Giriş
Use this guide to replace a broken NFC antenna on your Xiaomi Redmi Note 9.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the back cover and the fingerprint reader.
Neye ihtiyacın var
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the screen, as close to the edge as possible.
Lift the screen and phone assembly with the suction handle to create a small gap between the assembly and the back cover.
Insert an opening pick in a steep angle into the gap you created. This might require some force.
Slide the opening pick to the bottom right corner to slice the adhesive and release the plastic clips holding the back cover in place.
Insert a second opening pick in a steep angle at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to release the plastic clips and to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Slide the bottom left opening pick along the left edge of your phone to release the plastic clips and slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Prepare an iOpener and apply it to the back cover where the fingerprint reader is located for at least two minutes to loosen the adhesive underneath.
Carefully lift the back cover upwards whilst pressing down the fingerprint reader with a finger.
Remove the back cover.
Prepare an iOpener and apply it to the back cover where the fingerprint reader was located for at least two minutes to loosen the adhesive underneath the NFC antenna and its protective foil.
Slide the tip of an opening pick underneath the right edge of the graphite foil covering the NFC antenna.
Carefully start to separate the graphite foil from the back cover by pulling it upwards and slicing the adhesive with the opening pick.
Repeat the previous procedure you used to remove the protective foil by carefully sliding the tip of an opening pick underneath the NFC antenna and separating it from the back cover.
2 farklı kişi bu kılavuzu tamamladı.
