Ana içeriğe geç
iPhone 14 Rear Glass Replacement
Neye ihtiyacın var
  1. iPhone 14 Rear Glass Replacement, Remove the pentalobe screws: adım 1, 2 resimden 1. iPhone 14 Rear Glass Replacement, Remove the pentalobe screws: adım 1, 2 resimden 2.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Rear Glass Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 14 Rear Glass Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 14 Rear Glass Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 14 Rear Glass Replacement, Tape over any cracks: adım 3, 2 resimden 1. iPhone 14 Rear Glass Replacement, Tape over any cracks: adım 3, 2 resimden 2.
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Rear Glass Replacement, Heat the bottom edge: adım 4, 1 resimden 1.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  5. iPhone 14 Rear Glass Replacement, Insert an opening pick: adım 5, 3 resimden 1. iPhone 14 Rear Glass Replacement, Insert an opening pick: adım 5, 3 resimden 2. iPhone 14 Rear Glass Replacement, Insert an opening pick: adım 5, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 Rear Glass Replacement, Heat the left edge: adım 6, 1 resimden 1.
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  7. iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: adım 7, 3 resimden 1. iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: adım 7, 3 resimden 2. iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: adım 7, 3 resimden 3.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  8. iPhone 14 Rear Glass Replacement, Rear glass information: adım 8, 1 resimden 1.
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  9. iPhone 14 Rear Glass Replacement, Heat the right edge: adım 9, 1 resimden 1.
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the volume buttons) for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: adım 10, 3 resimden 1. iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: adım 10, 3 resimden 2. iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: adım 10, 3 resimden 3.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  11. iPhone 14 Rear Glass Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  12. iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: adım 12, 3 resimden 1. iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: adım 12, 3 resimden 2. iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: adım 12, 3 resimden 3.
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  13. iPhone 14 Rear Glass Replacement: adım 13, 3 resimden 1. iPhone 14 Rear Glass Replacement: adım 13, 3 resimden 2. iPhone 14 Rear Glass Replacement: adım 13, 3 resimden 3.
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  14. iPhone 14 Rear Glass Replacement, Open the iPhone: adım 14, 3 resimden 1. iPhone 14 Rear Glass Replacement, Open the iPhone: adım 14, 3 resimden 2. iPhone 14 Rear Glass Replacement, Open the iPhone: adım 14, 3 resimden 3.
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  15. iPhone 14 Rear Glass Replacement, Unfasten the battery connector cover screws: adım 15, 2 resimden 1. iPhone 14 Rear Glass Replacement, Unfasten the battery connector cover screws: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $16.96
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  16. iPhone 14 Rear Glass Replacement, Remove the battery connector cover: adım 16, 3 resimden 1. iPhone 14 Rear Glass Replacement, Remove the battery connector cover: adım 16, 3 resimden 2. iPhone 14 Rear Glass Replacement, Remove the battery connector cover: adım 16, 3 resimden 3.
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  17. iPhone 14 Rear Glass Replacement, Disconnect the battery: adım 17, 2 resimden 1. iPhone 14 Rear Glass Replacement, Disconnect the battery: adım 17, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone 14 Rear Glass Replacement, Unfasten the charging coil connector cover screw: adım 18, 2 resimden 1. iPhone 14 Rear Glass Replacement, Unfasten the charging coil connector cover screw: adım 18, 2 resimden 2.
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  19. iPhone 14 Rear Glass Replacement, Remove the charging coil connector bracket: adım 19, 2 resimden 1. iPhone 14 Rear Glass Replacement, Remove the charging coil connector bracket: adım 19, 2 resimden 2.
    • Use a pair of tweezers to remove the charging coil connector cover.
  20. iPhone 14 Rear Glass Replacement, Disconnect the charging coil: adım 20, 2 resimden 1. iPhone 14 Rear Glass Replacement, Disconnect the charging coil: adım 20, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  21. iPhone 14 Rear Glass Replacement, Remove the rear glass assembly: adım 21, 2 resimden 1. iPhone 14 Rear Glass Replacement, Remove the rear glass assembly: adım 21, 2 resimden 2.
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
Sonuç
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
33 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
129.274 İtibar
189 adet Kılavuz yazıldı
16Kılavuz Yorumları
Does Ifixit currently offer this part?
Mark Schulze - Yanıt
Dear Mark Schulze, unfortunately not.
Manuel Haeussermann -
After completing this repair, my camera doesn't save flash photos anymore, even though the flash fires and it saves normal photos. Flash photos still save with the original back glass. Anyone else run into this issue?
Rich - Yanıt
Hi Rich, the issue could be caused by a damaged IC (see marked in this image)
Tobias Isakeit -
You need to transfer the charging coil and any parts adhered to the back glass as they are paired.
Sean - Lua Tech -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 176
Son 7 gün: 1,376
Son 30 gün: 5,812
Her zaman: 232,505
