Ana içeriğe geç
iPhone 14 Pro Rear Camera Assembly Replacement
Neye ihtiyacın var
  1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the pentalobe screws: adım 1, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the pentalobe screws: adım 1, 2 resimden 2.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 14 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 14 Pro Rear Camera Assembly Replacement, Tape over any cracks: adım 3, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Tape over any cracks: adım 3, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Tape over any cracks: adım 3, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 14 Pro Rear Camera Assembly Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 14 Pro Rear Camera Assembly Replacement: adım 5, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement: adım 5, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement: adım 5, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 14 Pro Rear Camera Assembly Replacement: adım 6, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement: adım 6, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement: adım 6, 3 resimden 3.
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the bottom edge: adım 7, 1 resimden 1.
    • If you're using a suction handle, follow the next two steps to loosen the screen.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
    • Never leave your heat gun in one spot for an extended period of time.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 14 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the right edge: adım 9, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the right edge: adım 9, 2 resimden 2.
    • Heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the right adhesive: adım 10, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the right adhesive: adım 10, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the right adhesive: adım 10, 3 resimden 3.
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Heat the top edge of the iPhone until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the left edge: adım 13, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Heat the left edge: adım 13, 2 resimden 2.
    • Heat the left edge of the iPhone until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the left adhesive: adım 14, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the left adhesive: adım 14, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Separate the left adhesive: adım 14, 3 resimden 3.
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 14 Pro Rear Camera Assembly Replacement, Open the iPhone: adım 15, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Open the iPhone: adım 15, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Open the iPhone: adım 15, 3 resimden 3.
    • Remove your suction handle from the screen.
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
    • Lean the screen against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
    • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 14 Pro Rear Camera Assembly Replacement, Unfasten the battery connector cover screws: adım 16, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Unfasten the battery connector cover screws: adım 16, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
    • Five 1.3 mm-long screws
    • Two 1.6 mm-long screw
    • One 1.9 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the battery connector cover: adım 17, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the battery connector cover: adım 17, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the battery connector cover: adım 17, 3 resimden 3.
    • Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
    • Remove the connector cover.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the battery: adım 18, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the battery: adım 18, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the battery: adım 18, 3 resimden 3.
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the display cable: adım 19, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the display cable: adım 19, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 14 Pro Rear Camera Assembly Replacement: adım 20, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement: adım 20, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the second display cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the screen: adım 21, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the screen: adım 21, 2 resimden 2.
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the screen adhesives.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly cover screws: adım 22, 1 resimden 1.
    • Use a tri‑point Y000 driver to remove the five screws securing the rear camera assembly cover:
    • Four 1.5 mm‑long Y000 screws
    • One 1.3 mm‑long Y000 screw
    • Use a Phillips screwdriver to remove one 1.7mm‑long screw.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly cover: adım 23, 3 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly cover: adım 23, 3 resimden 2. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly cover: adım 23, 3 resimden 3.
    • There's a small metal edge in the top right corner of the rear camera assembly cover that is secured by the phone frame.
    • Grab the rear camera assembly cover with a pair of tweezers.
    • Move the rear camera assembly cover toward the volume buttons to free its small metal edge from the frame.
    • Remove the rear camera assembly cover.
    • During reassembly, make sure to align the rear camera assembly cover correctly and push the small metal edge back into its recess in the frame.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the ultra wide and telephoto camera cable: adım 24, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the ultra wide and telephoto camera cable: adım 24, 2 resimden 2.
    • Use a spudger to disconnect the ultra wide and telephoto lens cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the wide lens camera cable: adım 25, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Disconnect the wide lens camera cable: adım 25, 2 resimden 2.
    • Use a spudger to disconnect the wide lens cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 14 Pro Rear Camera Assembly Replacement, Pry up the rear camera assembly: adım 26, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Pry up the rear camera assembly: adım 26, 2 resimden 2.
    • Insert the pointed end of a spudger underneath the bottom edge of the rear camera assembly.
    • Pry up with the spudger to loosen the rear camera assembly.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly: adım 27, 2 resimden 1. iPhone 14 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly: adım 27, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the rear camera assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
11 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
261.293 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.364 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 151
Son 30 gün: 714
Her zaman: 26,035
