Ana içeriğe geç
iMac Intel 21.5" EMC 2805 Logic Board Replacement
Walter Galan
Walter Galan ve 3 diğer katkıda bulunanlar
En son March 15, 2024 tarihinde güncellendi
Tahmin yok
Orta
Use this guide to replace the logic board.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display Assembly: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 21.5" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 2, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 2, 2 resimden 2.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  3. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 3, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 3, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 3, 3 resimden 3.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 4, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 4, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 4, 3 resimden 3.
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 5, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 5, 2 resimden 2.
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 6, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 6, 2 resimden 2.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 7, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 7, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 7, 3 resimden 3.
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 8, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 8, 2 resimden 2.
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 9, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 9, 2 resimden 2.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 10, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 10, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 10, 3 resimden 3.
    Plastic Cards
    $2.99
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 11, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 11, 2 resimden 2.
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 12, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 12, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 12, 3 resimden 3.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 13, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 13, 2 resimden 2.
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 14, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 14, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 14, 3 resimden 3.
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 15, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 15, 2 resimden 2.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 16, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 16, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 16, 3 resimden 3.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 17, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 17, 2 resimden 2.
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 18, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 18, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 18, 3 resimden 3.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display Assembly Cables: adım 19, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display Assembly Cables: adım 19, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display Assembly Cables: adım 19, 3 resimden 3.
    • Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  20. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 20, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 20, 2 resimden 2.
    • While holding the display up with one hand, use the other hand to unplug the display power cable.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  21. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display: adım 21, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Display: adım 21, 2 resimden 2.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 22, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 22, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 22, 3 resimden 3.
    Plastic Cards
    $2.99
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  23. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 23, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 23, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 23, 3 resimden 3.
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • If you're replacing the display with a new one, you may need to transfer some components from the old display to the new display.
    • During reassembly, head over to our display adhesive guide to install the new adhesive.
  24. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Lower Support Bracket: adım 24, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Lower Support Bracket: adım 24, 2 resimden 2.
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • On at least some EMC 2544 machines, all five screws are the same size.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  25. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 25, 1 resimden 1.
    • Remove the lower support bracket from the iMac enclosure.
  26. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Right Speaker: adım 26, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Right Speaker: adım 26, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Right Speaker: adım 26, 3 resimden 3.
    • Use the tip of a spudger to push on either side of the right speaker cable connector to walk it out of its socket on the logic board.
  27. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 27, 1 resimden 1.
    • Remove the two 10.0 mm T10 screws securing the right speaker to the rear enclosure.
  28. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 28, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 28, 2 resimden 2.
    • Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side.
    • Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
    • If the channel is not easily accessible, you can pull the speaker gently away from the case to gain access to the antenna cable.
  29. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 29, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 29, 2 resimden 2.
    • Lift the right speaker straight up and remove it from the iMac.
    • It may be helpful to tip the top of the speaker away from the rear enclosure when removing it from the iMac.
  30. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Hard Drive Brackets: adım 30, 1 resimden 1.
    • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
  31. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 31, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 31, 2 resimden 2.
    • Remove the left and right hard drive brackets from the iMac.
  32. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Power Supply: adım 32, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Power Supply: adım 32, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Power Supply: adım 32, 3 resimden 3.
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board.
    • Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
  33. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 33, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 33, 2 resimden 2.
    • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  34. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 34, 1 resimden 1.
    • Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
    • In newer model iMacs these are 7.2 mm T8 Torx screws.
    • During reassembly, be careful not to trap the power button wire behind the board.
  35. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 35, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 35, 2 resimden 2.
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Tilt the power supply forward.
  36. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 36, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 36, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 36, 3 resimden 3.
    • Pull the power supply slightly up and out from the rear enclosure.
    • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  37. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 37, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 37, 2 resimden 2.
    • Slide the power supply to the right to clear the screw posts on the rear enclosure.
  38. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 38, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 38, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 38, 3 resimden 3.
    • Rock the power supply forward and remove it from its recess in the rear enclosure.
    • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  39. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 39, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 39, 2 resimden 2.
    • Flip the power supply over to access the DC power cable connection behind the logic board.
    • Squeeze the tab on the back side of the DC power cable connector and pull it straight out of its socket on the back of the logic board.
  40. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 40, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 40, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 40, 3 resimden 3.
    • You may find it helpful to set the iMac down on its back for the next couple of steps.
    • Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward.
    • While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  41. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 41, 1 resimden 1.
    • Remove the power supply from the iMac.
  42. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Fan: adım 42, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Fan: adım 42, 2 resimden 2.
