Ana içeriğe geç
Yamaha NS-AW190BL Input/Output Panel Replacement
bradley
bradley ve 5 diğer katkıda bulunanlar
En son June 9, 2019 tarihinde güncellendi
8 dakika
Orta
This guide will walk you through the process of replacing the input/output panel.
Neye ihtiyacın var
  1. Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: adım 1, 2 resimden 1. Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: adım 1, 2 resimden 2.
    • Remove all four .5 mm Phillips head screws located on the back panel of the device.
    • Pull out the input/output panel from the back of the device once all four screws are removed.
  2. Yamaha NS-AW190BL Input/Output Panel Replacement: adım 2, 3 resimden 1. Yamaha NS-AW190BL Input/Output Panel Replacement: adım 2, 3 resimden 2. Yamaha NS-AW190BL Input/Output Panel Replacement: adım 2, 3 resimden 3.
    • Gently push down on the tab holding the connectors together.
    • Repeat the process on the second connector. (Even though they appear different, they are held together using the same tabs.)
    • Remove both connectors to free the input/output panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
bradley
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 726
