Ana içeriğe geç
iMac Intel 27" EMC 2639 Adhesive Strips Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart ve 5 diğer katkıda bulunanlar
En son April 1, 2024 tarihinde güncellendi
30 dakika
Orta
Removing the display on a Late 2013 iMac requires cutting through the adhesive around the perimeter of the screen. After the adhesive is cut, it cannot be used to re-seal the display in place, so you'll need to apply a new set of adhesive strips.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Determine which adhesives you have: adım 1, 1 resimden 1.
    • Before you begin, make sure you have the right adhesive strips:
    • The 2012-2019 iMac adhesive strips have a microphone cutout and are numbered 16, 21, 22, 23, 25, and 26. They can be used on 27" iMacs from 2012-2019.
    • If your strips are numbered 11-16, follow the 2012-2015 iMac adhesive guide instead.
    Is there anything better than these self-adhesive strips?
    They don’t seem as thick as the original adhesive and not as strong. As the adhesive weakens when warm, I’ve had a screen come loose within a few days of use. Luckily the user was in front of it to catch it, else we could have been looking at a very expensive repair.
    Cool_Breeze - Yanıt
    Hello, in 99% of cases this happens because the residues of the old stripes on the display side have not been completely removed.
    McFix - Yanıt
    My strips are labelled 14, 15, 16, 21, 22, 23 in a kit for the late 2013 iMac. That matches neither set mentioned here. So I have 14 and 15 instead of 25 and 26. It seems a mix of the two sets described, but since either should work for the 2013 model I should be fine?
    Bernd - Yanıt
    I agree with the first comment: they are not thick enough. I have laid them all down and temporarily reconnected the screen and tested it, and all is well. But I'm looking carefully at it all, and see that the top surface of the labels are below the chassis lip. I have definitely removed all the old adhesive, but I am concerned because of this design flaw that it won't hold. So I'm thinking of buying another set of adhesives and putting them on top to thicken it. Has anyone tried this or is this a mistake in your opinion? Gary
    Gary Schankula - Yanıt
    I removed the glass with Apple strips and next day with iFix strips, what a difference, took me 3 time longer.
    These iFix strips are not very good, if you clean the surfaces with isopropyl alcohol they stick like crazy, but:
    - They are so thin that it's very difficult to get the excellent tool with the roller between glass and body.
    if you need to remove the glass
    - The backing of these strips are so weak that you have to remove every little bit piece by piece,
    the Apple strips have so strong backing that you can with just one pull remove the old strip on both
    body and glass.
    I found it securing to hold my thumb on the glass where I worked with the roller tool to support the glass
    and avoid excessive bending.
    My recommendation, don't even think about removing the glass without the tool that comes with the strips,
    it has a very thin and flexible roller cutting wheel. I removed glass twice with one tool.
    It's not difficult, put a pillow between stand and body and work SLOWLY!
    Vane - Yanıt
  2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Stabilize the iMac: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 27" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iFixit cardboard service wedge.
    • Follow these assembly directions to put the service wedge together.
    • If you are not using an iMac service wedge, be very careful when installing and working behind the display—it can easily fall out and break if the iMac moves unexpectedly.
  3. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Remove the old adhesive: adım 3, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Remove the old adhesive: adım 3, 2 resimden 2.
    • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the adhesive strips using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the surface with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
    The black border on the back of the screen glass appears to be painted on. When removing the foam adhesive, be careful with tools as it can scratch off the paint and that will show through when all is back together. Fingernails worked best for me; peeling the tape up slowly followed by the alcohol wipe.
    Tom Pentz - Yanıt
    On mine the glue stuck mostly to the enclosure. It required a lot of elbow grease to get it off.
    Larry - Yanıt
    Used a little dab of Goo Gone with a micro fiber cloth and a lot of elbow grease on the enclosure to remove the adhesive. As far as the glass side, mine was fairly clean so I just used some 70 % alcohol and was careful. Then went back over all areas with 70 % alcohol again. Was able to clean everything thoroughly. It’s tough but worth it for good adhesion. Thanks Darren S.
    Darren Stewart - Yanıt
    My 27" iMac was damaged in shipping and I had to replace the display. When trying to replace the display, I found that the case was bent on the top, just barely visible. Makes sense as the top right corner of the display was totally smashed... Check your display fit and alignment BEFORE placing the adhesive strips. This way you can work on straightening the frame without worrying about damaging the adhesive strips.
