Ana içeriğe geç
iPhone 17e Taptic Engine Replacement
Neye ihtiyacın var
  1. iPhone 17e Taptic Engine Replacement, Before you begin: adım 1, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Before you begin: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power button and either volume button, then slide to power off your phone.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 17e Taptic Engine Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 17e Taptic Engine Replacement, Remove the pentalobe screws: adım 3, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the pentalobe screws: adım 3, 2 resimden 2.
    • Use a pentalobe P2 screwdriver to remove the two 7.8 mm‑long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 17e Taptic Engine Replacement, Mark your opening picks: adım 4, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Mark your opening picks: adım 4, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Mark your opening picks: adım 4, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 17e Taptic Engine Replacement, Heat the bottom edge: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the back glass for 90 seconds.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 17e Taptic Engine Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 17e Taptic Engine Replacement, Back glass information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, next to the volume up button.
    • Multiple spring contacts around the perimeter of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 17e Taptic Engine Replacement, Separate the bottom adhesive: adım 8, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Separate the bottom adhesive: adım 8, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Separate the bottom adhesive: adım 8, 3 resimden 3.
    • Slide the opening pick along the bottom of the back glass to separate the adhesive.
    • Leave the opening pick near the bottom left corner.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 17e Taptic Engine Replacement, Heat the left edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back glass for 90 seconds.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 17e Taptic Engine Replacement: adım 10, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 10, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 10, 3 resimden 3.
    • Rotate the opening pick around the bottom left corner and slide it along the left edge to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick near the top left corner.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 17e Taptic Engine Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back glass for 90 seconds.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 17e Taptic Engine Replacement, Separate the top adhesive: adım 12, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Separate the top adhesive: adım 12, 2 resimden 2.
    • Rotate the opening pick around the top left corner and slide it along the top edge to separate the adhesive and release the metal clips.
    • Leave the opening pick in the top right corner.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 17e Taptic Engine Replacement, Heat the right edge: adım 13, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back glass for 90 seconds.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 17e Taptic Engine Replacement, Separate the right adhesive: adım 14, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Separate the right adhesive: adım 14, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Separate the right adhesive: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm to avoid damaging the hidden cable.
    • Rotate the opening pick around the top right corner and slide it along the right edge to separate the remaining adhesive and the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 17e Taptic Engine Replacement: adım 15, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 15, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 15, 3 resimden 3.
    • Your back glass adhesive should now be completely separated. If it isn't, slide your opening pick around the back glass to separate any remaining adhesive.
    • Swing open the back glass to the right of the phone and support it upright on a clean, sturdy object.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 17e Taptic Engine Replacement, Remove the lower connector cover screws: adım 16, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the lower connector cover screws: adım 16, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the two 1.3 mm‑long screws securing the lower connector cover.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 17e Taptic Engine Replacement, Remove the lower connector cover: adım 17, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the lower connector cover: adım 17, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Remove the lower connector cover: adım 17, 3 resimden 3.
    • Use tweezers or your fingers to lift the lower connector cover and slide it toward the top of the phone to release it from its metal clip.
    • Remove the lower connector cover.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 17e Taptic Engine Replacement, Disconnect the battery: adım 18, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Disconnect the battery: adım 18, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 17e Taptic Engine Replacement, Remove the middle connector cover screw: adım 19, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the middle connector cover screw: adım 19, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the middle connector cover.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 17e Taptic Engine Replacement, Remove the middle connector cover: adım 20, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the middle connector cover: adım 20, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Remove the middle connector cover: adım 20, 3 resimden 3.
    • The middle connector cover is slotted into two metal clips on the top and bottom.
    • Use the point of a spudger to push the middle connector cover towards the bottom of the phone to release its clips.
    • Use tweezers or your fingers to remove the cover.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 17e Taptic Engine Replacement, Disconnect the wireless charging coil: adım 21, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Disconnect the wireless charging coil: adım 21, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 17e Taptic Engine Replacement, Remove the back glass: adım 22, 1 resimden 1.
