Ana içeriğe geç
iPhone 12 Screen Replacement
Neye ihtiyacın var
    1. iPhone 12 Screen Replacement, Remove the pentalobe screws: adım 1, 1 resimden 1.
      • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 12 Screen Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 12 Screen Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 12 Screen Replacement, Mark your opening picks: adım 2, 3 resimden 3.
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 12 Screen Replacement, Tape over any cracks: adım 3, 3 resimden 1. iPhone 12 Screen Replacement, Tape over any cracks: adım 3, 3 resimden 2. iPhone 12 Screen Replacement, Tape over any cracks: adım 3, 3 resimden 3.
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 12 Screen Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 12 Screen Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 12 Screen Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 12 Screen Replacement: adım 5, 3 resimden 1. iPhone 12 Screen Replacement: adım 5, 3 resimden 2. iPhone 12 Screen Replacement: adım 5, 3 resimden 3.
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 12 Screen Replacement: adım 6, 3 resimden 1. iPhone 12 Screen Replacement: adım 6, 3 resimden 2. iPhone 12 Screen Replacement: adım 6, 3 resimden 3.
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 12 Screen Replacement, Heat the bottom edge: adım 7, 1 resimden 1.
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 12 Screen Replacement, Apply a suction cup: adım 8, 2 resimden 1. iPhone 12 Screen Replacement, Apply a suction cup: adım 8, 2 resimden 2.
      • Apply a suction handle to the bottom edge of the screen.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 12 Screen Replacement, Screen information: adım 9, 1 resimden 1.
      • To avoid damaging your screen in the next step, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      FixBot'a Sor
      Yorum Ekle
    8. iPhone 12 Screen Replacement, Lift the screen slightly: adım 10, 3 resimden 1. iPhone 12 Screen Replacement, Lift the screen slightly: adım 10, 3 resimden 2. iPhone 12 Screen Replacement, Lift the screen slightly: adım 10, 3 resimden 3.
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the screen’s plastic bezel.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert an opening pick into the gap.
      • Remember to insert the opening pick under the thick plastic bezel to avoid damaging your screen.
      FixBot'a Sor
      Yorum Ekle
    9. iPhone 12 Screen Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 1. iPhone 12 Screen Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 2. iPhone 12 Screen Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 3.
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      FixBot'a Sor
      Yorum Ekle
    10. iPhone 12 Screen Replacement, Heat the right edge: adım 12, 2 resimden 1. iPhone 12 Screen Replacement, Heat the right edge: adım 12, 2 resimden 2.
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      FixBot'a Sor
      Yorum Ekle
    11. iPhone 12 Screen Replacement, Separate the right adhesive: adım 13, 3 resimden 1. iPhone 12 Screen Replacement, Separate the right adhesive: adım 13, 3 resimden 2. iPhone 12 Screen Replacement, Separate the right adhesive: adım 13, 3 resimden 3.
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      FixBot'a Sor
      Yorum Ekle
    12. iPhone 12 Screen Replacement, Heat the top edge: adım 14, 1 resimden 1.
      • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
      FixBot'a Sor
      Yorum Ekle
    13. iPhone 12 Screen Replacement, Separate the top adhesive: adım 15, 3 resimden 1. iPhone 12 Screen Replacement, Separate the top adhesive: adım 15, 3 resimden 2. iPhone 12 Screen Replacement, Separate the top adhesive: adım 15, 3 resimden 3.
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      FixBot'a Sor
      Yorum Ekle
    14. iPhone 12 Screen Replacement, Heat the left edge: adım 16, 2 resimden 1. iPhone 12 Screen Replacement, Heat the left edge: adım 16, 2 resimden 2.
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      FixBot'a Sor
      Yorum Ekle
    15. iPhone 12 Screen Replacement, Separate the left adhesive: adım 17, 3 resimden 1. iPhone 12 Screen Replacement, Separate the left adhesive: adım 17, 3 resimden 2. iPhone 12 Screen Replacement, Separate the left adhesive: adım 17, 3 resimden 3.
