Giriş
If your camera's back case is damaged, you might consider changing it. To remove the back panel you will need a small blue plastic opening tool.
Neye ihtiyacın var
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
10 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where can i buy the back panel replacement ?