    The case is actually soft, in that it is easily bent. Work only when relaxed and not stressed out! I used my body weight and a small piece of wood as a fulcrum to accomplish the (un)bends. If you place it on a totally flat surface you can see where it's touching and where it's high, so you know where to bent it. I had to use some pliers to get the last bit straight. I used multiple (4 - 6) layers of cardboard under the pliers to prevent scratching the aluminium. Go gently, slowly, checking for alignment / flatness many times, rather than doing too much and having to bent it back again.
    VikingShips - Yanıt
  4. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Lay out the adhesive strips: adım 4, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Lay out the adhesive strips: adım 4, 2 resimden 2.
    • Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
    • Strip 22 on the top left
    • Strip 23 on the top right
    • Strip 21 on the right vertical
    • Strip 25 on the bottom right, dark side facing up.
    • Double check to make sure this strip has the necessary cutout for the microphone.
    • Strip 26 on the bottom left, dark side facing up
    • Strip 16 on the left vertical
  5. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 3.
    • Start with strip 21, which goes on the right vertical edge of the iMac frame.
    • Before you peel off any backing, line the adhesive strip up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  6. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 6, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 6, 2 resimden 2.
    • Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
  7. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 3.
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
  8. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 3.
    • Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel longer blue piece of backing out from behind the strip.
    • If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  9. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 9, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 9, 2 resimden 2.
    • Align the lower portion of the strip with the right edge of the frame, and stick it down.
  10. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 10, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 10, 2 resimden 2.
    • Use your finger to smooth out the strip. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  11. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the top and left adhesives: adım 11, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the top and left adhesives: adım 11, 2 resimden 2.
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • Strip 16 on the vertical left
    • These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement.
    • On the iMac Intel 27" Retina 5K Display, the top-right strip's blue tabs will not line up with the top antenna in the same way as the non-5K model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
    2017 27”, lining up the top strips with the smaller outside holes, the tape holes at the other end did not line up with the larger holes in the case, near the camera.
    ebay - Yanıt
    For the late 2012 27” iMac, strip 23 didn't line up correctly with the antenna. the antenna adhesive was a cm off from where it should have been. No biggie though.
    Daniel - Yanıt
    I can confirm above comment - EMC 2546 Late 2012 27" iMac, strip 23 antenna does not align with adhesive.
    Michael - Yanıt
  12. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the bottom adhesives: adım 12, 1 resimden 1.
    • The next few steps will show you how to install the bottom right adhesive strip (strip 25), which includes a notch that must be aligned with the microphone.
    • Read through this step and the next four steps before you attempt the procedure.
    • Grasp the red pull tab on strip 25 and pull to separate about 2 inches (5 cm) of white backing from the strip.
    These steps instruct you to install the lower strips to the iMac frame first, as that is what Apple instructs their techs to do. If you have an iMac without a microphone hole, you can choose to install the lower strips onto the display first. Peel the blue tab instead of the red to expose the adhesive. Carefully place the adhesive along the bottom edge of the display. The L-bend on the adhesive should match the display contours.
    Arthur Shi - Yanıt
    My EMC No. 2546 did not have a microphone hole, so I was confused at first. A different instructional video (https://vimeo.com/139364064) recommends placing the strips on the display instead. I installed the strips on the frame, but I reckon installation on the display glass might have been a better option, at least with no microphone hole to contend with.
    Lennart Saaf - Yanıt
    Yep, no microphone hole on the late 2012 27” iMac. I followed the video but I don’t think it made anything easier.
    Maybe my mistake was putting the screen back on when the frame was lying down. I was left with a mm gap on one side due to misalignment. Stand up the mac so the screen can sit on the lip and be aligned properly.
    Daniel -
    Je pense qu’il est possible de coller les adhésifs inférieurs légèrement plus haut que sur l’image, pour dégager 2mm afin de permettre à l’écran à l’horizontale de glisser latéralement pour faciliter l’alignement lors du remontage.
    stbrille - Yanıt
  13. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 3.
    • Fold the loose white backing to a right angle and pinch the crease with your fingers.
    • This exposes 2 inches of adhesive while folding the red tab out of the way.
