Ana içeriğe geç
iPad Mini Wi-Fi Battery Replacement
Neye ihtiyacın var
  1. iPad Mini Wi-Fi Battery Replacement, iOpener Heating: adım 1, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement, iOpener Heating: adım 1, 2 resimden 2.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    FixBot'a Sor
    Yorum Ekle
  2. iPad Mini Wi-Fi Battery Replacement: adım 2, 1 resimden 1.
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    FixBot'a Sor
    Yorum Ekle
  3. iPad Mini Wi-Fi Battery Replacement: adım 3, 1 resimden 1.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    FixBot'a Sor
    Yorum Ekle
  4. iPad Mini Wi-Fi Battery Replacement, Alternate iOpener heating method: adım 4, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement, Alternate iOpener heating method: adım 4, 2 resimden 2.
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    FixBot'a Sor
    Yorum Ekle
  5. iPad Mini Wi-Fi Battery Replacement, Front Panel: adım 5, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement, Front Panel: adım 5, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement, Front Panel: adım 5, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  6. iPad Mini Wi-Fi Battery Replacement: adım 6, 1 resimden 1.
    • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
    FixBot'a Sor
    Yorum Ekle
  7. iPad Mini Wi-Fi Battery Replacement: adım 7, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 7, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 7, 3 resimden 3.
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you may risk cracking the glass.
    FixBot'a Sor
    Yorum Ekle
  8. iPad Mini Wi-Fi Battery Replacement: adım 8, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 8, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 8, 3 resimden 3.
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  9. iPad Mini Wi-Fi Battery Replacement: adım 9, 1 resimden 1.
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
    FixBot'a Sor
    Yorum Ekle
  10. iPad Mini Wi-Fi Battery Replacement: adım 10, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 10, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 10, 3 resimden 3.
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
    FixBot'a Sor
    Yorum Ekle
  11. iPad Mini Wi-Fi Battery Replacement: adım 11, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 11, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 11, 3 resimden 3.
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. iPad Mini Wi-Fi Battery Replacement: adım 12, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 12, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 12, 3 resimden 3.
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
    FixBot'a Sor
    Yorum Ekle
  13. iPad Mini Wi-Fi Battery Replacement: adım 13, 1 resimden 1.
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
    FixBot'a Sor
    Yorum Ekle
  14. iPad Mini Wi-Fi Battery Replacement: adım 14, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 14, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 14, 3 resimden 3.
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    FixBot'a Sor
    Yorum Ekle
  15. iPad Mini Wi-Fi Battery Replacement: adım 15, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 15, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 15, 3 resimden 3.
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
    FixBot'a Sor
    Yorum Ekle
  16. iPad Mini Wi-Fi Battery Replacement: adım 16, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 16, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 16, 3 resimden 3.
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
    FixBot'a Sor
    Yorum Ekle
  17. iPad Mini Wi-Fi Battery Replacement: adım 17, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 17, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 17, 3 resimden 3.
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
    FixBot'a Sor
    Yorum Ekle
  18. iPad Mini Wi-Fi Battery Replacement: adım 18, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 18, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 18, 3 resimden 3.
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    FixBot'a Sor
    Yorum Ekle
  19. iPad Mini Wi-Fi Battery Replacement: adım 19, 1 resimden 1.
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
    FixBot'a Sor
    Yorum Ekle
  20. iPad Mini Wi-Fi Battery Replacement: adım 20, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 20, 2 resimden 2.
    • Slide the top right opening pick around the corner to fully release the top edge of the glass.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
    FixBot'a Sor
    Yorum Ekle
  21. iPad Mini Wi-Fi Battery Replacement: adım 21, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 21, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 21, 3 resimden 3.
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    FixBot'a Sor
    Yorum Ekle
  22. iPad Mini Wi-Fi Battery Replacement: adım 22, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 22, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 22, 3 resimden 3.
    • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
    FixBot'a Sor
    Yorum Ekle
  23. iPad Mini Wi-Fi Battery Replacement: adım 23, 1 resimden 1.
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
    FixBot'a Sor
    Yorum Ekle
  24. iPad Mini Wi-Fi Battery Replacement: adım 24, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 24, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 24, 3 resimden 3.
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
    FixBot'a Sor
    Yorum Ekle
  25. iPad Mini Wi-Fi Battery Replacement: adım 25, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 25, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 25, 3 resimden 3.
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
    FixBot'a Sor
    Yorum Ekle
  26. iPad Mini Wi-Fi Battery Replacement: adım 26, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 26, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 26, 3 resimden 3.
    • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
    • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
    • Insert the pick slightly deeper and work it back toward the home button.
    • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
    FixBot'a Sor
    Yorum Ekle
  27. iPad Mini Wi-Fi Battery Replacement: adım 27, 1 resimden 1.
