Ana içeriğe geç
Yardım
Apple AirPort Express Base Station Power Supply Kit
Adım 19 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Pre-tin the exposed wires to add rigidity to them and keep them from fraying when pushing through the PCB through-holes.
Pre-tinning is when you cover or fill wires with solder to improve a solder connection. Be sure that your pre-tin does not have any globs on it, or it will not fit through the PCB through-holes. If necessary, trim the wire so that it will fit through the holes.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
