bypass broken USB on GARMIN Gps
Neye ihtiyacın var
The battery must be removed for safety since the yellow wire which sends a safety signal to the charging electronics about the battery heat levels will be bypassed. We will be powering the unit directly from the Garmin Car Charger (others may not work since Garmin has special circuitry in its chargers).
# using a mini torx screwdriver, remove all the screws and seperate the front and back of the case. # if the usb conector is still on the circuit board, carefully twist it off and discard # cut the car charger cable a few cm from the usb connector and strip the two wires back 0.5 cm.the middle wire is positive, the outer mesh sheath, negative.
== Tips == * free updated maps are available at openstreetmap.http://garmin.openstreetmap.nl/ == Warnings == * make sure you dont cut battery wires at the same time, the wire cutters will short out the battery and it may explode or catch fire. wires must be cut indicidually
2 farklı kişi bu kılavuzu tamamladı.