    • Reheat and reapply the iOpener to the top bezel of the iPad.
    FixBot'a Sor
    Yorum Ekle
  28. iPad Mini Wi-Fi Battery Replacement: adım 28, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 28, 2 resimden 2.
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
    • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
    FixBot'a Sor
    Yorum Ekle
  29. iPad Mini Wi-Fi Battery Replacement: adım 29, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 29, 2 resimden 2.
    • Lift slowly and gently to further detach the adhesive along the lower edge.
    FixBot'a Sor
    Yorum Ekle
  30. iPad Mini Wi-Fi Battery Replacement: adım 30, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 30, 2 resimden 2.
    • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
    • If reusing the front panel assembly during reassembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
    FixBot'a Sor
    Yorum Ekle
  31. iPad Mini Wi-Fi Battery Replacement: adım 31, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 31, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 31, 3 resimden 3.
    • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
    • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
    • Return the front-facing camera housing to its recess in the rear case.
    FixBot'a Sor
    Yorum Ekle
  32. iPad Mini Wi-Fi Battery Replacement, LCD Assembly: adım 32, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement, LCD Assembly: adım 32, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement, LCD Assembly: adım 32, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Small pieces of foam tape cover the top and bottom right-hand screws securing the LCD to the rear case.
    • Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
    • Remove the triangular tape covering the lower right LCD screw.
    FixBot'a Sor
    Yorum Ekle
  33. iPad Mini Wi-Fi Battery Replacement: adım 33, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 33, 2 resimden 2.
    • The top left LCD screw may be covered by adhesive tape from the front panel.
    • If the tape is present, use the flat end of a spudger to pry the tape up and away, exposing the LCD screw beneath.
    FixBot'a Sor
    Yorum Ekle
  34. iPad Mini Wi-Fi Battery Replacement: adım 34, 1 resimden 1.
    • Remove the four 3.9 mm Phillips #000 screws securing the LCD to the rear case.
    FixBot'a Sor
    Yorum Ekle
  35. iPad Mini Wi-Fi Battery Replacement: adım 35, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 35, 2 resimden 2.
    • Use a pair of tweezers to peel up the small piece of tape connecting the LCD frame to the right speaker.
    FixBot'a Sor
    Yorum Ekle
  36. iPad Mini Wi-Fi Battery Replacement: adım 36, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 36, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 36, 3 resimden 3.
    • A thin strip of foam tape on the LCD frame is covering a piece of tape connecting the LCD to the panel beneath it. To proceed, you'll have to break and peel up some of the foam tape to expose the tape hidden beneath.
    • Use a pair of thin tweezers to pull up the top of the foam tape surrounding the LCD.
    • Be careful not to touch the LCD with the tweezers, as you may damage the display.
    • Use the tweezers to peel the foam tape up to expose the top of the LCD.
    FixBot'a Sor
    Yorum Ekle
  37. iPad Mini Wi-Fi Battery Replacement: adım 37, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 37, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 37, 3 resimden 3.
    • Insert the tip of a spudger between the LCD frame and the tape on the top of the LCD.
    • Slide the spudger along the space between the LCD frame and tape, separating the tape from the LCD frame.
    FixBot'a Sor
    Yorum Ekle
  38. iPad Mini Wi-Fi Battery Replacement: adım 38, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 38, 2 resimden 2.
    • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
    • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
    • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
    FixBot'a Sor
    Yorum Ekle
  39. iPad Mini Wi-Fi Battery Replacement: adım 39, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 39, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 39, 3 resimden 3.
    • Insert the guitar pick into three more locations down the left side of the LCD and bend it over in each location, to slide the LCD over to the right side of the rear case.
    FixBot'a Sor
    Yorum Ekle
  40. iPad Mini Wi-Fi Battery Replacement: adım 40, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 40, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 40, 3 resimden 3.
    • Now switch to the right side of the LCD, and pry with the guitar pick in several places along the side to shift the LCD back to the left.
    • Repeat this and the previous step a few times, until the LCD is easily moved left and right.
    FixBot'a Sor
    Yorum Ekle
  41. iPad Mini Wi-Fi Battery Replacement: adım 41, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 41, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 41, 3 resimden 3.
    • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
    • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
    • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
    FixBot'a Sor
    Yorum Ekle
  42. iPad Mini Wi-Fi Battery Replacement: adım 42, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 42, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 42, 3 resimden 3.
    • Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
    • The goal is to separate the adhesive, not to pry the LCD up, so keep the pointed tip of the spudger as low as possible to prevent bending the LCD.
    • If inserting the spudger causes the corner of the LCD to bend up, repeat the steps with the guitar pick to further loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  43. iPad Mini Wi-Fi Battery Replacement: adım 43, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 43, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 43, 3 resimden 3.
