Ana içeriğe geç
iPhone 16 Screen Replacement
Neye ihtiyacın var
  1. iPhone 16 Screen Replacement, Before you begin: adım 1, 2 resimden 1. iPhone 16 Screen Replacement, Before you begin: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 16 Screen Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Screen Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 16 Screen Replacement, Remove the pentalobe screws: adım 3, 2 resimden 1. iPhone 16 Screen Replacement, Remove the pentalobe screws: adım 3, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 16 Screen Replacement, Mark your opening picks: adım 4, 3 resimden 1. iPhone 16 Screen Replacement, Mark your opening picks: adım 4, 3 resimden 2. iPhone 16 Screen Replacement, Mark your opening picks: adım 4, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 16 Screen Replacement, Heat the bottom edge: adım 5, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 16 Screen Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone 16 Screen Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone 16 Screen Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 16 Screen Replacement, Screen information: adım 7, 2 resimden 1. iPhone 16 Screen Replacement, Screen information: adım 7, 2 resimden 2.
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
    • Multiple spring contacts around the perimeter of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 16 Screen Replacement, Heat the right edge: adım 8, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the right edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 16 Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 1. iPhone 16 Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 2. iPhone 16 Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 16 Screen Replacement, Heat the top edge: adım 10, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the top edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 16 Screen Replacement, Separate the top adhesive: adım 11, 2 resimden 1. iPhone 16 Screen Replacement, Separate the top adhesive: adım 11, 2 resimden 2.
    • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 16 Screen Replacement, Heat the left edge: adım 12, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 16 Screen Replacement, Separate the left adhesive: adım 13, 2 resimden 1. iPhone 16 Screen Replacement, Separate the left adhesive: adım 13, 2 resimden 2.
    • Don't insert your pick deeper than 3 mm to avoid damaging the screen cables and the spring contacts.
    • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 16 Screen Replacement, Prop up the screen: adım 14, 3 resimden 1. iPhone 16 Screen Replacement, Prop up the screen: adım 14, 3 resimden 2. iPhone 16 Screen Replacement, Prop up the screen: adım 14, 3 resimden 3.
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 16 Screen Replacement, Remove the connector covers: adım 15, 2 resimden 1. iPhone 16 Screen Replacement, Remove the connector covers: adım 15, 2 resimden 2.
    • Use a tri-point Y000 driver to remove the two 0.9 mm‑long screws securing the front sensor and screen connector covers.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 16 Screen Replacement: adım 16, 2 resimden 1. iPhone 16 Screen Replacement: adım 16, 2 resimden 2.
    • Use tweezers, or your fingers, to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
    • Lift the cover out of its slot and remove it.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 16 Screen Replacement: adım 17, 2 resimden 1. iPhone 16 Screen Replacement: adım 17, 2 resimden 2.
    • Use tweezers, or your fingers, to lift the screen connector cover at a slight angle to unhook it from its slot in the logic board.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 16 Screen Replacement, Disconnect the screen: adım 18, 3 resimden 1. iPhone 16 Screen Replacement, Disconnect the screen: adım 18, 3 resimden 2. iPhone 16 Screen Replacement, Disconnect the screen: adım 18, 3 resimden 3.
    • Use the tip of a spudger to pry up and disconnect the screen press connector.
    • Repeat for the front sensor press connector.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 16 Screen Replacement, Remove the screen: adım 19, 1 resimden 1.
    • Lift the screen off the frame and remove it.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: adım 20, 3 resimden 1. iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: adım 20, 3 resimden 2. iPhone 16 Screen Replacement, Remove the ambient light sensor bracket: adım 20, 3 resimden 3.
    • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
    • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 16 Screen Replacement, Pry up the ambient light sensor: adım 21, 3 resimden 1. iPhone 16 Screen Replacement, Pry up the ambient light sensor: adım 21, 3 resimden 2. iPhone 16 Screen Replacement, Pry up the ambient light sensor: adım 21, 3 resimden 3.
    • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
    • Use an opening pick to pry up the ambient light sensor.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 16 Screen Replacement, Reposition the ambient light sensor cable: adım 22, 2 resimden 1. iPhone 16 Screen Replacement, Reposition the ambient light sensor cable: adım 22, 2 resimden 2.
    • Use your finger to push the ambient light sensor away from its recess.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 16 Screen Replacement, Peel up the ambient light sensor cable: adım 23, 2 resimden 1. iPhone 16 Screen Replacement, Peel up the ambient light sensor cable: adım 23, 2 resimden 2.
    • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving to the opposite corner.
    • If the adhesive doesn't peel up easily, apply more heat.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 16 Screen Replacement, Remove the ambient light sensor: adım 24, 3 resimden 1. iPhone 16 Screen Replacement, Remove the ambient light sensor: adım 24, 3 resimden 2. iPhone 16 Screen Replacement, Remove the ambient light sensor: adım 24, 3 resimden 3.
    • Continue slowly sliding the opening pick under the ambient light sensor cable until the cable is free from the screen.
    • Use a pair of tweezers to lift the ambient light sensor off of the screen.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 16 Screen Replacement, End of disassembly: adım 25, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 16 Screen Replacement, Place the ambient light sensor: adım 26, 3 resimden 1. iPhone 16 Screen Replacement, Place the ambient light sensor: adım 26, 3 resimden 2. iPhone 16 Screen Replacement, Place the ambient light sensor: adım 26, 3 resimden 3.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $2.95
    • Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to press the ambient light sensor into its recess.
    • Lay the ambient light sensor cable down on the back of the screen.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 16 Screen Replacement, Press the ambient light sensor: adım 27, 3 resimden 1. iPhone 16 Screen Replacement, Press the ambient light sensor: adım 27, 3 resimden 2. iPhone 16 Screen Replacement, Press the ambient light sensor: adım 27, 3 resimden 3.
    • Use your finger to press down the ambient light sensor cable.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 16 Screen Replacement, Install the ambient light sensor bracket: adım 28, 3 resimden 1. iPhone 16 Screen Replacement, Install the ambient light sensor bracket: adım 28, 3 resimden 2. iPhone 16 Screen Replacement, Install the ambient light sensor bracket: adım 28, 3 resimden 3.
    • Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
    • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 16 Screen Replacement, Remove the screen adhesive: adım 29, 3 resimden 1. iPhone 16 Screen Replacement, Remove the screen adhesive: adım 29, 3 resimden 2. iPhone 16 Screen Replacement, Remove the screen adhesive: adım 29, 3 resimden 3.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up the phone. Connect the screen, power on the phone, and make sure it works as expected. Power it back down, disconnect the screen, and continue reassembly.
    • The adhesive remaining on the phone's frame can be difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 16 Screen Replacement: adım 30, 3 resimden 1. iPhone 16 Screen Replacement: adım 30, 3 resimden 2. iPhone 16 Screen Replacement: adım 30, 3 resimden 3.
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 16 Screen Replacement, Orient the adhesive: adım 31, 2 resimden 1. iPhone 16 Screen Replacement, Orient the adhesive: adım 31, 2 resimden 2.
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 16 Screen Replacement, Expose the bottom edge of the adhesive: adım 32, 2 resimden 1. iPhone 16 Screen Replacement, Expose the bottom edge of the adhesive: adım 32, 2 resimden 2.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 16 Screen Replacement, Apply the adhesive: adım 33, 3 resimden 1. iPhone 16 Screen Replacement, Apply the adhesive: adım 33, 3 resimden 2. iPhone 16 Screen Replacement, Apply the adhesive: adım 33, 3 resimden 3.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 16 Screen Replacement: adım 34, 3 resimden 1. iPhone 16 Screen Replacement: adım 34, 3 resimden 2. iPhone 16 Screen Replacement: adım 34, 3 resimden 3.
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 16 Screen Replacement, Press the adhesive into place: adım 35, 3 resimden 1. iPhone 16 Screen Replacement, Press the adhesive into place: adım 35, 3 resimden 2. iPhone 16 Screen Replacement, Press the adhesive into place: adım 35, 3 resimden 3.
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 16 Screen Replacement, Remove the top liner: adım 36, 3 resimden 1. iPhone 16 Screen Replacement, Remove the top liner: adım 36, 3 resimden 2. iPhone 16 Screen Replacement, Remove the top liner: adım 36, 3 resimden 3.
    • Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
    • Peel back the top liner and remove it.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 16 Screen Replacement: adım 37, 2 resimden 1. iPhone 16 Screen Replacement: adım 37, 2 resimden 2.
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 16 Screen Replacement, Prop up the screen: adım 38, 1 resimden 1.
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 16 Screen Replacement, Connect the screen and front sensor: adım 39, 3 resimden 1. iPhone 16 Screen Replacement, Connect the screen and front sensor: adım 39, 3 resimden 2. iPhone 16 Screen Replacement, Connect the screen and front sensor: adım 39, 3 resimden 3.
