Ana içeriğe geç
iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement
  1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the pentalobe screws: adım 1, 1 resimden 1.
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Heat the lower edge of the iPhone: adım 2, 1 resimden 1.
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 4, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 4, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 4, 3 resimden 3.
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Apply a suction cup: adım 5, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Apply a suction cup: adım 5, 2 resimden 2.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: adım 6, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: adım 6, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: adım 6, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: adım 7, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: adım 7, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: adım 7, 3 resimden 3.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  8. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 8, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 8, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 8, 3 resimden 3.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
  9. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 9, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 9, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement: adım 9, 3 resimden 3.
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick into the right edge of the phone. Slide it around the top-right corner and across the top edge.
    • Again, don't insert the pick more than a few millimeters—about the width of the display bezel—or you may damage the front panel sensor array.
  10. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: adım 10, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: adım 10, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: adım 10, 3 resimden 3.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  11. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the battery and display connector cover: adım 12, 1 resimden 1.
    • Remove the cover.
  12. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the battery: adım 13, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the battery: adım 13, 2 resimden 2.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  13. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the display cable: adım 14, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the display cable: adım 14, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the digitizer cable: adım 15, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the digitizer cable: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  15. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the front sensor connector cover: adım 16, 1 resimden 1.
    • Use a Y000 driver to remove four screws securing the front sensor connector cover.
    • Three 1.1 mm long screws
    • One 1.4 mm long screw
  16. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the front sensor connector cover: adım 17, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the front sensor connector cover: adım 17, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the front sensor connector cover: adım 17, 3 resimden 3.
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  17. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the front sensors: adım 18, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the front sensors: adım 18, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  18. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the display assembly: adım 19, 1 resimden 1.
  19. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the speaker/sensor assembly: adım 20, 1 resimden 1.
    • Remove the four screws securing the speaker/sensor assembly to the back of the display.
    • Two 1.4 mm long Phillips screws
    • One 1.7 mm long shouldered Y000 screw
    • One 1.2 mm long Y000 screw
  20. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Flip the speaker assembly over: adım 21, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Flip the speaker assembly over: adım 21, 2 resimden 2.
    • The earpiece speaker is lightly adhered in place.
    • Use the point of a spudger to gently pry up the top edge of the speaker.
    • Flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin ribbon cable. Be careful not to strain or damage the cable.
  21. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Heat the top edge of the display: adım 22, 1 resimden 1.
    • Use a hair dryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  22. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the ambient light sensor: adım 23, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the ambient light sensor: adım 23, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the ambient light sensor: adım 23, 3 resimden 3.
    • Use the point of a spudger to lift and separate the ambient light sensor from its notch in the front panel.
    • Take care not to damage the light sensor ribbon cables while prying.
    • Continue sliding the spudger underneath the ambient light sensor and its cable to separate the adhesive securing the cable.
  23. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: adım 24, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: adım 24, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: adım 24, 3 resimden 3.
    • Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
  24. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the proximity sensor and flood illuminator module: adım 25, 2 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the proximity sensor and flood illuminator module: adım 25, 2 resimden 2.
    • Use the point of a spudger to lift the proximity sensor and flood illuminator module out of its notch in the front panel.
  25. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker and front sensor assembly: adım 26, 3 resimden 1. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker and front sensor assembly: adım 26, 3 resimden 2. iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker and front sensor assembly: adım 26, 3 resimden 3.
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
177.797 İtibar
418 adet Kılavuz yazıldı
2 Comments
The title of this Guide is "iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement". The text and photos ONLY SHOW DISASSEMBLY AND THERE IS NO GUIDE ON REASSEMBLY...ESPECIALLY THE DETAIL OF HOW THE PART IS REATTACHED TO THE SCREEN! My experience of this guide is that it is a 50% proposition and is not helpful.
RP
rob - Yanıt
Finally someone said it, any one that’s doing something like this as a beginner is kinda screwed with reassembly the whole in reverse doesn’t work with visual people
Jesse -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 36
Son 7 gün: 241
Son 30 gün: 1,181
Her zaman: 13,724