    • Repeat the previous procedure along the top of the LCD.
    • Insert the flat end of the spudger between the LCD frame and metal backing plate and gently push the spudger in across the top of the device, separating adhesive.
    FixBot'a Sor
    Yorum Ekle
  44. iPad Mini Wi-Fi Battery Replacement: adım 44, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 44, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 44, 3 resimden 3.
    • Continue with the left side of the LCD: insert the flat end of the spudger between the LCD and shield plate and insert the spudger as far as it will go.
    • At this point the LCD should be loosened from the adhesive holding it. If it is not, re-insert the spudger on the right side or top to fully free the LCD.
    FixBot'a Sor
    Yorum Ekle
  45. iPad Mini Wi-Fi Battery Replacement: adım 45, 1 resimden 1.
    • Lift the LCD up a couple inches from the rear case to ensure it's free from the adhesive.
    FixBot'a Sor
    Yorum Ekle
  46. iPad Mini Wi-Fi Battery Replacement: adım 46, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 46, 2 resimden 2.
    • Two wide strips of tape connect the LCD to the speakers.
    • While holding the LCD with one hand, Insert the flat end of a spudger into the gap between this tape and the left speaker.
    • Gently pull the LCD away from the speakers while rotating the spudger outward to separate the tape from the speaker.
    FixBot'a Sor
    Yorum Ekle
  47. iPad Mini Wi-Fi Battery Replacement: adım 47, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 47, 2 resimden 2.
    • Insert the flat end of the spudger into the gap between the right speaker and the LCD tape.
    • While pulling the LCD away from the speakers, rotate the spudger outward, widening the gap and releasing the tape from the speaker.
    FixBot'a Sor
    Yorum Ekle
  48. iPad Mini Wi-Fi Battery Replacement: adım 48, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 48, 2 resimden 2.
    • Flip the LCD over and rest it on top of the front panel glass.
    • Do not attempt to remove the LCD from the iPad, as it is still connected by its data cable.
    FixBot'a Sor
    Yorum Ekle
  49. iPad Mini Wi-Fi Battery Replacement, LCD Shield Plate: adım 49, 1 resimden 1.
    • Remove the following screws securing the LCD shield plate to the rear case of the iPad:
    • Two 2.6 mm Phillips #00
    • Thirteen 1.7 mm Phillips #00
    • One additional 1.7 mm Phillips #00 on some devices.
    FixBot'a Sor
    Yorum Ekle
  50. iPad Mini Wi-Fi Battery Replacement: adım 50, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 50, 2 resimden 2.
    • Insert the flat end of a spudger underneath the center of the LCD shield plate from the bottom end of the iPad.
    • Pry up on the spudger to free the plate from the sides of the rear case.
    FixBot'a Sor
    Yorum Ekle
  51. iPad Mini Wi-Fi Battery Replacement: adım 51, 1 resimden 1.
    • Remove the LCD shield plate from the iPad.
    FixBot'a Sor
    Yorum Ekle
  52. iPad Mini Wi-Fi Battery Replacement, Battery Connector: adım 52, 1 resimden 1.
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
    FixBot'a Sor
    Yorum Ekle
  53. iPad Mini Wi-Fi Battery Replacement: adım 53, 1 resimden 1.
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
    FixBot'a Sor
    Yorum Ekle
  54. iPad Mini Wi-Fi Battery Replacement: adım 54, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 54, 2 resimden 2.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
    FixBot'a Sor
    Yorum Ekle
  55. iPad Mini Wi-Fi Battery Replacement, LCD: adım 55, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement, LCD: adım 55, 2 resimden 2.
    • Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
    • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
    FixBot'a Sor
    Yorum Ekle
  56. iPad Mini Wi-Fi Battery Replacement: adım 56, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 56, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 56, 3 resimden 3.
    • The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame.
    • While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
    • Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
    • It may help to twist the spudger, to spread the gap the rest of the way and separate the LCD from the tape.
    FixBot'a Sor
    Yorum Ekle
  57. iPad Mini Wi-Fi Battery Replacement: adım 57, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 57, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 57, 3 resimden 3.
    • While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
    • Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
    FixBot'a Sor
    Yorum Ekle
  58. iPad Mini Wi-Fi Battery Replacement: adım 58, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 58, 2 resimden 2.
    • Lift and remove the LCD from the iPad Mini.
    FixBot'a Sor
    Yorum Ekle
  59. iPad Mini Wi-Fi Battery Replacement, Front Panel Assembly: adım 59, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement, Front Panel Assembly: adım 59, 2 resimden 2.
    • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
    • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
    • Gently pry the digitizer connector up from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  60. iPad Mini Wi-Fi Battery Replacement: adım 60, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 60, 2 resimden 2.
    • Gently pry the digitizer cable board up from the rear case.
