Ana içeriğe geç
iPhone 15 Pro Front Camera Assembly Replacement
Neye ihtiyacın var
  1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: adım 1, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: adım 1, 2 resimden 2.
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 15 Pro Front Camera Assembly Replacement, Heat the bottom edge: adım 5, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 15 Pro Front Camera Assembly Replacement, Screen information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 15 Pro Front Camera Assembly Replacement, Heat the right edge: adım 9, 1 resimden 1.
    • Heat the right edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: adım 10, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: adım 10, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: adım 10, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: adım 11, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: adım 11, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: adım 11, 3 resimden 3.
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: adım 12, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: adım 12, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: adım 12, 3 resimden 3.
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 15 Pro Front Camera Assembly Replacement, Heat the top edge: adım 13, 1 resimden 1.
    • Heat the top edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 15 Pro Front Camera Assembly Replacement, Heat the left edge: adım 15, 1 resimden 1.
    • Heat the left edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 3.
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: adım 17, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: adım 17, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: adım 17, 3 resimden 3.
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: adım 18, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: adım 18, 2 resimden 2.
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: adım 19, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: adım 19, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: adım 19, 3 resimden 3.
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: adım 20, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: adım 20, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: adım 20, 3 resimden 3.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: adım 21, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: adım 21, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: adım 22, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: adım 22, 2 resimden 2.
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: adım 23, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: adım 23, 2 resimden 2.
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: adım 24, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: adım 24, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: adım 24, 3 resimden 3.
    • Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
    • The third connector is hidden beneath the top one—lift the top cable slightly to reveal the third connector.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: adım 25, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: adım 25, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
    • One 3.8 mm‑long screw
    • One 3.2 mm‑long screw
    • One 2.8 mm‑long screw
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: adım 26, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: adım 26, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: adım 26, 3 resimden 3.
    • Be careful not to touch or smudge the camera lenses during this step.
    • Insert the point of a spudger between the top right corner of the rear cameras and frame.
    • Pry up until you can grab the rear cameras with your fingers.
    • Remove the rear cameras.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: adım 27, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: adım 27, 2 resimden 2.
    Bu adımda kullanılan alet:
    Standoff Screwdriver for iPhones
    $5.49
    • Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
    • If you don't have a standoff screwdriver, you can use a thin flathead one instead. Apply constant, downward pressure to avoid damaging the shallow notches in the screw head.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: adım 28, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: adım 28, 2 resimden 2.
    • Remove the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: adım 29, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: adım 29, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: adım 29, 3 resimden 3.
    • The microphone cable covers the front sensors press connector.
    • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
    • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: adım 30, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: adım 30, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: adım 30, 3 resimden 3.
    • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 15 Pro Front Camera Assembly Replacement, Remove the front camera assembly: adım 31, 1 resimden 1.
    • Remove the front camera assembly.
    • Be careful not to touch or smudge the camera or sensor lenses.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 15 Pro Front Camera Assembly Replacement, Disassembly complete: adım 32, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: adım 33, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: adım 33, 2 resimden 2.
    • Be careful not to touch or smudge the front camera or sensor lenses.
    • If the replacement cameras include a plastic liner to protect the lenses, keep it in place until just before you reinstall the screen.
    • Use tweezers to align the front camera assembly with its recess in the frame and set it into place.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: adım 34, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: adım 34, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: adım 34, 3 resimden 3.
    • Use your finger or the flat end of a spudger to connect the front camera assembly's press connectors to their sockets on the top edge of the logic board.
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: adım 35, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: adım 35, 2 resimden 2.
    • Use your finger to connect the microphone press connector to its socket on the top left corner of the logic board.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: adım 36, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: adım 36, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: adım 36, 3 resimden 3.
    • Align the gasket on the top right corner of the earpiece speaker with its recess in the frame.
    • Press the gasket into its recess, then lower the earpiece speaker into place.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: adım 37, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: adım 37, 2 resimden 2.
    • Use a Phillips #000 screwdriver to install the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to install the remaining screw securing the bottom left corner of the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: adım 38, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: adım 38, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: adım 38, 3 resimden 3.
    • Be careful not to touch or smudge the camera lenses.
    • Align the rear camera assembly with its recess in the frame and set it into place.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: adım 39, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: adım 39, 2 resimden 2.
    • Use a Phillips #000 screwdriver to install the three screws securing the rear cameras:
    FixBot'a Sor
    Yorum Ekle
  40. iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: adım 40, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: adım 40, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: adım 40, 3 resimden 3.
