Ana içeriğe geç
iPhone 13 Pro Max Loudspeaker Replacement
Neye ihtiyacın var
  1. iPhone 13 Pro Max Loudspeaker Replacement, Remove the pentalobe screws: adım 1, 1 resimden 1.
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Pro Max Loudspeaker Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 Pro Max Loudspeaker Replacement, Tape over any cracks: adım 3, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Tape over any cracks: adım 3, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Tape over any cracks: adım 3, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Pro Max Loudspeaker Replacement: adım 5, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement: adım 5, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement: adım 5, 3 resimden 3.
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Pro Max Loudspeaker Replacement: adım 6, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement: adım 6, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement: adım 6, 3 resimden 3.
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 Pro Max Loudspeaker Replacement, Heat the bottom edge: adım 7, 1 resimden 1.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Pro Max Loudspeaker Replacement, Insert an opening pick: adım 8, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Insert an opening pick: adım 8, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Insert an opening pick: adım 8, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 13 Pro Max Loudspeaker Replacement, Heat the right edge: adım 9, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Heat the right edge: adım 9, 2 resimden 2.
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 13 Pro Max Loudspeaker Replacement, Separate the right adhesive: adım 10, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Separate the right adhesive: adım 10, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Separate the right adhesive: adım 10, 3 resimden 3.
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 13 Pro Max Loudspeaker Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 13 Pro Max Loudspeaker Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 13 Pro Max Loudspeaker Replacement, Heat the left edge: adım 13, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Heat the left edge: adım 13, 2 resimden 2.
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 13 Pro Max Loudspeaker Replacement, Screen information: adım 14, 1 resimden 1.
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 13 Pro Max Loudspeaker Replacement, Separate the left adhesive: adım 15, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Separate the left adhesive: adım 15, 2 resimden 2.
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 13 Pro Max Loudspeaker Replacement, Open the iPhone: adım 16, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Open the iPhone: adım 16, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Open the iPhone: adım 16, 3 resimden 3.
    • Remove your suction handle from the screen.
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 13 Pro Max Loudspeaker Replacement, Remove the battery connector cover: adım 17, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the three 1.3 mm screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 13 Pro Max Loudspeaker Replacement: adım 18, 1 resimden 1.
    • Remove the battery connector cover.
  19. iPhone 13 Pro Max Loudspeaker Replacement, Disconnect the battery: adım 19, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Disconnect the battery: adım 19, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Disconnect the battery: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 13 Pro Max Loudspeaker Replacement, Disconnect the display cable: adım 20, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Disconnect the display cable: adım 20, 2 resimden 2.
    • Use the pointed end a spudger or a clean fingernail to pry the display connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 13 Pro Max Loudspeaker Replacement, Unscrew the front sensor connector cover: adım 21, 1 resimden 1.
    • Use a Y000 screwdriver to remove two 1.1 mm screws from the front sensor connector cover.
    • Use a Phillips screwdriver to remove the remaining two screws from the front sensor connector cover:
    • One 1.5 mm screw
    • One 1.8 mm screw
  22. iPhone 13 Pro Max Loudspeaker Replacement: adım 22, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement: adım 22, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement: adım 22, 3 resimden 3.
    • Remove the front sensor connector cover.
  23. iPhone 13 Pro Max Loudspeaker Replacement: adım 23, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement: adım 23, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the front sensor assembly cable connector.
  24. iPhone 13 Pro Max Loudspeaker Replacement: adım 24, 2 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement: adım 24, 2 resimden 2.
  25. iPhone 13 Pro Max Loudspeaker Replacement, Unscrew the loudspeaker: adım 25, 1 resimden 1.
    • Use a Phillips driver to remove the four 1.5 mm screws securing the loudspeaker:
    • Two larger-headed screws
    • Two smaller-headed screws
  26. iPhone 13 Pro Max Loudspeaker Replacement, Separate the loudspeaker adhesive: adım 26, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Separate the loudspeaker adhesive: adım 26, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Separate the loudspeaker adhesive: adım 26, 3 resimden 3.
    • Slide an opening pick between the top edge of the taptic engine and the adhesive-backed strip.
  27. iPhone 13 Pro Max Loudspeaker Replacement, Remove the loudspeaker: adım 27, 1 resimden 1.
    • Remove the loudspeaker.
  28. iPhone 13 Pro Max Loudspeaker Replacement, Transfer the adhesive-backed strip: adım 28, 3 resimden 1. iPhone 13 Pro Max Loudspeaker Replacement, Transfer the adhesive-backed strip: adım 28, 3 resimden 2. iPhone 13 Pro Max Loudspeaker Replacement, Transfer the adhesive-backed strip: adım 28, 3 resimden 3.
    • If your replacement part didn’t come with the plastic strip along the top of the loudspeaker, you'll need to transfer it to your replacement part.
    • Use your fingers to gently peel the adhesive-backed strip off of the loudspeaker.
  29. iPhone 13 Pro Max Loudspeaker Replacement: adım 29, 1 resimden 1.
    • Only the loudspeaker remains.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Pro Max Answers community for help.
6 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
83.813 İtibar
290 adet Kılavuz yazıldı
2 Yorum
Sam, great detail and clear photos but I wanted to see all sides of the loudspeaker and didn’t see them. Could you add more loudspeaker pictures to your post?
Patrick McKone - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 112
Son 30 gün: 429
Her zaman: 19,371