    • Lift the back glass off the frame and remove it.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine connector cover screws: adım 23, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine connector cover screws: adım 23, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 2.2 mm‑long screws securing the Taptic Engine connector cover.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine connector cover: adım 24, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine connector cover: adım 24, 2 resimden 2.
    • Use tweezers or your fingers to remove the Taptic Engine connector cover.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 17e Taptic Engine Replacement, Disconnect the Taptic Engine: adım 25, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Disconnect the Taptic Engine: adım 25, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the Taptic Engine press connector.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine screw: adım 26, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine screw: adım 26, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 2.1 mm‑long screw securing the Taptic Engine.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine: adım 27, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine: adım 27, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Remove the Taptic Engine: adım 27, 3 resimden 3.
    • Use the tip of a spudger to lift the Taptic Engine out of the frame until you can grip it with your fingers.
    • Remove the Taptic Engine.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 17e Taptic Engine Replacement, End of disassembly: adım 28, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 17e Taptic Engine Replacement, Place the Taptic Engine: adım 29, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Place the Taptic Engine: adım 29, 2 resimden 2.
    • Place the Taptic Engine into its slot in the frame.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 17e Taptic Engine Replacement, Install the Taptic Engine screw: adım 30, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Install the Taptic Engine screw: adım 30, 2 resimden 2.
    • Use a Phillips screwdriver to install the 2.1 mm‑long screw securing the Taptic Engine.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 17e Taptic Engine Replacement, Connect the Taptic Engine: adım 31, 1 resimden 1.
    • Use the flat end of a spudger to connect the Taptic Engine press connector.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 17e Taptic Engine Replacement, Install the Taptic Engine connector cover: adım 32, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Install the Taptic Engine connector cover: adım 32, 2 resimden 2.
    • Place the cover over the Taptic Engine connector.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 17e Taptic Engine Replacement: adım 33, 2 resimden 1. iPhone 17e Taptic Engine Replacement: adım 33, 2 resimden 2.
    • Use a Phillips screwdriver to install the two 2.2 mm‑long screws securing the Taptic Engine connector cover.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 17e Taptic Engine Replacement, Remove the residual frame adhesive: adım 34, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the residual frame adhesive: adım 34, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Remove the residual frame adhesive: adım 34, 3 resimden 3.
    • Use tweezers to remove the adhesive around the perimeter of the frame.
    • You may need to bunch up the adhesive with the point of a spudger before gripping it with tweezers.
    • Use a coffee filter or a lint‑free cloth and high‑concentration isopropyl alcohol (>90%) to clean off any adhesive residue.
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 17e Taptic Engine Replacement, Orient the adhesive: adım 35, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Orient the adhesive: adım 35, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Orient the adhesive: adım 35, 3 resimden 3.
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay in the frame.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 17e Taptic Engine Replacement, Apply the adhesive: adım 36, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Apply the adhesive: adım 36, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Apply the adhesive: adım 36, 3 resimden 3.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 17e Taptic Engine Replacement: adım 37, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 37, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 37, 3 resimden 3.
    • Continue peeling the back liner off the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 17e Taptic Engine Replacement, Press the adhesive into place: adım 38, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Press the adhesive into place: adım 38, 2 resimden 2.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 17e Taptic Engine Replacement: adım 39, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 39, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 39, 3 resimden 3.
    • Use the tip of a spudger to lift up the pull tab on the top right corner of the pink adhesive liner until you can grip it with your fingers.
    FixBot'a Sor
    Yorum Ekle
  40. iPhone 17e Taptic Engine Replacement: adım 40, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 40, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 40, 3 resimden 3.
    • Use the pull tab to peel the pink liner off the frame and expose the secondary blue liners.