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick down the left edge of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      FixBot'a Sor
      Yorum Ekle
    16. iPhone 12 Screen Replacement, Open the iPhone: adım 18, 3 resimden 1. iPhone 12 Screen Replacement, Open the iPhone: adım 18, 3 resimden 2. iPhone 12 Screen Replacement, Open the iPhone: adım 18, 3 resimden 3.
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      FixBot'a Sor
      Yorum Ekle
    17. iPhone 12 Screen Replacement, Unscrew the battery and display connector cover: adım 19, 1 resimden 1.
      Magnetic Project Mat
      $19.95
      • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      FixBot'a Sor
      Yorum Ekle
    18. iPhone 12 Screen Replacement, Remove the battery and display connector cover: adım 20, 1 resimden 1.
      • Remove the cover.
      FixBot'a Sor
      Yorum Ekle
    19. iPhone 12 Screen Replacement, Disconnect the battery: adım 21, 2 resimden 1. iPhone 12 Screen Replacement, Disconnect the battery: adım 21, 2 resimden 2.
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      FixBot'a Sor
      Yorum Ekle
    20. iPhone 12 Screen Replacement, Disconnect the display cable: adım 22, 2 resimden 1. iPhone 12 Screen Replacement, Disconnect the display cable: adım 22, 2 resimden 2.
      • Use a spudger or a fingernail to disconnect the display cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBot'a Sor
      Yorum Ekle
    21. iPhone 12 Screen Replacement, Disconnect the digitizer cable: adım 23, 2 resimden 1. iPhone 12 Screen Replacement, Disconnect the digitizer cable: adım 23, 2 resimden 2.
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      FixBot'a Sor
      Yorum Ekle
    22. iPhone 12 Screen Replacement, Unscrew the front sensor connector cover: adım 24, 1 resimden 1.
      • Use a Y000 driver to remove four screws securing the front sensor connector cover.
      • Three 1.1 mm long screws
      • One 1.4 mm long screw
      FixBot'a Sor
      Yorum Ekle
    23. iPhone 12 Screen Replacement, Remove the front sensor connector cover: adım 25, 3 resimden 1. iPhone 12 Screen Replacement, Remove the front sensor connector cover: adım 25, 3 resimden 2. iPhone 12 Screen Replacement, Remove the front sensor connector cover: adım 25, 3 resimden 3.
      • Swing the cover up from the left until the small clip on the right unhooks.
      • Remove the cover.
      • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
      FixBot'a Sor
      Yorum Ekle
    24. iPhone 12 Screen Replacement, Disconnect the front sensors: adım 26, 2 resimden 1. iPhone 12 Screen Replacement, Disconnect the front sensors: adım 26, 2 resimden 2.
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      FixBot'a Sor
      Yorum Ekle
    25. iPhone 12 Screen Replacement, Remove the display assembly: adım 27, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 12 Screen Replacement, Unscrew the speaker/sensor assembly: adım 28, 1 resimden 1.
      • Remove the four screws securing the speaker/sensor assembly to the back of the display.
      • Two 1.4 mm long Phillips screws
      • One 1.7 mm long shouldered Y000 screw
      • One 1.2 mm long Y000 screw
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 12 Screen Replacement, Flip the speaker assembly over: adım 29, 2 resimden 1. iPhone 12 Screen Replacement, Flip the speaker assembly over: adım 29, 2 resimden 2.
      • The earpiece speaker is lightly adhered in place.
      • Use the point of a spudger to gently pry up the top edge of the speaker.
      • Flip the speaker assembly over—down and away from the top edge of the display.
      • The speaker remains attached via a very thin ribbon cable. Be careful not to strain or damage the cable.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 12 Screen Replacement, Heat the top edge of the display: adım 30, 1 resimden 1.
      • Use a hair dryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 12 Screen Replacement, Separate the ambient light sensor: adım 31, 3 resimden 1. iPhone 12 Screen Replacement, Separate the ambient light sensor: adım 31, 3 resimden 2. iPhone 12 Screen Replacement, Separate the ambient light sensor: adım 31, 3 resimden 3.