    I had difficulty here. The red tab wanted to pull off from the white backing.
    ebay - Yanıt
    It's not the red tab. It's the bond between the white backing and the adhesive that's causing the problem. When I tried to peel the white backing off, it takes the adhesive along with it. I had to detach it with my finger nail, already risking a weaker bond between the screen and the adhesive. I thought the problem was only around the edge of the strip (where I had to pull the red tab), but the whole strip was pulling the adhesive off the clear backing as I was aligning it with the iMac. This is the second time this has happened with these strips. And now I'm concerned, since the adhesive is now slightly compressed and there's a little air gap in the middle now...
    adrianfpommier -
  14. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 3.
    • The microphone hole is the center hole flanked by two larger holes. In the subsequent steps, be sure to align to the microphone hole and not the larger holes.
    • Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
    • If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
    • The adhesive tears easily. Be careful not to pull on the strip with too much force.
    • Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
    Can anyone confirm that the mic is the middle small hole as the photo in step 14 appears to show a larger hole? I ask as I don’t have the mic kit and will have to cut the kit to suit my late 2015 iMac 27 retina. Thanks.
    Amuseme - Yanıt
    Good catch!! Yes, the mic hole is the small center hole. The step image is showing the wrong hole. I’ll upload the correct photo shortly.
    Arthur Shi -
    i have a late 2015 iMac 27” 5K (iMac 17,1) and I do not have a microphone along the bottom. I am confused because other people do?
    R L - Yanıt
    The 2017 iMacs (both 21.5 and 27" models) were the first to have the microphone at the bottom. Previous models had it at the top center with the camera.
    Mike Rosenberg -
  15. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 3.
    • Peel away the white backing behind the strip to expose the remaining adhesive.
  16. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 16, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 16, 2 resimden 2.
    • Run your finger from left to right along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
  17. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 3.
    • Repeat the previous steps for the bottom left adhesive strip (strip 26), aligning and placing it along the bottom left edge of the iMac.
    • The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the second photo.
    This strip is adjacent to the power supply of the iMac. Take care not to touch any part of the power supply module during this step.
    Zachary Hill - Yanıt
    At this point, before proceeding, I would make sure the the power supply is fully de energized(no power cord) by holding down the power button for 30 seconds!
    Macrepair SF - Yanıt
  18. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Replace the display: adım 18, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Replace the display: adım 18, 2 resimden 2.
    • Gently set the display in place over the iMac and align it carefully.
  19. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 19, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 19, 2 resimden 2.
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
    I used 2” painter’s tape to hold the display in place, but did it a little differently. With the wedge holding the iMac at an angle, I laid the display in place and felt on the sides to make sure it was centered. Then I put small strips (4-5” long) all along the sides and top, wrapping the tape around to the back of the display to hold it in place. Then tested my repair to make sure everything worked.
    I had seen some comments about problems with the strips holding in place over time, so I didn’t actually install them. Instead, I’ve left the painter’s tape on mine. I’m a week or more in, and so far there’s no sign of failure to hold. I’m going to leave it this way until I decide whether or not to replace the blade and hard drive with an SSD. I find I don’t even notice the painter’s tape as I’m using my iMac.
    paul - Yanıt
    Paul- If you haven’t made the move to SSD yet, i suggest you replace the SATA 3.5” HDD with a 2.5” SSD, and leave the blade SSD already installed in place. You can create a new Fusion Drive with the SATA SSD & stock blade SSD. This allows you to still take advantage of the blade SSD for extra RAM.
    I just did this myself on my Late 2015 iMac 5K with the 2TB Fusion Drive. I swapped the dinosaur HDD for a 4TB Samsung 870 QVO 2.5” SATA SSD and my computer feels like new! better than new!
    I don’t recommend replacing the blade SSD because it’s a lot more complicated and you run a real risk of damaging the logic board.
    R L -
    @R L I'm 99% certain that it is not possible to fuse two SSD drives (and certainly not advised). i.e. your 2.5" SATA SSD and your stock blade SSD. I'm about to replace the failing 3TB HDD in my Late-2013 iMac 27 (stock 128gb blade SSD). My plan, assuming the blade drive even mounts, is to format it and let it mount as a separate volume. It's too small to really be of any use and my understanding is the disparate speeds may actually reduce performance overall.