    FixBot'a Sor
    Yorum Ekle
  41. iPhone 17e Taptic Engine Replacement, Connect the press connectors: adım 41, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Connect the press connectors: adım 41, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Connect the press connectors: adım 41, 3 resimden 3.
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the glass.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector, then the battery press connector.
    FixBot'a Sor
    Yorum Ekle
  42. iPhone 17e Taptic Engine Replacement, Place the middle connector cover: adım 42, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Place the middle connector cover: adım 42, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Place the middle connector cover: adım 42, 3 resimden 3.
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
    FixBot'a Sor
    Yorum Ekle
  43. iPhone 17e Taptic Engine Replacement: adım 43, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 43, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 43, 3 resimden 3.
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
    FixBot'a Sor
    Yorum Ekle
  44. iPhone 17e Taptic Engine Replacement, Place the lower connector cover: adım 44, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Place the lower connector cover: adım 44, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Place the lower connector cover: adım 44, 3 resimden 3.
    • Use tweezers to place the top of the lower connector cover over its slot in the logic board.
    • Lay the lower connector cover over the press connector.
    FixBot'a Sor
    Yorum Ekle
  45. iPhone 17e Taptic Engine Replacement, Install the cover screws: adım 45, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Install the cover screws: adım 45, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
    FixBot'a Sor
    Yorum Ekle
  46. iPhone 17e Taptic Engine Replacement, Remove the final liners: adım 46, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Remove the final liners: adım 46, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Remove the final liners: adım 46, 3 resimden 3.
    • Use tweezers to grip the pull tabs on the three blue liners and peel them off to expose the adhesive.
    • You may need to hold the back glass above the frame without it touching the adhesive to remove the liner along the right edge.
    FixBot'a Sor
    Yorum Ekle
  47. iPhone 17e Taptic Engine Replacement, Place the back glass: adım 47, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Place the back glass: adım 47, 2 resimden 2.
    • Hold the back glass above the phone and align it with the frame.
    FixBot'a Sor
    Yorum Ekle
  48. iPhone 17e Taptic Engine Replacement: adım 48, 2 resimden 1. iPhone 17e Taptic Engine Replacement: adım 48, 2 resimden 2.
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
    FixBot'a Sor
    Yorum Ekle
  49. iPhone 17e Taptic Engine Replacement, Heat the back glass: adım 49, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Heat the back glass: adım 49, 2 resimden 2.
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
    FixBot'a Sor
    Yorum Ekle
  50. iPhone 17e Taptic Engine Replacement, Press the back glass: adım 50, 3 resimden 1. iPhone 17e Taptic Engine Replacement, Press the back glass: adım 50, 3 resimden 2. iPhone 17e Taptic Engine Replacement, Press the back glass: adım 50, 3 resimden 3.
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    FixBot'a Sor
    Yorum Ekle
  51. iPhone 17e Taptic Engine Replacement: adım 51, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 51, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 51, 3 resimden 3.
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    FixBot'a Sor
    Yorum Ekle
  52. iPhone 17e Taptic Engine Replacement: adım 52, 3 resimden 1. iPhone 17e Taptic Engine Replacement: adım 52, 3 resimden 2. iPhone 17e Taptic Engine Replacement: adım 52, 3 resimden 3.
    • Place one layer of coins or similarly thick objects on the tape along the edges of the back glass.
    • Depending on the thickness of the coins, you might need multiple layers.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    FixBot'a Sor
    Yorum Ekle
  53. iPhone 17e Taptic Engine Replacement: adım 53, 1 resimden 1.
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    FixBot'a Sor
    Yorum Ekle
  54. iPhone 17e Taptic Engine Replacement, Install the pentalobe screws: adım 54, 2 resimden 1. iPhone 17e Taptic Engine Replacement, Install the pentalobe screws: adım 54, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to install the two 7.8 mm‑long screws on either side of the charging port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
After your repair, calibrate the new Taptic Engine using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 17e Answers Community for help.
Nick Schultz
58.401 İtibar
316 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 98
Her zaman: 341
