Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Sökme işlemine başlamadan önce iPhone'unuzu kapatın.
Tercümeyi buraya girin
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Bu adımda kullanılan alet:Anti-Clamp$24.95-
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the screen.
Bu adımda kullanılan alet:Tweezers$4.99-
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
Remove the metal battery connector bracket from the iPhone.
Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
One 1.7 mm Phillips #000 screw
One 1.2 mm Phillips #000 screw
One 1.3 mm Phillips #000 screw
One more 1.7 mm Phillips #000 screw
Remove the front panel assembly cable bracket from the logic board.
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray. This may require a significant amount of force.
Use a spudger to gently pry the button assembly cable up from its socket on the logic board.
Use a spudger to pry the Lightning connector cable up from its socket on the logic board.
Fold the Lightning connector cable out of the way of the logic board.
Use the tip of a spudger to pry the antenna cable up from its socket on the logic board.
Use the flat end of a spudger to disconnect the rear-facing camera cable from its socket on the logic board.
Bu adımda kullanılan alet:Standoff Screwdriver for iPhones$5.49-
Remove the following screws from the logic board:
One 2.4 mm Phillips #000 screw
Two 2.3 mm Phillips #000 screws
Four 2.8 mm standoff screws
Use a plastic opening tool to lift the logic board up enough to grab with your fingers.
Pull the logic board slightly away from the rear facing camera.
Flip the logic board toward the battery, as if you are turning the page in a book.
Use the flat end of a spudger to disconnect the antenna cable on the back of the logic board.
Remove the logic board from the iPhone.
At this point, a small metal plate near the rear facing camera is loose and may come free from its recess.
Use tweezers to remove the plate from beneath the bracket to the left of the rear-facing camera.
Using a pair of tweezers, flip the rubber camera cover out of its clip and toward the outside of the rear case.
Remove the two 1.6 mm Phillips #000 screws securing the rear-facing camera bracket.
Remove the rear-facing camera bracket from the rear case.
Insert the tip of a spudger into the hole in the battery adhesive tab near the headphone jack.
Lift the tab up slightly and use the spudger to unfold the tab from its recess.
Pull the battery adhesive tab straight up from the phone.
Cut the black battery adhesive tab between the two white adhesive strips, separating them.
Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
Guide the strip carefully around the corner and up the side of the battery.
Repeat to remove the second adhesive strip.
If you removed both strips successfully, skip the next two steps.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Bu adımda kullanılan alet:Plastic Cards$2.99-
Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
Press the card in farther to break up the adhesive behind the battery.
Remove the following Phillips #000 screws from the vibrator bracket:
One 1.7 mm screw
One 2.5 mm screw
With a set of tweezers, remove the vibrator bracket.
Remove the 1.7 mm Phillips #000 screw securing the vibrator to the rear case.
Use a set of tweezers to remove the vibrator from the rear case.
Gently peel the vibrator contact pad portion of the upper cable assembly off of the bluetooth and wi-fi antenna.
Carefully pry the bluetooth and wi-fi antenna up off of the adhesive holding it to the rear case.
Remove the bluetooth and wi-fi antenna.
46 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Followed this guide, after reassembly
my flash, front and rear camera have stopped working. Anyone got any ideas why?
cheers
gary
If they worked before changing the antenna may be that they are barely seated, try reconnecting the cameras and see if the FPC connector is well embedded
Thanks for this guide.
I just replaced the battery using a different guide but broke the bluetooth and wi-fi antenna. The new battery works but I am reluctant to remove it because it was that process that caused the damage. Albeit more difficult, but is it still possible to replace the bluetooth and wi-fi antenna without removing the battery?
Regards.
