Ana içeriğe geç
Xiaomi Yi Back Panel Replacement
Neye ihtiyacın var
  1. Xiaomi Yi Back Panel Replacement, Battery: adım 1, 2 resimden 1. Xiaomi Yi Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Back Panel Replacement: adım 2, 3 resimden 1. Xiaomi Yi Back Panel Replacement: adım 2, 3 resimden 2. Xiaomi Yi Back Panel Replacement: adım 2, 3 resimden 3.
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Back Panel Replacement, Front Panel: adım 3, 2 resimden 1. Xiaomi Yi Back Panel Replacement, Front Panel: adım 3, 2 resimden 2.
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Back Panel Replacement: adım 4, 3 resimden 1. Xiaomi Yi Back Panel Replacement: adım 4, 3 resimden 2. Xiaomi Yi Back Panel Replacement: adım 4, 3 resimden 3.
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Back Panel Replacement, Back Panel: adım 5, 2 resimden 1. Xiaomi Yi Back Panel Replacement, Back Panel: adım 5, 2 resimden 2.
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Back Panel Replacement: adım 6, 3 resimden 1. Xiaomi Yi Back Panel Replacement: adım 6, 3 resimden 2. Xiaomi Yi Back Panel Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Back Panel Replacement: adım 7, 2 resimden 1. Xiaomi Yi Back Panel Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Karol Gonzalez
379 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G5
3 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy back panel for Xiaomi Yi?
matulek - Yanıt
Where can i buy the back panel replacement ?
Roland Meilleur - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 88
Her zaman: 3,753
