Ana içeriğe geç
iHome iH3L Scroll Wheel Circuit Board  Replacement
Brittany Holloway
Brittany Holloway ve 2 diğer katkıda bulunanlar
En son December 31, 2018 tarihinde güncellendi
25 - 35 dakika
Orta
The scroll wheels are on the top left and right side of the iHome. The right side scroll wheel control the "set +/-" and the left side scroll wheel controls the "volume". If they do not respond, the circuit board could be corroded or broken.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: adım 1, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: adım 1, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: adım 1, 3 resimden 3.
    • Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
    • Two Countersunk 9.7 mm Phillips #2 screws in the middle.
    • Two 15.9 mm Phillips #2 screws.
    • Six 13.9 mm Phillips #2 screws.
    • Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
    • Two 11.8 mm Phillips #2 screws.
  2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 2, 2 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 2, 2 resimden 2.
    • Remove all screws indicated in the previous step.
  3. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 3, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 3, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 3, 3 resimden 3.
    • Slowly tilt the bottom cover of the iHome up.
    • Do not yank the cover off, there is a wire connecting the cover to the circuit board.
    • Disconnect the wire just by pulling on the connector gently.
  4. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 4, 2 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 4, 2 resimden 2.
    • Disconnect the next connector pin after slowly opening the lid more.
  5. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 5, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 5, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 5, 3 resimden 3.
    • Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
    • The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
  6. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 6, 2 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 6, 2 resimden 2.
    • Remove the seven screws that are holding the motherboard in place:
    • Six 14 mm Phillips #2 screws.
    • One 14 mm Phillips #2 screw with two rubber washers on it.
  7. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 7, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 7, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 7, 3 resimden 3.
    • To remove the motherboard, gently lift up from opposite sides.
    • Be careful when lifting the motherboard. There are wires still connected to it on the backside.
  8. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 8, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 8, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 8, 3 resimden 3.
    • Carefully tilt the motherboard up from the front.
    • Disconnect the 8 connections by gently pulling on them. Starting from the front and work your way backwards.
    • All 8 connectors disconnected.
  9. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 9, 2 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 9, 2 resimden 2.
    • Unscrew the screws holding the speakers onto the body. One on each side:
    • Two 14.3 mm Phillips #2 screws.
  10. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 10, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 10, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 10, 3 resimden 3.
    • To remove the speakers from the iHome, gently lift up the back of the speaker and pull towards you. These are very secure so minor shaking may help release the speaker.
    • Repeat for the other side.
    • Be careful yanking on them, the speakers are connected together.
  11. iHome iH3L Scroll Wheel Circuit Board  Replacement, Scroll Wheel Circuit Board: adım 11, 2 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement, Scroll Wheel Circuit Board: adım 11, 2 resimden 2.
    • Remove the three 7.9 mm Phillips #2 screws holding the scroll wheel board down.
  12. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 12, 3 resimden 1. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 12, 3 resimden 2. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 12, 3 resimden 3.
    • With the screws removed, gently pull the scroll wheel circuit board up.
    • Repeat for the other scroll wheel circuit board.
    • Do not yank it off, the wire will still be connected to it.
  13. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 13, 1 resimden 1.
    • The connector to the scroll wheel has already been disconnected from the motherboard.
    • Untangling the wires might be necessary to completely remove it.
  14. iHome iH3L Scroll Wheel Circuit Board  Replacement: adım 14, 1 resimden 1.
    • You have successfully removed the scroll wheel circuit boards.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 265