    • Use the flat end of a spudger to connect the three rear camera press connectors—starting with the black one—to their respective sockets on the logic board.
    FixBot'a Sor
    Yorum Ekle
  41. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: adım 41, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: adım 41, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: adım 41, 3 resimden 3.
    • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  42. iPhone 15 Pro Front Camera Assembly Replacement: adım 42, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement: adım 42, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement: adım 42, 3 resimden 3.
    • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
    • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
    • Wipe along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    FixBot'a Sor
    Yorum Ekle
  43. iPhone 15 Pro Front Camera Assembly Replacement, Orient the adhesive: adım 43, 1 resimden 1.
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
    FixBot'a Sor
    Yorum Ekle
  44. iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: adım 44, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: adım 44, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: adım 44, 3 resimden 3.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, set it down along the bottom edge.
    FixBot'a Sor
    Yorum Ekle
  45. iPhone 15 Pro Front Camera Assembly Replacement: adım 45, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement: adım 45, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement: adım 45, 3 resimden 3.
    • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
    FixBot'a Sor
    Yorum Ekle
  46. iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: adım 46, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: adım 46, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: adım 46, 3 resimden 3.
    • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    FixBot'a Sor
    Yorum Ekle
  47. iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: adım 47, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: adım 47, 2 resimden 2.
    • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
    FixBot'a Sor
    Yorum Ekle
  48. iPhone 15 Pro Front Camera Assembly Replacement, Adhesive information: adım 48, 1 resimden 1.
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
    FixBot'a Sor
    Yorum Ekle
  49. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: adım 49, 1 resimden 1.
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    FixBot'a Sor
    Yorum Ekle
  50. iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: adım 50, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: adım 50, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: adım 50, 3 resimden 3.
    • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
    FixBot'a Sor
    Yorum Ekle
  51. iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: adım 51, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: adım 51, 2 resimden 2.
    • Use your finger or the flat end of a spudger to connect the battery press connector.
    FixBot'a Sor
    Yorum Ekle
  52. iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: adım 52, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: adım 52, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: adım 52, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  53. iPhone 15 Pro Front Camera Assembly Replacement, Fasten the logic board cover: adım 53, 1 resimden 1.
    • Use a Y000 screwdriver to install the six screws securing the logic board cover:
    FixBot'a Sor
    Yorum Ekle
  54. iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: adım 54, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: adım 54, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: adım 54, 3 resimden 3.
    • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
    • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
    FixBot'a Sor
    Yorum Ekle
  55. iPhone 15 Pro Front Camera Assembly Replacement: adım 55, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement: adım 55, 2 resimden 2.
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
    FixBot'a Sor
    Yorum Ekle
  56. iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: adım 56, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: adım 56, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: adım 56, 3 resimden 3.
    • Align the screen over the frame, then lower it into place.
    FixBot'a Sor
    Yorum Ekle
  57. iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: adım 57, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: adım 57, 2 resimden 2.
    • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
    FixBot'a Sor
    Yorum Ekle
  58. iPhone 15 Pro Front Camera Assembly Replacement, Install the pentalobe screws: adım 58, 1 resimden 1.
    • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
  59. iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: adım 59, 2 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: adım 59, 2 resimden 2.
    • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
    FixBot'a Sor
    Yorum Ekle
  60. iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: adım 60, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: adım 60, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: adım 60, 3 resimden 3.
    • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the iPhone's original box, take the lid and place it on a flat surface.
    • If you don't have the original box, skip this step for an alternate method.
    • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
    • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes, ideally overnight.
    FixBot'a Sor
    Yorum Ekle
  61. iPhone 15 Pro Front Camera Assembly Replacement: adım 61, 3 resimden 1. iPhone 15 Pro Front Camera Assembly Replacement: adım 61, 3 resimden 2. iPhone 15 Pro Front Camera Assembly Replacement: adım 61, 3 resimden 3.
    • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    FixBot'a Sor
    Yorum Ekle
  62. iPhone 15 Pro Front Camera Assembly Replacement: adım 62, 1 resimden 1.
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Congratulations on replacing the front camera assembly!
After your repair, depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
2 farklı kişi bu kılavuzu tamamladı.
Spencer Day
196.911 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
1Rehber Yorum
with ios 18, can you use the repair assistant tool to fix faceid? if not is there some sort of device i can use to pair the logic board with the faceid? if not, is my best bet for the front camera and faceid to work again just sending it in to apple for repairs?
Jesse Beckmann - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 87
Son 30 gün: 540
Her zaman: 11,127
