the plastic clips: adım 4, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Release the plastic clips: adım 4, 3 resimden 3.
      • Slide the opening pick to the bottom left corner of the phone to release the plastic clips holding the back cover in place.
      • Slide the opening pick around the bottom left corner.
      FixBot'a Sor
      Yorum Ekle
    4. Xiaomi Poco M3 Screen Replacement: adım 5, 3 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 5, 3 resimden 2. Xiaomi Poco M3 Screen Replacement: adım 5, 3 resimden 3.
      • Slide the opening pick along the left edge of the Poco M3 to release the plastic clips.
      FixBot'a Sor
      Yorum Ekle
    5. Xiaomi Poco M3 Screen Replacement: adım 6, 3 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 6, 3 resimden 2. Xiaomi Poco M3 Screen Replacement: adım 6, 3 resimden 3.
      • Slide the opening pick around the top left corner to release the plastic clips.
      • Slide the opening pick along the top edge of the phone to release the plastic clips holding the back cover in place.
      FixBot'a Sor
      Yorum Ekle
    6. Xiaomi Poco M3 Screen Replacement: adım 7, 2 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 7, 2 resimden 2.
      • Slide the opening pick around the top right corner to release the plastic clips.
      • Leave the opening pick inserted above the volume buttons.
      • Avoid using your opening pick in the area where the physical buttons are located. There's a flex cable running to the motherboard which can be easily torn.
      FixBot'a Sor
      Yorum Ekle
    7. Xiaomi Poco M3 Screen Replacement: adım 8, 3 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 8, 3 resimden 2. Xiaomi Poco M3 Screen Replacement: adım 8, 3 resimden 3.
      • Insert another opening pick into the gap at the bottom edge of your phone.
      • Slide the opening pick around the bottom right corner to release the plastic clips securing the back cover.
      • Slide the opening pick along the right edge of the phone to release the remaining plastic clips. Stop just below the fingerprint reader.
      FixBot'a Sor
      Yorum Ekle
    8. Xiaomi Poco M3 Screen Replacement: adım 9, 2 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 9, 2 resimden 2.
      • Remove the opening picks and flip the phone over.
      • Open up the phone by swinging the back cover up from the right side, like the front cover of a book.
      • Avoid tensioning the fingerprint flex cable during this procedure.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Poco M3 Screen Replacement, Unfasten the screws: adım 10, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the ten 3.9 mm-long screws.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Poco M3 Screen Replacement, Pry up the motherboard cover: adım 11, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Pry up the motherboard cover: adım 11, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Pry up the motherboard cover: adım 11, 3 resimden 3.
      • Slide an opening pick under the bottom right corner of the motherboard cover.
      • Slide the opening pick along the right edge of the motherboard cover to release the plastic clips holding it in place.
      • At the top right corner, twist the opening pick countercockwise to pry up the motherboard cover.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Poco M3 Screen Replacement, Remove the motherboard cover: adım 12, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Remove the motherboard cover: adım 12, 2 resimden 2.
      • Remove the motherboard cover.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Poco M3 Screen Replacement, Disconnect the fingerprint sensor cable: adım 13, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Disconnect the fingerprint sensor cable: adım 13, 2 resimden 2.
      • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor cable at the bottom left corner of the motherboard.
      • Remove the back cover assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Poco M3 Screen Replacement, Disconnect the battery cable: adım 14, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Disconnect the battery cable: adım 14, 2 resimden 2.
      • Use the flat end of a spudger to pry up and disconnect the battery cable at the bottom right corner of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Poco M3 Screen Replacement, Peel the "A" pull tab off the battery: adım 15, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Peel the "A" pull tab off the battery: adım 15, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Peel the "A" pull tab off the battery: adım 15, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the top edge of the orange adhesive strip labeled with an A off the battery.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the bottom edge of the orange adhesive strip labeled with an A off the battery.
      • Fold down the adhesive strip labeled with an A.
      FixBot'a Sor
      Yorum Ekle
    4. Xiaomi Poco M3 Screen Replacement, Peel the "B" pull tab off the battery: adım 16, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Peel the "B" pull tab off the battery: adım 16, 2 resimden 2.
      • Use a pair of blunt nose tweezers or a clean fingernail the orange adhesive strip labeled with a B off the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Xiaomi Poco M3 Screen Replacement, Lift the battery out of its recess: adım 17, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Lift the battery out of its recess: adım 17, 2 resimden 2.
      • Grab both corners of the orange adhesive strip labeled with an A.
      • Pull upwards to lift the battery out of its recess and swing it to an upright position.