    Kupe - Yanıt
    I have fused the stock ssd drive with a samsung evo ssd drive for years with no problems in my 2012 iMac The downside is that to do so you have to boot from a recovery disk and do pretty complicated stuff with terminal to fuse both ssd drives. Once that's done you cannot touch your fusion drive with disk utility (mac will not reboot and you will have to erase both disk and start over). The easy option is just leave both drives separated, they work just like any standard ssd drive.
    David C. - Yanıt
    It seems to me that some emphasis could be added to this step. I had successfully upgraded my HDD to SDD, and I had confirmed the success of the upgrade by booting my iMac 5G 27 2017 to the Apple prompt. In this step 19, I did not use a sufficient, nor a strong enough masking tape to hold my monitor when I was attempting to remove the backing from the bottom adhesive strips in Step 23. When the tape let go, the monitor screen dropped, and unfortunately I still had the power and data cables connected. In the process the data cable and the power cable receptacle were damaged. I hope to recover by purchasing a new data cable. the power receptacle is still usable, perhaps with an adhesive tape piece over the connection. I found this procedure difficult.
    NTAbbott - Yanıt
  20. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 3.
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 22.
    • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
    • Flip the display data connector lock down onto the socket.
    • Insert the display power connector into its socket on the logic board.
    After I completed this repair I noticed that the fan was spinning all the time. What is going on?
    Diane Radke - Yanıt
    If the fan is going constantly the thermal (temperature) sensor is likely not attached to the hard drive. It should be okay to run it like this - but it’s loud… Better to have the thermal sensor attached and configured. I bought my kit from iFixit and the sensor was wrapped in some of the paper packaging - took me a few minutes to find it.
    Greg Postma - Yanıt
    I used my foam support wedge to hold open the glass side from the enclosure side. I placed in in the center to even out the weight. I used the longer areas of the wedge so more was in contact with the two parts. This freed up my hands to plug in both power and data cables. *Just be careful
    You can also use a sw version instead of a hw thermal sensor. I found on my 27 inch iMac 2019, that the hw sensor didn’t really work for me. In fact, some of the ssd cases used in the hard drive bay are made of plastic. I found for me using Mac Fan Control by Crystal Ideal a good alternative. You can use the free version, or pay for the pro version for about 15.00 dollars to have better control of your fan speed. Of course, your mileage may vary.
    George Martinez - Yanıt
  21. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 21, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 21, 2 resimden 2.
    • Set the display back on the iMac's rear enclosure.
    • At this time, plug in your iMac, power it on, and test your repair before sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  22. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 3.
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
    Here's a sure fire way to replace the LCD onto the frame. It involves using painters tape, a foam wedge and 12" Surgical Hemostat Forceps clamps. iMac is upright on a low table so I can look down into it, painters tape applied, Foam wedge keeps it at an upward tilting angle. Headlamp recommended. LCD and power display connectors have been re-attached. Carefully open the LCD from the frame, keep in mind that the 2 cables give you about 2" of space to "look down" and with your 12" locking forceps grab and lock onto the blue tabs, getting a good, firm bite and then pull upwards to detach from the bottom adhesive strips. There will be 2 of them. The pull tab may detach but not difficult to find the transparent thread to continue the pulling. When both sides have films removed, let the display rest back on the frame and plug it in. If boot screen you can then carefully again separate the LCD slightly to then easily pull off the rest of the strips. Reseal and I use 6 pressure clamps on all sides to cure.
  23. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 3.
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
    The display I bought had some pink protective plastic film covering the camera portion of glass on the back of the display. Be sure to remove this before finally seating the display in place! Not doing so would result in improper focusing and a pink tinted picture all the time.
    VikingShips - Yanıt
    amazing now it won't turn on anymore. I see as green LED but that's it.
    Kerim Incedayi - Yanıt
  24. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 3.
    Microfiber Cleaning Cloths
    $3.99
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
  25. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 3.
    • Remove one side of the protective film from the top left strip by pulling its tab straight up.
  26. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 26, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 26, 2 resimden 2.
    • Remove the other side of the protective film from the top left strip.
  27. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 27, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 27, 2 resimden 2.
    • Repeat the previous steps to remove the protective films from all the remaining adhesive strips.
    When pulling the adhesive strips off I had one snap in half right (just the white part revealing the adhesive) one my top right corner. I panicked because there was not adhesive there so I pulled a quick maneuver. I slipped in one of the guitar pick type triangles near the gap quickly before the adhesive has set in and was then able to slip my bent nose tweezers in and grab the white tape and peal the remaining. Whew! It worked. *Just be careful
  28. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 28, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 28, 2 resimden 2.
