Ana içeriğe geç
iPad 6 Wi-Fi LCD Replacement
Neye ihtiyacın var
    1. iPad 6 Wi-Fi LCD Replacement, Heat the left edge: adım 1, 1 resimden 1.
      • Heat an iOpener and apply it to the left edge of the device for two minutes.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 6 Wi-Fi LCD Replacement, Screen removal information: adım 2, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Screen removal information: adım 2, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Screen removal information: adım 2, 3 resimden 3.
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Antennas
      • Display cables
      FixBot'a Sor
      Yorum Ekle
    3. iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      FixBot'a Sor
      Yorum Ekle
    4. iPad 6 Wi-Fi LCD Replacement: adım 4, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 4, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 4, 3 resimden 3.
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBot'a Sor
      Yorum Ekle
    5. iPad 6 Wi-Fi LCD Replacement: adım 5, 2 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 5, 2 resimden 2.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      FixBot'a Sor
      Yorum Ekle
    6. iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: adım 6, 3 resimden 3.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      FixBot'a Sor
      Yorum Ekle
    7. iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: adım 7, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: adım 7, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: adım 7, 3 resimden 3.
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      FixBot'a Sor
      Yorum Ekle
    8. iPad 6 Wi-Fi LCD Replacement: adım 8, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 8, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 8, 3 resimden 3.
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      FixBot'a Sor
      Yorum Ekle
    9. iPad 6 Wi-Fi LCD Replacement: adım 9, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 9, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 9, 3 resimden 3.
      • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      FixBot'a Sor
      Yorum Ekle
    10. iPad 6 Wi-Fi LCD Replacement, Heat the top edge: adım 10, 1 resimden 1.
      • Heat an iOpener and apply it to the top edge of the device for two minutes.
      FixBot'a Sor
      Yorum Ekle
    11. iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: adım 11, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: adım 11, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: adım 11, 3 resimden 3.
      • Rotate the pick around the top-left corner of the device to separate the adhesive.
      FixBot'a Sor
      Yorum Ekle
    12. iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
      • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      FixBot'a Sor
      Yorum Ekle
    13. iPad 6 Wi-Fi LCD Replacement: adım 13, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 13, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 13, 3 resimden 3.
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      FixBot'a Sor
      Yorum Ekle
    14. iPad 6 Wi-Fi LCD Replacement: adım 14, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 14, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 14, 3 resimden 3.
      • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      FixBot'a Sor
      Yorum Ekle
    15. iPad 6 Wi-Fi LCD Replacement, Heat the right edge: adım 15, 1 resimden 1.
      • Heat an iOpener and apply it to the right edge of the device for two minutes.
      FixBot'a Sor
      Yorum Ekle
    16. iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: adım 16, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: adım 16, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: adım 16, 3 resimden 3.
      • Rotate the pick around the top-right corner of the device to separate the adhesive.
      FixBot'a Sor
      Yorum Ekle
    17. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 17, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 17, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 17, 3 resimden 3.
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • Stop sliding once you reach five inches from the bottom of the iPad to avoid damaging the display cables.
      FixBot'a Sor
      Yorum Ekle
    18. iPad 6 Wi-Fi LCD Replacement, Heat the bottom edge: adım 18, 1 resimden 1.
      • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
      FixBot'a Sor
      Yorum Ekle
    19. iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 3.
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • Leave the pick in the bottom-left corner before moving to the next step.
      FixBot'a Sor
      Yorum Ekle
    20. iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: adım 20, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: adım 20, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: adım 20, 3 resimden 3.
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      FixBot'a Sor
      Yorum Ekle
    21. iPad 6 Wi-Fi LCD Replacement: adım 21, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 21, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 21, 3 resimden 3.
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      • Only insert the pick up to 1 mm to avoid damaging the right antenna.
      FixBot'a Sor
      Yorum Ekle
    22. iPad 6 Wi-Fi LCD Replacement: adım 22, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 22, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 22, 3 resimden 3.
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      FixBot'a Sor
      Yorum Ekle
    23. iPad 6 Wi-Fi LCD Replacement, Heat the right edge: adım 23, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    24. iPad 6 Wi-Fi LCD Replacement: adım 24, 2 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 24, 2 resimden 2.
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      FixBot'a Sor
      Yorum Ekle
    25. iPad 6 Wi-Fi LCD Replacement: adım 25, 2 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 25, 2 resimden 2.
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      FixBot'a Sor
      Yorum Ekle
    26. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 26, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 26, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: adım 26, 3 resimden 3.
      • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
      FixBot'a Sor
      Yorum Ekle
    27. iPad 6 Wi-Fi LCD Replacement: adım 27, 2 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 27, 2 resimden 2.
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      FixBot'a Sor
      Yorum Ekle
    1. iPad 6 Wi-Fi LCD Replacement, LCD: adım 28, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, LCD: adım 28, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, LCD: adım 28, 3 resimden 3.
      • Remove any tape obscuring the LCD screws.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 6 Wi-Fi LCD Replacement: adım 29, 1 resimden 1.
      • Remove the four Phillips #00 4.3 mm screws securing the LCD.
      FixBot'a Sor
      Yorum Ekle
    3. iPad 6 Wi-Fi LCD Replacement: adım 30, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 30, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 30, 3 resimden 3.
      • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
      • Be gentle and keep an eye on the LCD cables as you flip the display over.
      • Lay the LCD on its face to allow access to the display cables.
      • Set the LCD down on a soft, clean, lint-free surface.
      FixBot'a Sor
      Yorum Ekle
    4. iPad 6 Wi-Fi LCD Replacement, Battery connector information: adım 31, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement, Battery connector information: adım 31, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement, Battery connector information: adım 31, 3 resimden 3.
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      FixBot'a Sor
      Yorum Ekle
    5. iPad 6 Wi-Fi LCD Replacement: adım 32, 3 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 32, 3 resimden 2. iPad 6 Wi-Fi LCD Replacement: adım 32, 3 resimden 3.
      • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
      • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
      • Leave the battery blocker in place as you work.
      FixBot'a Sor
      Yorum Ekle
    6. iPad 6 Wi-Fi LCD Replacement: adım 33, 1 resimden 1.
      • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
      FixBot'a Sor
      Yorum Ekle
    7. iPad 6 Wi-Fi LCD Replacement: adım 34, 2 resimden 1. iPad 6 Wi-Fi LCD Replacement: adım 34, 2 resimden 2.
      • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
      • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
      FixBot'a Sor
      Yorum Ekle
    8. iPad 6 Wi-Fi LCD Replacement: adım 35, 1 resimden 1.
      • Remove the LCD.
      FixBot'a Sor
      Yorum Ekle
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.759 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
36.307 adet Kılavuz yazıldı
12Kılavuz Yorumları
No comments…. No one is brave enough to attempt this :)
Tal Glazer - Yanıt Paylaş
I tried to replace the LCD with the iPad AIR 1 LCD and is NOT compatible. It fits and the connector is the same but shows just like tv static noise.
nazareno valentini - Yanıt Paylaş
I have same issue, but with LCD iPad 5, some idea to make it compatible.
Luis Prieto - Yanıt Paylaş
I replaced the front screen and now the number 9 on the passcode keypad isn’t working. I don’t get it.
Richard Lombardo - Yanıt Paylaş
I’m having the same issue! Different numbers, but same issue. Just certain sections of the screen won’t respond to touch.
Adriane Zaic - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 75
Son 30 gün: 255
Her zaman: 41,260
