Ana içeriğe geç
iPhone 6 Home Button Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iPhone 6 Home Button Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 6 Home Button Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. iPhone 6 Home Button Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. iPhone 6 Home Button Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 6 Home Button Replacement: adım 3, 3 resimden 1. iPhone 6 Home Button Replacement: adım 3, 3 resimden 2. iPhone 6 Home Button Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 6 Home Button Replacement, Manual Opening Procedure: adım 4, 1 resimden 1.
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 6 Home Button Replacement: adım 5, 1 resimden 1.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 6 Home Button Replacement: adım 6, 2 resimden 1. iPhone 6 Home Button Replacement: adım 6, 2 resimden 2.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 6 Home Button Replacement, Opening up the phone: adım 7, 3 resimden 1. iPhone 6 Home Button Replacement, Opening up the phone: adım 7, 3 resimden 2. iPhone 6 Home Button Replacement, Opening up the phone: adım 7, 3 resimden 3.
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 6 Home Button Replacement: adım 8, 3 resimden 1. iPhone 6 Home Button Replacement: adım 8, 3 resimden 2. iPhone 6 Home Button Replacement: adım 8, 3 resimden 3.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 6 Home Button Replacement, Removing the battery connector bracket screws: adım 9, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 6 Home Button Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 6 Home Button Replacement, Disconnecting the battery connector: adım 11, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 6 Home Button Replacement, Removing the front panel assembly cable bracket screws: adım 12, 1 resimden 1.
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 6 Home Button Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 6 Home Button Replacement: adım 14, 2 resimden 1. iPhone 6 Home Button Replacement: adım 14, 2 resimden 2.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 6 Home Button Replacement: adım 15, 2 resimden 1. iPhone 6 Home Button Replacement: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the home button cable connector.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 6 Home Button Replacement: adım 16, 2 resimden 1. iPhone 6 Home Button Replacement: adım 16, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 6 Home Button Replacement: adım 17, 2 resimden 1. iPhone 6 Home Button Replacement: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 6 Home Button Replacement, Separating front panel assembly and rear case: adım 18, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 6 Home Button Replacement, Home Button: adım 19, 1 resimden 1.
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 6 Home Button Replacement: adım 20, 2 resimden 1. iPhone 6 Home Button Replacement: adım 20, 2 resimden 2.
    • Remove the home button bracket from the front panel.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 6 Home Button Replacement: adım 21, 2 resimden 1. iPhone 6 Home Button Replacement: adım 21, 2 resimden 2.
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 6 Home Button Replacement: adım 22, 2 resimden 1. iPhone 6 Home Button Replacement: adım 22, 2 resimden 2.
    iOpener
    $24.95
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 6 Home Button Replacement: adım 23, 2 resimden 1. iPhone 6 Home Button Replacement: adım 23, 2 resimden 2.
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 6 Home Button Replacement: adım 24, 2 resimden 1. iPhone 6 Home Button Replacement: adım 24, 2 resimden 2.
    iOpener
    $14.95
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 6 Home Button Replacement: adım 25, 1 resimden 1.
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 6 Home Button Replacement, Home Button: adım 26, 3 resimden 1. iPhone 6 Home Button Replacement, Home Button: adım 26, 3 resimden 2. iPhone 6 Home Button Replacement, Home Button: adım 26, 3 resimden 3.
    • Depending on your replacement part, you may need to remove the rubber gasket around your home button.
    • Use a set of tweezers to carefully pull the gasket up from the home button.
    • Be careful not to snag the gasket on the home button cable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
394 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.364 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.810 adet Kılavuz yazıldı
69Kılavuz Yorumları
is this the original home button?
costasefth23 - Yanıt Paylaş
My home button doesnt working while my touch id is working fine. I ask this repair shop he said , if u get this phone repaired, ur touch id wont working. How can i settle this down with free risk
sufian ahmad - Yanıt Paylaş
جهاز أيفون 6 البصمة تخرب بسرعة
Abdulaziz Alhammad - Yanıt Paylaş
You can't update your phone when you don't have the original home button, any solutions?
brampeeters122 - Yanıt Paylaş
I work at an Apple repair centre in based in the UK and we have recently encountered MAJOR issues with replacement home buttons. It turns out that home buttons are linked too the logic board on each handset due to the method in which Apple stores you biometric data. Due to this, to the greatest extent of our knowledge, any update (through setting on the phone, updating on the phone, updating through iTunes or resting on iTunes) will cause an ERROR 53 to occur. As of yet we have not be able to rescue a handset from this state. If any body has any further knowledge it would be massively appreciated, as a community we need to get to the bottom of this before anybody had any major disasters.
jakebennettyoung - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 84
Son 30 gün: 364
Her zaman: 627,432
