Ana içeriğe geç
iPad Pro 12.9" 2nd Gen Home Button Replacement
Neye ihtiyacın var
    1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Prepare your iPad for disassembly: adım 1, 1 resimden 1.
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      FixBot'a Sor
      Yorum Ekle
    1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Tape over a cracked screen: adım 2, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Tape over a cracked screen: adım 2, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Tape over a cracked screen: adım 2, 3 resimden 3.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear eye protection. The glass may break, sending pieces flying.
      FixBot'a Sor
      Yorum Ekle
    2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Adhesive tip: adım 3, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Adhesive tip: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      Halberd Spudger
      $2.99
      • Removing the screen involves using an opening pick and/or halberd spudger to separate the adhesive securing the screen to the frame.
      • As you slice through the adhesive, note the following:
      • The adhesive on the long edges of the iPad is about 4 mm wide. Avoid slicing deeper than that, or you risk damaging the display panel.
      • The adhesive on the short edges of the iPad is about 2 mm wide. Avoid slicing deeper than that.
      • Take especially care when slicing near the home button and charging port to avoid damaging the flex cables.
      • Take extra care when you slice near the front facing camera, to avoid damaging or smearing it.
      FixBot'a Sor
      Yorum Ekle
    3. iPad Pro 12.9" 2nd Gen Home Button Replacement, Heat the left edge: adım 4, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Heat the left edge: adım 4, 2 resimden 2.
      • Apply a heated iOpener to the left edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      • The display adhesive of the iPad is strong and the glass breaks easily. You need to reheat and reapply the iOpener in each section several times during the display removal.
      FixBot'a Sor
      Yorum Ekle
    4. iPad Pro 12.9" 2nd Gen Home Button Replacement, Anti-Clamp instructions: adım 5, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Anti-Clamp instructions: adım 5, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Anti-Clamp instructions: adım 5, 3 resimden 3.
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      FixBot'a Sor
      Yorum Ekle
    5. iPad Pro 12.9" 2nd Gen Home Button Replacement: adım 6, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement: adım 6, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement: adım 6, 3 resimden 3.
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBot'a Sor
      Yorum Ekle
    6. iPad Pro 12.9" 2nd Gen Home Button Replacement: adım 7, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement: adım 7, 2 resimden 2.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      FixBot'a Sor
      Yorum Ekle
    7. iPad Pro 12.9" 2nd Gen Home Button Replacement, Apply a suction handle: adım 8, 1 resimden 1.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the iPad's screen, above the Smart Connector port and as close to the edge as possible.
      FixBot'a Sor
      Yorum Ekle
    8. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 9, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 9, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 9, 3 resimden 3.
      • While holding down the corners of the iPad, repeatedly pull up on the screen, then ease it back down to weaken the adhesive. This will eventually create a small gap in the seam.
      • If the edge cools down during the pulling process, reheat the edge with an iOpener before proceeding.
      • Once you've created a small gap, insert the tip of an opening pick into the gap.
      • Don't insert your opening pick deeper than 3–4 mm, or you risk permanently damaging the display panel.
      FixBot'a Sor
      Yorum Ekle
    9. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 10, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 10, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 10, 3 resimden 3.
      • Reapply the iOpener to the bottom left corner of the iPad for at least 2 minutes, spanning from the opening pick to the home button.
      • After letting the adhesive soften, insert an opening pick or halberd spudger into the gap next to the opening pick.
      • Don't insert your slicing tool deeper than 3–4 mm, or you risk permanently damaging the display panel.
      • Use an opening pick or halberd spudger to slice the adhesive along the bottom left side of the iPad. If the slicing becomes difficult, reheat the edge and try again.
      FixBot'a Sor
      Yorum Ekle
    10. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 11, 1 resimden 1.
      • Insert an opening pick underneath the bottom left corner of the screen to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    11. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 12, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 12, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 12, 3 resimden 3.
      • Reapply the iOpener to the upper left corner of the iPad for at least 2 minutes, spanning from the opening pick to the front facing camera.
      • Use an opening pick or halberd spudger and slide along the upper left edge of the iPad to slice the adhesive.
      • If the slicing becomes difficult, reheat the edge and try again.
      FixBot'a Sor
      Yorum Ekle
    12. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 13, 1 resimden 1.
      • Insert an opening pick underneath the top left corner of the screen to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    13. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 14, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 14, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 14, 3 resimden 3.
      • Reheat your iOpener and apply it the top edge of the device for at least 2 minutes.
      • Use an opening pick or halberd spudger and slide along the top edge of the iPad to slice the adhesive. Stop before you reach the front-facing camera.
      • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the display panel.
      FixBot'a Sor
      Yorum Ekle
    14. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 15, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 15, 2 resimden 2.
