Ana içeriğe geç
iPhone 16 Pro Screen Replacement
Neye ihtiyacın var
  1. iPhone 16 Pro Screen Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 16 Pro Screen Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Pro Screen Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Pro Screen Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Screen Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 16 Pro Screen Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 16 Pro Screen Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Screen Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 16 Pro Screen Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Screen Replacement, Create a gap with a suction handle: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    iOpener
    $12.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Screen Replacement: adım 6, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 6, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Screen Replacement, Screen information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
  8. iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: adım 8, 3 resimden 3.
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Screen Replacement, Heat the left edge: adım 9, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
  10. iPhone 16 Pro Screen Replacement, Separate the left adhesive: adım 10, 2 resimden 1. iPhone 16 Pro Screen Replacement, Separate the left adhesive: adım 10, 2 resimden 2.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: adım 11, 3 resimden 1. iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: adım 11, 3 resimden 2. iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: adım 11, 3 resimden 3.
    • Repeat the heating and slicing procedure along the remaining screen edges.
  12. iPhone 16 Pro Screen Replacement, Swing open the screen: adım 12, 3 resimden 1. iPhone 16 Pro Screen Replacement, Swing open the screen: adım 12, 3 resimden 2. iPhone 16 Pro Screen Replacement, Swing open the screen: adım 12, 3 resimden 3.
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  13. iPhone 16 Pro Screen Replacement, Remove the connector covers: adım 13, 1 resimden 1.
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
  14. iPhone 16 Pro Screen Replacement: adım 14, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 14, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 14, 3 resimden 3.
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
  15. iPhone 16 Pro Screen Replacement: adım 15, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 15, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 15, 3 resimden 3.
  16. iPhone 16 Pro Screen Replacement, Disconnect the screen: adım 16, 2 resimden 1. iPhone 16 Pro Screen Replacement, Disconnect the screen: adım 16, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the display press connector.
  17. iPhone 16 Pro Screen Replacement: adım 17, 2 resimden 1. iPhone 16 Pro Screen Replacement: adım 17, 2 resimden 2.
    • Repeat this process for the front sensor press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  18. iPhone 16 Pro Screen Replacement, Remove the screen: adım 18, 1 resimden 1.
    • Remove the screen.
  19. iPhone 16 Pro Screen Replacement, Disassembly complete: adım 19, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
  20. iPhone 16 Pro Screen Replacement, Remove the adhesive and its residue: adım 20, 2 resimden 1. iPhone 16 Pro Screen Replacement, Remove the adhesive and its residue: adım 20, 2 resimden 2.
    • Use a spudger or tweezers to remove the adhesive chunks from the iPhone's frame.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
  21. iPhone 16 Pro Screen Replacement: adım 21, 1 resimden 1.
    • If you're reinstalling your existing screen, be sure to remove any remaining adhesive from the back of your screen as well.
  22. iPhone 16 Pro Screen Replacement: adım 22, 2 resimden 1. iPhone 16 Pro Screen Replacement: adım 22, 2 resimden 2.
    • Using a lint-free cloth (or coffee filter) and some high concentration (>90%) isopropyl alcohol, clean the areas of the frame and screen where you removed the old adhesive.
    • For best results, swipe your cleaning cloth in one direction, not back and forth.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
  23. iPhone 16 Pro Screen Replacement, Apply the replacement adhesive: adım 23, 1 resimden 1.
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout to visualize how the adhesive will lay in the frame.
  24. iPhone 16 Pro Screen Replacement: adım 24, 1 resimden 1.
    • Grasp the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
  25. iPhone 16 Pro Screen Replacement: adım 25, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 25, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 25, 3 resimden 3.
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of your iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip into place.
  26. iPhone 16 Pro Screen Replacement: adım 26, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 26, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 26, 3 resimden 3.
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
  27. iPhone 16 Pro Screen Replacement: adım 27, 2 resimden 1. iPhone 16 Pro Screen Replacement: adım 27, 2 resimden 2.
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Don't press too hard, or you'll stretch and deform the adhesive.
  28. iPhone 16 Pro Screen Replacement: adım 28, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 28, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 28, 3 resimden 3.
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner—the pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have liners covering the perimeter, which prevent the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
  29. iPhone 16 Pro Screen Replacement, Reconnect the screen: adım 29, 2 resimden 1. iPhone 16 Pro Screen Replacement, Reconnect the screen: adım 29, 2 resimden 2.
    • Use your finger to press down and connect the display connector.
    • To re-attach wide press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Press down and connect the front sensor connector.
    • Align the connector carefully over its socket and press down with your fingertip until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • This is a good time to power on your iPhone and test all functions before you seal it up. Be sure to power your iPhone back down completely before you continue.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
  30. iPhone 16 Pro Screen Replacement, Install the connector covers: adım 30, 2 resimden 1. iPhone 16 Pro Screen Replacement, Install the connector covers: adım 30, 2 resimden 2.
    • Tuck the display connector cover's tab into its frame cutout and lay the cover in place.
    • Repeat with the front sensor connector cover.
  31. iPhone 16 Pro Screen Replacement: adım 31, 1 resimden 1.
    • Use a tri-point Y000 driver to install the two 1.3 mm‑long screws securing the two connector covers.
  32. iPhone 16 Pro Screen Replacement, Remove the final liners: adım 32, 3 resimden 1. iPhone 16 Pro Screen Replacement, Remove the final liners: adım 32, 3 resimden 2. iPhone 16 Pro Screen Replacement, Remove the final liners: adım 32, 3 resimden 3.
    • While supporting the screen, use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • Be careful not to touch the exposed adhesive.
    • Check the frame and screen for any stray liners and remove them. There should be no liners remaining.
  33. iPhone 16 Pro Screen Replacement, Install the screen onto the frame: adım 33, 2 resimden 1. iPhone 16 Pro Screen Replacement, Install the screen onto the frame: adım 33, 2 resimden 2.
    • Carefully align the screen's top clips with their frame cutouts.
  34. iPhone 16 Pro Screen Replacement: adım 34, 3 resimden 1. iPhone 16 Pro Screen Replacement: adım 34, 3 resimden 2. iPhone 16 Pro Screen Replacement: adım 34, 3 resimden 3.
    • Lower the screen onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Make sure the screen edge isn't pinching any cables.
  35. iPhone 16 Pro Screen Replacement, Apply heat to the perimeter: adım 35, 1 resimden 1.
    • Use a hair dryer, heat gun, or an iOpener to heat the screen perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
  36. iPhone 16 Pro Screen Replacement, Apply pressure to the perimeter: adım 36, 2 resimden 1. iPhone 16 Pro Screen Replacement, Apply pressure to the perimeter: adım 36, 2 resimden 2.
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
  37. iPhone 16 Pro Screen Replacement: adım 37, 2 resimden 1. iPhone 16 Pro Screen Replacement: adım 37, 2 resimden 2.
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
  38. iPhone 16 Pro Screen Replacement: adım 38, 2 resimden 1. iPhone 16 Pro Screen Replacement: adım 38, 2 resimden 2.
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
  39. iPhone 16 Pro Screen Replacement, Install the pentalobe screws: adım 39, 2 resimden 1. iPhone 16 Pro Screen Replacement, Install the pentalobe screws: adım 39, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
Sonuç
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Nick Schultz
19.526 İtibar
114 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 215
Son 30 gün: 583
Her zaman: 637
