Giriş
For the updated guide, click here. This guide has been archived for historical purposes.
Removing the display requires cutting through the adhesive around the perimeter of the screen. After the adhesive is cut, it cannot be used to re-seal the display in place, so you'll need to apply a new set of adhesive strips.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
Neye ihtiyacın var
Bu adımda kullanılan alet:iMac Intel 21.5" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
Bu adımda kullanılan alet:Tweezers$4.99
If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
After all the old adhesive is removed, carefully clean off the adhesive residue with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
Start with the strip labeled 3 (or 03), which goes on the right vertical side of the rear enclosure.
Peel the short piece of backing off the back of the strip.
Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of backing on it.
With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pulling up against the spudger to ensure the strip is taut, and stick it onto the frame.
Work your way around the perimeter of the iMac, adding three more adhesive strips in the same manner.
Working counter-clockwise from strip 3, place:
Strip 2 on the top right
Strip 1 on the top left
Strip 5 on the left vertical
To avoid blocking the microphone port with adhesive, strip 4R must be modified before use. A small notch must be cut out of the lower edge of the adhesive strip to accommodate the microphones.
Measuring from the left end of strip 4R (the end with the labels) make two marks on the strip as guides for where to cut.
Make the first mark 1.125 (1⅛) inches (28.6 mm) from the left edge.
Make the next mark 1.75 (1¾) inches (44.5 mm) from the left edge.
Measuring from the bottom edge of the strip, make a third mark in between the first two 0.16 (5/32) inches (4 mm) up from the bottom edge.
Grasp the red film pull tab on the 4R adhesive strip and pull to remove the backing from the strip.
Align the strip on the bottom edge of the rear enclosure such that the right end of the strip sits next to—but does not overlap—adhesive strip 3.
Run your finger along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
Gently lay the display in place over the iMac, and align it carefully.
After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
Remove the film from the 4R strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
Reconnect the display power and data cables for the final time.
Bu adımda kullanılan alet:Microfiber Cleaning Cloths$3.99
Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
Bir başkası bu kılavuzu tamamladı.