    FixBot'a Sor
    Yorum Ekle
  61. iPad Mini Wi-Fi Battery Replacement: adım 61, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 61, 2 resimden 2.
    • Lift and remove the front panel from the iPad.
    FixBot'a Sor
    Yorum Ekle
  62. iPad Mini Wi-Fi Battery Replacement, Battery: adım 62, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement, Battery: adım 62, 2 resimden 2.
    • Reheat the iOpener in the microwave for one minute.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
    • Place the heated iOpener on the back of the iPad, along the center. Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the right of the back of the iPad (the side opposite the rear-facing camera), and let the iOpener sit for another 90 seconds.
    • If the iOpener cools significantly between sittings, reheat it for another minute.
    FixBot'a Sor
    Yorum Ekle
  63. iPad Mini Wi-Fi Battery Replacement: adım 63, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 63, 2 resimden 2.
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Flip the iPad back over and insert a plastic card between the top left battery and the rear case.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
    FixBot'a Sor
    Yorum Ekle
  64. iPad Mini Wi-Fi Battery Replacement: adım 64, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 64, 2 resimden 2.
    • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
    FixBot'a Sor
    Yorum Ekle
  65. iPad Mini Wi-Fi Battery Replacement: adım 65, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 65, 2 resimden 2.
    • Remove the plastic card and reinsert it underneath the top right corner of the battery.
    FixBot'a Sor
    Yorum Ekle
  66. iPad Mini Wi-Fi Battery Replacement: adım 66, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 66, 2 resimden 2.
    • Again, press the card in further, to break more of the adhesive behind the battery.
    • Leave this card in place to prevent the adhesive from resetting.
    FixBot'a Sor
    Yorum Ekle
  67. iPad Mini Wi-Fi Battery Replacement: adım 67, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 67, 2 resimden 2.
    • Insert a second plastic card beneath the bottom left corner of the battery.
    FixBot'a Sor
    Yorum Ekle
  68. iPad Mini Wi-Fi Battery Replacement: adım 68, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 68, 2 resimden 2.
    • Slowly push the card in further, breaking more of the adhesive between the battery and the rear case.
    FixBot'a Sor
    Yorum Ekle
  69. iPad Mini Wi-Fi Battery Replacement: adım 69, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 69, 2 resimden 2.
    • Remove the card and reinsert it, beneath the bottom right corner of the battery.
    FixBot'a Sor
    Yorum Ekle
  70. iPad Mini Wi-Fi Battery Replacement: adım 70, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 70, 2 resimden 2.
    • Push the card further underneath the battery.
    FixBot'a Sor
    Yorum Ekle
  71. iPad Mini Wi-Fi Battery Replacement: adım 71, 2 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 71, 2 resimden 2.
    • Grasp both cards and slowly pull the right side of the battery up about two inches from the rear case.
    • Peel slowly and try to keep the battery as straight as possible.
    FixBot'a Sor
    Yorum Ekle
  72. iPad Mini Wi-Fi Battery Replacement: adım 72, 1 resimden 1.
    • While lifting the right side of the battery up with one hand, use a plastic card to cut any adhesive still holding the battery down to the rear case.
    FixBot'a Sor
    Yorum Ekle
  73. iPad Mini Wi-Fi Battery Replacement: adım 73, 3 resimden 1. iPad Mini Wi-Fi Battery Replacement: adım 73, 3 resimden 2. iPad Mini Wi-Fi Battery Replacement: adım 73, 3 resimden 3.
    • Lift and remove the battery from the iPad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
60 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.305 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.603 adet Kılavuz yazıldı
8Kılavuz Yorumları
What a great guide! Using this, I was able to disassemble my iPad Mini and replace the batter for around $30. I used a heat gun (carefully, 10 seconds at a time) instead of the microwaveable sock thingy. Everything went perfectly, just like in the pictures and instructions. Thanks again!
Charles Haase - Yanıt Paylaş
For the re-assembly, do we need to apply fresh adhesive to keep the digitizer from coming loose?
pfaulconer - Yanıt Paylaş
It is a !&&* of work, but it works at least from being capable to do it and it went relativerly smoothly. But!!! Even if for sure I didn’t break anything, the iPad doesn’t work at all. It looks to me as for sure nothing went wrong during the change and repair process, that simply the new battery is broken, or is there any trick to get it running like in other cases were a battery activation process is required? I’m really disappointed after all this work and being so careful with each step during the process!!!
Dirk Neudert - Yanıt Paylaş
wait, that’s it? What do I do with the included adhesive???????????????????
jfaulks1 - Yanıt Paylaş
Thanks for this tutorial. What else could I use for heating a tablet? This is the most questionable part I think. Anything else is a quite usual and simple at least for me.
Clayton Simpson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 44
Son 30 gün: 231
Her zaman: 89,044