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
    FixBot'a Sor
    Yorum Ekle
  40. iPhone 16 Screen Replacement, Cover the connectors: adım 40, 2 resimden 1. iPhone 16 Screen Replacement, Cover the connectors: adım 40, 2 resimden 2.
    • Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
    FixBot'a Sor
    Yorum Ekle
  41. iPhone 16 Screen Replacement: adım 41, 2 resimden 1. iPhone 16 Screen Replacement: adım 41, 2 resimden 2.
    • Use a pair of tweezers or your fingers to place the front sensor connector cover over the front sensor connector by inserting it at a 90‑degree angle to engage the hook, then laying the cover flat over the connector.
    FixBot'a Sor
    Yorum Ekle
  42. iPhone 16 Screen Replacement, Install the cover screws: adım 42, 2 resimden 1. iPhone 16 Screen Replacement, Install the cover screws: adım 42, 2 resimden 2.
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    FixBot'a Sor
    Yorum Ekle
  43. iPhone 16 Screen Replacement, Remove the final adhesive liners: adım 43, 3 resimden 1. iPhone 16 Screen Replacement, Remove the final adhesive liners: adım 43, 3 resimden 2. iPhone 16 Screen Replacement, Remove the final adhesive liners: adım 43, 3 resimden 3.
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  44. iPhone 16 Screen Replacement: adım 44, 3 resimden 1. iPhone 16 Screen Replacement: adım 44, 3 resimden 2. iPhone 16 Screen Replacement: adım 44, 3 resimden 3.
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
    FixBot'a Sor
    Yorum Ekle
  45. iPhone 16 Screen Replacement, Place the screen: adım 45, 2 resimden 1. iPhone 16 Screen Replacement, Place the screen: adım 45, 2 resimden 2.
    • Align the screen over the frame, then lower it into place.
    FixBot'a Sor
    Yorum Ekle
  46. iPhone 16 Screen Replacement: adım 46, 2 resimden 1. iPhone 16 Screen Replacement: adım 46, 2 resimden 2.
    • Firmly press the top edge of the screen into the adhesive, then the bottom edge, until the screen is fully seated in the frame.
    FixBot'a Sor
    Yorum Ekle
  47. iPhone 16 Screen Replacement, Heat the screen: adım 47, 2 resimden 1. iPhone 16 Screen Replacement, Heat the screen: adım 47, 2 resimden 2.
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the screen.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    FixBot'a Sor
    Yorum Ekle
  48. iPhone 16 Screen Replacement, Press the back glass: adım 48, 3 resimden 1. iPhone 16 Screen Replacement, Press the back glass: adım 48, 3 resimden 2. iPhone 16 Screen Replacement, Press the back glass: adım 48, 3 resimden 3.
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    FixBot'a Sor
    Yorum Ekle
  49. iPhone 16 Screen Replacement: adım 49, 2 resimden 1. iPhone 16 Screen Replacement: adım 49, 2 resimden 2.
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    FixBot'a Sor
    Yorum Ekle
  50. iPhone 16 Screen Replacement: adım 50, 3 resimden 1. iPhone 16 Screen Replacement: adım 50, 3 resimden 2. iPhone 16 Screen Replacement: adım 50, 3 resimden 3.
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    FixBot'a Sor
    Yorum Ekle
  51. iPhone 16 Screen Replacement: adım 51, 1 resimden 1.
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    FixBot'a Sor
    Yorum Ekle
  52. iPhone 16 Screen Replacement, Install the pentalobe screws: adım 52, 2 resimden 1. iPhone 16 Screen Replacement, Install the pentalobe screws: adım 52, 2 resimden 2.
    • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
13 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
244.856 İtibar
1.203 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.236 adet Kılavuz yazıldı
3Kılavuz Yorumları
i am impressed that apple FINALLY caved for better repair support on right-to-repair and RCS. worked great on my iphone 16 for much cheaper than the appple store was offering. also first comment.
renny putansu - Yanıt Paylaş
My Apple Store claims they don’t have permission to replace screens on iphone16 yet? Do you know when this will be resolved?
TJT - Yanıt Paylaş
If it is not an original iPhone 16 display, does Repair Assistant work without any problems?
Hans - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 84
Son 7 gün: 621
Son 30 gün: 3,239
Her zaman: 44,075