      • Use the point of a spudger to lift and separate the ambient light sensor from its notch in the front panel.
      • Take care not to damage the light sensor ribbon cables while prying.
      • Continue sliding the spudger underneath the ambient light sensor and its cable to separate the adhesive securing the cable.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 12 Screen Replacement, Pry up the microphone: adım 32, 3 resimden 1. iPhone 12 Screen Replacement, Pry up the microphone: adım 32, 3 resimden 2. iPhone 12 Screen Replacement, Pry up the microphone: adım 32, 3 resimden 3.
      • Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 12 Screen Replacement, Pry up the proximity sensor and flood illuminator module: adım 33, 2 resimden 1. iPhone 12 Screen Replacement, Pry up the proximity sensor and flood illuminator module: adım 33, 2 resimden 2.
      • Use the point of a spudger to lift the proximity sensor and flood illuminator module out of its notch in the front panel.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 12 Screen Replacement, Remove the speaker and front sensor assembly: adım 34, 3 resimden 1. iPhone 12 Screen Replacement, Remove the speaker and front sensor assembly: adım 34, 3 resimden 2. iPhone 12 Screen Replacement, Remove the speaker and front sensor assembly: adım 34, 3 resimden 3.
      • Remove the earpiece speaker and front sensor assembly.
      • During reassembly, check the position of the black plastic module containing these components:
      • Proximity sensor
      • Flood illuminator
      • The module must be positioned so that these components are not obstructed by any adhesive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for troubleshooting help.
133 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
224.325 İtibar
416 adet Kılavuz yazıldı
12Kılavuz Yorumları
i am trying to source a replacement screen for my iPhone 12 that needs a new digitizer and battery. My main concern is since I cannot purchase an original part from apple and have to resort to eBay they have several option;
Lcd / Oled soft / Oled hard / Incell lcd??
I asssumed the 12 came with the oled screen and I’m worried that if I put a non original type screen it could damage phone after awhile?
what digitizer should I get?
Adam Anderson - Yanıt Paylaş
Hi, I would recommend looking at places like Fixez.com rather than Ebay. Their prices are lower and they have a LCD buyback program which is very helpful. They have a wide ranging variety of LCD's. On a scale of best to worst LCD's its ranges: OLED Soft,OLED Hard, Incell LCD, LCD. I hope this helps
Tecc World - Yanıt Paylaş
Hi there,
I have read that by installing an aftermarket screen, I would get a non-genuine display message. Has Apple addressed this issue?
Than
Alex Hsu - Yanıt Paylaş
Genuine components have chips that allow the phone to identify them - third party ones frequently do not. The phone is doing what it is designed to do so there isn’t really anything for Apple to address. Much as anything it’s to stop companies refurbishing iPhone’s ‘in-house’ and selling them as having genuine parts. The non genuine part message is t inherently a bad thing, it’s an advisory rather than an error.
Core Confusion - Yanıt Paylaş
Hi, I lent my grandson my iphone 12 and I got it back with a broken screen and a broken back glass. I have another iphone 12 for parts. I was going to swap out the screen and the back glass. My question is do I have to remove all these parts as described above or c an I just plug the new screen in ? Second question my iphone has a Qlink wireless SIM card in it and it works perfect. The same SIM card will not work in my other iphone that being said would it be easier to somehow take my other iphone and use the parts from my broken one so the SIM card would work in it? I don't know what it would entail to do such a thing but if you would possibly know what I would have to do to make this happen please let me know... Otherwise I will take the screen and back glass and continue to install them on my own phone. also which procedure would be easier to do?? Kudos to you on this article I followed it to the letter and everything worked perfect I removed the screen without any problems. GREAT ARTICLE! Thanks Jeffrey
Jeffrey Miller - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 147
Son 7 gün: 1,267
Son 30 gün: 5,537
Her zaman: 364,972
