Ana içeriğe geç
iPhone 11 Pro Front-Facing Cameras Replacement
Neye ihtiyacın var
  1. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the pentalobe screws: adım 1, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the pentalobe screws: adım 1, 2 resimden 2.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 11 Pro Front-Facing Cameras Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 11 Pro Front-Facing Cameras Replacement, Tape over any cracks: adım 3, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Tape over any cracks: adım 3, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Tape over any cracks: adım 3, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 11 Pro Front-Facing Cameras Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 11 Pro Front-Facing Cameras Replacement: adım 5, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 5, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement: adım 5, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 11 Pro Front-Facing Cameras Replacement: adım 6, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 6, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement: adım 6, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 11 Pro Front-Facing Cameras Replacement, Heat the lower edge of the phone: adım 7, 1 resimden 1.
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  8. iPhone 11 Pro Front-Facing Cameras Replacement: adım 8, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 8, 2 resimden 2.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone 11 Pro Front-Facing Cameras Replacement, Lift the display slightly: adım 9, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Lift the display slightly: adım 9, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Lift the display slightly: adım 9, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 11 Pro Front-Facing Cameras Replacement, Separate the screen adhesive: adım 10, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Separate the screen adhesive: adım 10, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Separate the screen adhesive: adım 10, 3 resimden 3.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 11 Pro Front-Facing Cameras Replacement, Screen information: adım 11, 1 resimden 1.
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 11 Pro Front-Facing Cameras Replacement: adım 12, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 12, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement: adım 12, 3 resimden 3.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 11 Pro Front-Facing Cameras Replacement: adım 13, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 13, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement: adım 13, 3 resimden 3.
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  14. iPhone 11 Pro Front-Facing Cameras Replacement: adım 14, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 14, 2 resimden 2.
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
  15. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the suction cup: adım 15, 1 resimden 1.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  16. iPhone 11 Pro Front-Facing Cameras Replacement, Open the iPhone: adım 16, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Open the iPhone: adım 16, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Open the iPhone: adım 16, 3 resimden 3.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 11 Pro Front-Facing Cameras Replacement, Unscrew the battery connector cover: adım 17, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Unscrew the battery connector cover: adım 17, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the battery connector cover: adım 18, 1 resimden 1.
    • Remove the bracket.
  19. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the battery: adım 19, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the battery: adım 19, 2 resimden 2.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 11 Pro Front-Facing Cameras Replacement, Unscrew the logic board cover screws: adım 20, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Unscrew the logic board cover screws: adım 20, 2 resimden 2.
    • Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
  21. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the logic board cover bracket: adım 21, 1 resimden 1.
  22. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the OLED display cable: adım 22, 2 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the OLED display cable: adım 22, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  23. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the front sensors + digitizer: adım 23, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the front sensors + digitizer: adım 23, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the front sensors + digitizer: adım 23, 3 resimden 3.
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  24. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the display assembly: adım 24, 1 resimden 1.
  25. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the Face ID hardware: adım 25, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the Face ID hardware: adım 25, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the Face ID hardware: adım 25, 3 resimden 3.
    • Use a spudger or a fingernail to disconnect the Face ID dot projector and sensor cables from their sockets on the logic board.
  26. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the selfie cam: adım 26, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the selfie cam: adım 26, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement, Disconnect the selfie cam: adım 26, 3 resimden 3.
    • Gently push the Face ID cable connectors away from the logic board to access the selfie cam connector underneath.
    • Disconnect the selfie cam by prying its connector straight up.
  27. iPhone 11 Pro Front-Facing Cameras Replacement: adım 27, 3 resimden 1. iPhone 11 Pro Front-Facing Cameras Replacement: adım 27, 3 resimden 2. iPhone 11 Pro Front-Facing Cameras Replacement: adım 27, 3 resimden 3.
    • Grasp the front camera assembly with tweezers, being careful not to get fingerprints on the sensors.
    • Slide the front camera assembly slightly down and to the left to free it from the enclosure.
  28. iPhone 11 Pro Front-Facing Cameras Replacement, Remove the front-facing cameras: adım 28, 1 resimden 1.
    • Remove the front-facing cameras.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Answers community for help.
13 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
440.364 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 86
Son 30 gün: 333
Her zaman: 20,459