    • Use the tip of a spudger to push the fan cable connector out of its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to walk it out of its socket.
  43. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 43, 1 resimden 1.
    • Remove the following screws securing the fan to the rear enclosure:
    • Two 12.5 mm T10 screws
    • One 9.9 mm T10 screw
  44. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 44, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 44, 2 resimden 2.
    • Lift and remove the fan from the iMac.
  45. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Hard Drive Assembly: adım 45, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Hard Drive Assembly: adım 45, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Hard Drive Assembly: adım 45, 3 resimden 3.
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  46. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 46, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 46, 2 resimden 2.
    • Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
  47. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 47, 1 resimden 1.
    • Remove the hard drive assembly from the iMac.
  48. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Hard Drive Tray: adım 48, 1 resimden 1.
    • Remove the single 7.2 mm T10 screw securing the hard drive tray to the rear enclosure.
  49. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 49, 1 resimden 1.
    • Remove the hard drive tray from the rear enclosure.
  50. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Logic Board Assembly: adım 50, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Logic Board Assembly: adım 50, 2 resimden 2.
    • Use the tip of a spudger to walk the left speaker cable connector out of its socket.
    • It is recommended to first press on one side of the connector, then press on the other side until freed.
  51. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 51, 1 resimden 1.
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  52. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 52, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 52, 2 resimden 2.
    • In a similar fashion as the previous step, de-route the combo SATA data/power cable up out of the retaining clip.
  53. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 53, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 53, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 53, 3 resimden 3.
    • Use a pair of tweezers to flip up the metal retaining bracket on the iSight camera cable connector.
    • Pull the iSight camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  54. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 54, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 54, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 54, 3 resimden 3.
    • If necessary, use the tip of a spudger to peel back the tabs covering the antenna connectors.
  55. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 55, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 55, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 55, 3 resimden 3.
    • Use the tip of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables.
  56. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 56, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 56, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 56, 3 resimden 3.
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
  57. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 57, 1 resimden 1.
    • Remove the following screws securing the exhaust duct to the rear enclosure:
    • Two 6.3 mm T8 screws
    • Two 4.7 mm T8 screws
  58. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 58, 1 resimden 1.
    • Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
  59. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 59, 1 resimden 1.
    • Use a pair of tweezers to peel the tape covering the exhaust duct.
  60. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 60, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 60, 2 resimden 2.
    • Tilt the top of the logic board away from the rear enclosure.
  61. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 61, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 61, 2 resimden 2.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear case's screw posts.
    • The I/O inputs at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
  62. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 62, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 62, 2 resimden 2.
    • When reinstalling the logic board, check the alignment of the exterior I/O ports. The logic board can sit crooked even when secured with all its screws.
    • Use a USB flash drive and/or ethernet cable to keep the logic board aligned while you screw it in.
  63. iMac Intel 21.5" EMC 2805 Logic Board Replacement, SATA Data and Power Cables: adım 63, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement, SATA Data and Power Cables: adım 63, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement, SATA Data and Power Cables: adım 63, 3 resimden 3.
    • The SATA data connector has a clip that must be pressed to allow removal.
    • While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
  64. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 64, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 64, 2 resimden 2.
    • Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
  65. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Heat Sink: adım 65, 1 resimden 1.
    • The following screws secure the heat sink to the logic board:
    • Remove the two T8 screws from the exhaust port end of the heat sink.
    • Loosen, but do not remove, the four captive T8 screws securing the CPU end of the heat sink.
  66. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 66, 2 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 66, 2 resimden 2.
    • Slowly lift and remove the heat sink from the logic board.
    • When reassembling your iMac, follow our thermal paste application guide to reapply the thermal paste.
  67. iMac Intel 21.5" EMC 2805 Logic Board Replacement, AirPort/Bluetooth Card: adım 67, 1 resimden 1.
    • Remove the two 3.2 mm T5 screws securing the AirPort/Bluetooth card to the logic board.
  68. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 68, 3 resimden 1. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 68, 3 resimden 2. iMac Intel 21.5" EMC 2805 Logic Board Replacement: adım 68, 3 resimden 3.
    • Slightly lift the AirPort/Bluetooth card and pull it straight out its socket.
    • Do not use excessive force to pull the end of the AirPort/Bluetooth Card away from its socket on the logic board. Doing so may cause severe damage.
    • When reinstalling the card, be sure it is properly seated before reinstalling the retaining screws.
  69. iMac Intel 21.5" EMC 2805 Logic Board Replacement, Logic Board: adım 69, 1 resimden 1.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
Sonuç
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 88
Her zaman: 19,045