      • Although these adhesive tabs are supposed to make the battery removal easier, they may require some force. If you're having trouble removing the battery, you can apply a heated iOpener to the center of the display to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    6. Xiaomi Poco M3 Screen Replacement, Remove the battery: adım 18, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Remove the battery: adım 18, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Remove the battery: adım 18, 3 resimden 3.
      • Peel the battery off the remaining adhesive.
      • Remove the battery.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      FixBot'a Sor
      Yorum Ekle
    7. Xiaomi Poco M3 Screen Replacement, Remove the adhesive sticker: adım 19, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Remove the adhesive sticker: adım 19, 2 resimden 2.
      • Peel the battery's adhesive sticker off the midframe.
      • This step is mandatory if you are replacing the display. It is highly recommended to use a fresh adhesive sticker when installing a new battery.
      FixBot'a Sor
      Yorum Ekle
    1. Xiaomi Poco M3 Screen Replacement, Disconnect the display cable: adım 20, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Disconnect the display cable: adım 20, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the main display flex cable.
      FixBot'a Sor
      Yorum Ekle
    2. Xiaomi Poco M3 Screen Replacement, Loosen the display cable: adım 21, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Loosen the display cable: adım 21, 2 resimden 2.
      • Use a pair of blunt nose tweezers to peel the main display flex cable off the midframe.
      FixBot'a Sor
      Yorum Ekle
    3. Xiaomi Poco M3 Screen Replacement, Unfasten the screws: adım 22, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the seven 3.9 mm-long screws.
      FixBot'a Sor
      Yorum Ekle
    4. Xiaomi Poco M3 Screen Replacement, Remove the loudspeaker assembly: adım 23, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Remove the loudspeaker assembly: adım 23, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Remove the loudspeaker assembly: adım 23, 3 resimden 3.
      • Insert an opening pick underneath the bottom right corner of the loudspeaker assembly.
      • Use the opening to pry the loudspeaker assembly out of its recess.
      • Remove the loudspeaker assembly.
      FixBot'a Sor
      Yorum Ekle
    5. Xiaomi Poco M3 Screen Replacement, Disconnect the digitizer cable: adım 24, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Disconnect the digitizer cable: adım 24, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the digitizer flex cable.
      FixBot'a Sor
      Yorum Ekle
    6. Xiaomi Poco M3 Screen Replacement, Loosen the display adhesive: adım 25, 1 resimden 1.
      • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      FixBot'a Sor
      Yorum Ekle
    7. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 26, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 26, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Insert an opening pick: adım 26, 3 resimden 3.
      • Once the screen is warm to touch, apply a suction cup to the bottom edge of the phone.
      • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert the tip of an opening pick in the gap between the midframe and the screen.
      • Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    8. Xiaomi Poco M3 Screen Replacement, Slice the display adhesive: adım 27, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Slice the display adhesive: adım 27, 2 resimden 2.
      • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
      • Leave the opening picks in to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    9. Xiaomi Poco M3 Screen Replacement: adım 28, 3 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 28, 3 resimden 2. Xiaomi Poco M3 Screen Replacement: adım 28, 3 resimden 3.
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick under the bottom left corner of the phone.
      • Slide the opening pick up to the top left corner to cut the adhesive. Leave it in to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    10. Xiaomi Poco M3 Screen Replacement: adım 29, 2 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 29, 2 resimden 2.
      • Insert a fourth opening pick at the top left corner.
      • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
      • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
      FixBot'a Sor
      Yorum Ekle
    11. Xiaomi Poco M3 Screen Replacement: adım 30, 2 resimden 1. Xiaomi Poco M3 Screen Replacement: adım 30, 2 resimden 2.
      • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
      • Try not to remove the display all the way yet, the display cables are still threaded through the frame and possibly adhered on the inner side of the midframe.
      FixBot'a Sor
      Yorum Ekle
    12. Xiaomi Poco M3 Screen Replacement, Thread the digitizer flex cable through the frame: adım 31, 2 resimden 1. Xiaomi Poco M3 Screen Replacement, Thread the digitizer flex cable through the frame: adım 31, 2 resimden 2.
      • Thread the digitizer flex cable through the gap in the midframe.
      FixBot'a Sor
      Yorum Ekle
    13. Xiaomi Poco M3 Screen Replacement, Remove the display: adım 32, 3 resimden 1. Xiaomi Poco M3 Screen Replacement, Remove the display: adım 32, 3 resimden 2. Xiaomi Poco M3 Screen Replacement, Remove the display: adım 32, 3 resimden 3.
      • Thread the display flex cable through the gap in the midframe and remove the screen.
      • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
26 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
262.273 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
40.851 adet Kılavuz yazıldı
1Rehber Yorum
hat sehr gut funktioniert, danke für die Anleitung!
hoeni - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 37
Son 30 gün: 163
Her zaman: 16,271
