Ana içeriğe geç
iMac Intel 27" EMC 2546 Hard Drive Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iMac Intel 27" EMC 2546 Hard Drive Replacement, Display: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 27" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
  2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 2, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 2, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
  3. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 3, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 3, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 4, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 4, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Continue wheeling the tool up around the top left corner.
  5. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 5, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 6, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 7, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 7, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Push the tool around the top right corner of the display.
  8. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 8, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 9, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 10, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 10, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 10, 3 resimden 3.
    Plastic Cards
    $2.99
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
  11. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 11, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 11, 2 resimden 2.
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  12. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 12, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 12, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 12, 3 resimden 3.
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
  13. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 13, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 13, 2 resimden 2.
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 14, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 14, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 14, 3 resimden 3.
    • Insert a second card into the gap between the display and frame in the top left corner.
  15. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 15, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 15, 2 resimden 2.
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  16. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 16, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 16, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 16, 3 resimden 3.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 17, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 17, 2 resimden 2.
    • Insert the card back into the top left corner.
  18. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 18, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 18, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 18, 3 resimden 3.
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
  19. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 19, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 19, 2 resimden 2.
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 20, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 20, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 20, 3 resimden 3.
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
  21. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 21, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 21, 2 resimden 2.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
  22. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 22, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 22, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 22, 3 resimden 3.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  23. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 23, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 23, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 23, 3 resimden 3.
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
  24. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 24, 1 resimden 1.
    • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
  25. iMac Intel 27" EMC 2546 Hard Drive Replacement, iMac Intel Speaker Displacement for HDD Guides: adım 25, 1 resimden 1.
    • Use a T10 driver to remove the two 10 mm screws securing the left speaker.
  26. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 26, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 26, 2 resimden 2.
    • Shift the loosened left speaker to the left—enough to uncover the hard drive bracket screws.
  27. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 27, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 27, 2 resimden 2.
    • Pull straight up on the SATA combo cable to disconnect it from the drive.
  28. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 28, 1 resimden 1.
    • Use a T8 driver to remove the two 7.3 mm screws securing the left hard drive bracket to the rear case.
  29. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 29, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 29, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 29, 3 resimden 3.
    • Grab the hard drive and left hard drive bracket together.
    • Tilt the left side away from the rear case, and slide the assembly to the left.
    • Remove the hard drive and left hard drive bracket from the iMac.
  30. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 30, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 30, 2 resimden 2.
    • Remove the left hard drive bracket.
  31. iMac Intel 27" EMC 2546 Hard Drive Replacement, Hard Drive: adım 31, 1 resimden 1.
    • Remove the four 8.1 mm T8 screw posts from the hard drive, and transfer them to the replacement drive enclosure.
  32. iMac Intel 27" EMC 2546 Hard Drive Replacement, Replace the hard drive with an SSD: adım 32, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement, Replace the hard drive with an SSD: adım 32, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement, Replace the hard drive with an SSD: adım 32, 3 resimden 3.
    • Follow the remaining steps if you are replacing your hard drive with an SSD kit.
    • If your SSD enclosure looks like the first image, follow this guide instead.
    • Line up the SSD connectors with the metal enclosure's sockets.
    • Press the drive against the enclosure sockets until the SSD is firmly seated.
    • The SSD connects with the enclosure in only one direction. If the connectors don't line up, rotate the SSD and try again.
  33. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 33, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 33, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 33, 3 resimden 3.
    • Use a Phillips screwdriver to install the four silver screws (two on each side) along the edges of the SSD to secure it to the enclosure.
  34. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 34, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 34, 2 resimden 2.
    • Plug the included sensor-enabled combo cable into the enclosure's port.
    • The cable is keyed to connect in only one orientation. If you can't connect the cable, rotate it 180° and try again.
  35. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 35, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 35, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 35, 3 resimden 3.
    • Peel the white liner off the back of the small temperature sensor board in order to expose the adhesive.
    • Adhere the temperature sensor board to an exposed, metal surface of the SSD, close to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  36. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 36, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 36, 2 resimden 2.
    • Use a T8 driver to install the mounting pins from the old hard drive onto the sides of the enclosure.
  37. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 37, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 37, 2 resimden 2.
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  38. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 38, 2 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 38, 2 resimden 2.
    • Connect the iMac's combo cable to the new temperature-enabled combo cable.
  39. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 39, 3 resimden 1. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 39, 3 resimden 2. iMac Intel 27" EMC 2546 Hard Drive Replacement: adım 39, 3 resimden 3.
    • The images used in this step come from a 2017 iMac. Your cables may look slightly different, but the procedure remains the same.
    • Slide the SSD enclosure into the space previously occupied by the hard drive.
    • Route the cables so that they will not interfere with any other components.
    • Try to keep the cables free from any sharp bends, and route them such that they are not pinched.
Sonuç
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
275 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
512.215 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.612 adet Kılavuz yazıldı
56Kılavuz Yorumları
My experience in upgrading this unit to a Seagate 4TB hybrid ST4000DX001 went fine except for the fans running at a constant higher RPM. Using Macs Fan Control is solving my issue for now. As a tip, you do not need to remove the left speaker, you can loosen the two screws and angle it leaning to the left.
MFR2VCB - Yanıt
What setting do you change in Macs Fan Control? Im looking at getting a SSD fitted to my Late 2013 iMac by a certified repair centre who have said they will do it for me if I provide the SSD but they did mention that the fans would most likely speed up as there won't be a temp sensor in the SSD. Thanks.
Lewis -
I didn't have a fan problem, since the adapter comes with a temperature sensor, my problem was the adapter wasn't long enough.
Erik Johnson -
Lewis: simply running the Macs Fan Control app will do it. Otherwise the fans run at full speed because they have no temperature measurement.
Max Fenton - Yanıt
I'm wondering what drive apple uses for the 1TB SSD version? Is it an OEM type PCIE Sandisk as well or a larger 2.5" drive?
I'm very tempted to upgrade my Fusion drive.
Brent Petersen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 269
Son 7 gün: 1,333
Son 30 gün: 2,069
Her zaman: 299,355