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
    • Remove the tape securing the display to the rear enclosure.
    • Check the display after 24 hours to make sure that it is not loose on the iMac.
    Before lowering the glass display, I would recommend removing the tape from the edges, in order to check that the glass is seated flush against the bottom shelf of the frame. In my case, the glass got slightly out of alignment with all the lifting and lowering of the display, and I ended up with one corner being about 1 mm above the frame ledge. Not a huge error, but regrettable, as once you start to lower the display with all adhesive exposed, there is no turning back!
    A big +1 to this. I had the same issue but was able to adjust the monitor before it was fully set. Hopefully the guide can be updated with this suggestion!
    I also did 1 more power on check after removing the screen after pulling the bottom strips covers off.
    Don Rhodes -
    Has anyone had the display fall out after a few days of use when the machine warms up and the adhesive softens?
    How do we prevent that from happening?
    Is it just my imagination or are the replacement adhesive strips thinner than the Apple originals? After cutting the original adhesive we are left with a thin layer on the frame AND a thin layer on the back of the front glass. To me it feels like the replacement tape is only as thick as one of these layers, so there’s less flex to take up any minor variations in level and ultimately a weaker join.
    I also have no idea if the replacement adhesive retains its grab strength once the machine warms up in use.
    Cool_Breeze - Yanıt
    I'm an (unauthorized) Apple computer tech and have replaced over 24 displays on 21.5 and 27" iMacs. The only time I had a display fall off was when I tried using GooGone to remove the adhesive residue. It leaves a greasy residue that is hard to remove and will prevent proper adhesion of the replacement strips. My customer found that her 27" display had fallen off TWICE (both times it miraculously ended up on their office chair with no damage). I now use 91% IPA and the flat edge of a new spudger tool to remove residue. Never had a problem since.
    I've used several different makes of strips purchased via amazon and they all work fine.
    Corey Matsumoto -
    I have the same problem. I followed the instructions exactly, after gluing the display I let the iMac lie on its back for 24 hours.
    Then I tilted the iMac forward and after 2 days the display started to peel off.
    What needs to be done so that the display does not come off? Ambient temperature? Or is it necessary to heat the display somehow after gluing the display?
    Ondrej -
    Corey, could I ask you a question? Have you successfully removed a display after it has been attached using the aftermarket adhesive strips? I didn't have a problem removing the original display adhesive, but when I decided to reopen my iMac to upgrade the SSD, I had a very difficult time, which ended up breaking the screen...Thanks very much
    S. Baxter - Yanıt
    When I replaced my screen. I heated up the edges of the screen with a hair dryer to soften the adhesive. Thereby allowing the adhesive to create a more solid bond. Seems to be working ok.
    David Church - Yanıt
Bitiş Çizgisi
104 farklı kişi bu kılavuzu tamamladı.
508.956 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.583 adet Kılavuz yazıldı
5 Yorum
Is there any reason to believe that Apple would deny any warranty repairs due to these adhesive strips not being identical to Apple's? I'd like to open and clean my iMac before taking it in to have the display replaced under warranty, but the vibes I'm getting from Apple support suggest that Apple may deny me service if the adhesive strips 'show any signs of tampering', i.e., being replaced for any reason. This sounds silly to me, as it doesn't void Apple's warranty to upgrade my hard drive.
gibsonjont - Yanıt
<<<crickets>>>
gibsonjont - Yanıt
Unfortunately, these strips are not even close to the original ones. Has anyone tried to reopen the iMac with these strips in place? A real pain… The original one must have a sort of foam in-between so that one can cut through with the ifixit wheel or a knife. After that, it is easy to remove the adhesive swipes on both sides. Trying to reopen an iMac with the iFixit strips in place is really hard and impossible with the iFixit wheel. Sad…
rozakis - Yanıt
True ! Same goes with OWC’s strips : no foam.
The only way to reopen the iMac should it be needed, is to use razor blades…
José -
Clear tuto, I did it on several IMac, the first time was a discovery… than it became easier on the following, as usual the best is to take your time and follow the instructions which are very clear
Ivan Corbet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 185
Her zaman: 44,874