      • Insert an opening pick underneath the screen just before the front-facing camera to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    15. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 16, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 16, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 16, 3 resimden 3.
      • Reheat your iOpener and apply it to the top edge of the device for at least 2 minutes.
      • Insert an opening pick or a halberd spudger just past the front-facing camera.
      • Use your cutting tool to slice the remaining adhesive underneath the top edge of your device.
      • If the slicing becomes hard, reheat the edge and try again.
      FixBot'a Sor
      Yorum Ekle
    16. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 17, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 17, 2 resimden 2.
      • Insert an opening pick underneath the upper right corner of the screen to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    17. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 18, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 18, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 18, 3 resimden 3.
      • Apply a heated iOpener to the right edge of the screen for 5 minutes to loosen the adhesive underneath.
      • Use an opening pick or halberd spudger and slide along the right edge of the iPad to slice the adhesive.
      • Insert an opening pick underneath the center of the right edge to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    18. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 19, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 19, 2 resimden 2.
      • Insert an opening pick underneath the bottom right corner of the iPad to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    19. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 20, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 20, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 20, 3 resimden 3.
      • Reheat your iOpener and apply it to the bottom edge of the device for at least 2 minutes.
      • Insert an opening pick or a halberd spudger underneath the bottom right corner of the iPad.
      • Slide the opening pick along the bottom edge of the iPad, stopping short about 12 mm before reaching the home button.
      FixBot'a Sor
      Yorum Ekle
    20. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 21, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Insert an opening pick: adım 21, 2 resimden 2.
      • Insert an opening pick underneath the screen just before the home button to prevent the adhesive from resealing.
      • Use the tip of an opening pick or an halberd spudger to slice the adhesive beneath the home button.
      • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the home button.
      FixBot'a Sor
      Yorum Ekle
    21. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 22, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Slice the adhesive: adım 22, 2 resimden 2.
      • Insert an opening pick or a halberd spudger just past the home button.
      • Use your cutting tool to slice the remaining adhesive underneath the bottom edge of your device.
      FixBot'a Sor
      Yorum Ekle
    22. iPad Pro 12.9" 2nd Gen Home Button Replacement, Loosen and slice any remaining adhesive: adım 23, 1 resimden 1.
      • At this point, you've sliced through most of the screen adhesive. Use an opening pick to carefully slice any remaining adhesive along the edges until the screen is freed.
      • If some parts are stubborn, heat the area with an iOpener to loosen the adhesive.
      FixBot'a Sor
      Yorum Ekle
    23. iPad Pro 12.9" 2nd Gen Home Button Replacement, Lift the display: adım 24, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Lift the display: adım 24, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Lift the display: adım 24, 3 resimden 3.
      • The iPad shown in the following two steps is the iPad Pro 12.9" 1st Generation. The internals look slightly different but the taping procedure is the same.
      • The display cables in this iPad are very short. Read the next two steps before you proceed.
      • Do not pivot the screen about the lower edge. The display cables don't have enough slack to allow for this and will tear if you do not slide the screen towards the front-facing camera as you lift.
      • The display cables will tear if you raise the screen more than 90º.
      • Lift up the upper edge of the screen and slide the entire screen towards the front-facing camera to access the iPad's internal components.
      • Use masking tape to tape the lower edge of the screen to the frame to prevent the screen from slipping.
      FixBot'a Sor
      Yorum Ekle
    24. iPad Pro 12.9" 2nd Gen Home Button Replacement, Prop up the screen: adım 25, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Prop up the screen: adım 25, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Prop up the screen: adım 25, 3 resimden 3.
      • This step shows one way to support the screen using masking tape. You can also turn the iPad sideways. Make sure not to strain the display cables with whatever method you choose.
      • Attach a long strip of masking tape to the top edge of the screen. Fold the tape over the edge and make sure that the tape is attached securely.
      • Attach the other end of the strip to the bottom edge of the iPad frame to hold the screen at an angle. Make sure the tape attaches securely to the frame.
      FixBot'a Sor
      Yorum Ekle
    25. iPad Pro 12.9" 2nd Gen Home Button Replacement, Unfasten the logic board EMI shield screws: adım 26, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Unfasten the logic board EMI shield screws: adım 26, 2 resimden 2.
      • It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
      • Use a Phillips screwdriver to remove the six screws securing the logic board EMI shield:
      • Two 2.4 mm-long screws
      • Four 1.2 mm-long screws
      FixBot'a Sor
      Yorum Ekle
    26. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the logic board EMI shield: adım 27, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the logic board EMI shield: adım 27, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the logic board EMI shield: adım 27, 3 resimden 3.
      • Lift the logic board EMI shield from the edge nearest the top of the iPad.
      • Peel up the EMI shield from the logic board.
      • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when you reinstall it and screw it down.
      • Remove the logic board EMI shield.
      FixBot'a Sor
      Yorum Ekle
    27. iPad Pro 12.9" 2nd Gen Home Button Replacement, Unfasten the display connector bracket screws: adım 28, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Unfasten the display connector bracket screws: adım 28, 2 resimden 2.
      • Use a Phillips screwdriver to remove the four screws securing the display connector bracket:
      • Two 1.2 mm-long screws
      FixBot'a Sor
      Yorum Ekle
    28. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the display connector bracket: adım 29, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the display connector bracket: adım 29, 2 resimden 2.
      • Remove the display connector bracket.
      FixBot'a Sor
      Yorum Ekle
    29. iPad Pro 12.9" 2nd Gen Home Button Replacement, Disconnect the display cables: adım 30, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Disconnect the display cables: adım 30, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Disconnect the display cables: adım 30, 3 resimden 3.
      • Use the pointed end of a spudger to pry up and disconnect the display and digitizer cables from their logic board sockets.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • These cables are very delicate, and the connectors can damage easily if they're misaligned. When you reattach the cables to the logic board, try to have as much slack on the cables and gently press the connectors onto their sockets.
      FixBot'a Sor
      Yorum Ekle
    30. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the screen assembly: adım 31, 1 resimden 1.
      • Remove the screen assembly.
      FixBot'a Sor
      Yorum Ekle
    1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the tape: adım 32, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the tape: adım 32, 2 resimden 2.
      • Use tweezers to peel off the tape covering the ZIF connector above the home button.
      FixBot'a Sor
      Yorum Ekle
    2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Release the ZIF connector: adım 33, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Release the ZIF connector: adım 33, 2 resimden 2.
      • Use the point of a spudger to open the ZIF connector that secures the cable by bringing its flap in an upright position.
      FixBot'a Sor
      Yorum Ekle
    3. iPad Pro 12.9" 2nd Gen Home Button Replacement, Disconnect the home button: adım 34, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Disconnect the home button: adım 34, 2 resimden 2.
      • Use tweezers to slide the cable out of the ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    4. iPad Pro 12.9" 2nd Gen Home Button Replacement, Loosen the home button cable adhesive: adım 35, 1 resimden 1.
      • The home button's ribbon cable is very fragile. If it gets damaged, Touch ID will no longer function.
      • Apply a heated iOpener to the home button for 2 minutes to loosen the adhesive underneath its cable.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the screen.
      FixBot'a Sor
      Yorum Ekle
    5. iPad Pro 12.9" 2nd Gen Home Button Replacement, Free the home button cable: adım 36, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Free the home button cable: adım 36, 2 resimden 2.
      • Carefully slide an opening pick underneath the home button cable to separate it from the screen.
      FixBot'a Sor
      Yorum Ekle
    6. iPad Pro 12.9" 2nd Gen Home Button Replacement, Loosen the home button bracket adhesive.: adım 37, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Loosen the home button bracket adhesive.: adım 37, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Loosen the home button bracket adhesive.: adım 37, 3 resimden 3.
      • The home button bracket is held in place with strong adhesive.
      • Apply a few drops of high concentration (90% or higher) isopropyl alcohol to the base of the home button bracket to loosen its adhesive.
      • A heated iOpener, a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the screen.
      FixBot'a Sor
      Yorum Ekle
    7. iPad Pro 12.9" 2nd Gen Home Button Replacement, Pry up the home button bracket: adım 38, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Pry up the home button bracket: adım 38, 2 resimden 2.
      • Insert the edge of an opening tool under the home button bracket lip.
      • Carefully pry up with steady force to loosen the bracket.
      • If you want to transfer your home button to a new screen be especially careful not to damage the home button cable during this procedure.
      • The adhesive holding this bracket can be stubborn. Apply more isopropyl alcohol or heat if it doesn't budge.
      FixBot'a Sor
      Yorum Ekle
    8. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the home button bracket: adım 39, 2 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the home button bracket: adım 39, 2 resimden 2.
      • Use tweezers to carefully pull the home button bracket from underneath the home button cable.
      • Remove the home button bracket.
      FixBot'a Sor
      Yorum Ekle
    9. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the home button: adım 40, 3 resimden 1. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the home button: adım 40, 3 resimden 2. iPad Pro 12.9" 2nd Gen Home Button Replacement, Remove the home button: adım 40, 3 resimden 3.
      • Gently push the home button from the front of the display inward using the tip of a finger.
      • Remove the home button.
      • The home button attaches to the screen with an adhesive gasket. When you transfer the home button to a new display, use some liquid adhesive to glue the button perimeter to the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Dominik Schnabelrauch
262.761 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
56.559 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 2,552
