Ana içeriğe geç
iPhone 6 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. iPhone 6 Rear Facing Camera Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Rear Facing Camera Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. iPhone 6 Rear Facing Camera Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. iPhone 6 Rear Facing Camera Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Clamp
    $24.95
    Satın Al
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Rear Facing Camera Replacement: adım 3, 3 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 3, 3 resimden 2. iPhone 6 Rear Facing Camera Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Rear Facing Camera Replacement, Manual Opening Procedure: adım 4, 1 resimden 1.
    Anti-Clamp
    $24.95
    Satın Al
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Rear Facing Camera Replacement: adım 6, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 6, 2 resimden 2.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Rear Facing Camera Replacement, Opening up the phone: adım 7, 3 resimden 1. iPhone 6 Rear Facing Camera Replacement, Opening up the phone: adım 7, 3 resimden 2. iPhone 6 Rear Facing Camera Replacement, Opening up the phone: adım 7, 3 resimden 3.
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Rear Facing Camera Replacement: adım 8, 3 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 8, 3 resimden 2. iPhone 6 Rear Facing Camera Replacement: adım 8, 3 resimden 3.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Rear Facing Camera Replacement, Removing the battery connector bracket screws: adım 9, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Rear Facing Camera Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Rear Facing Camera Replacement, Disconnecting the battery connector: adım 11, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Rear Facing Camera Replacement, Removing the front panel assembly cable bracket screws: adım 12, 1 resimden 1.
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Rear Facing Camera Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Rear Facing Camera Replacement: adım 14, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 14, 2 resimden 2.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Rear Facing Camera Replacement: adım 15, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Rear Facing Camera Replacement: adım 16, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 16, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Rear Facing Camera Replacement: adım 17, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Rear Facing Camera Replacement, Separating front panel assembly and rear case: adım 18, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Rear Facing Camera Replacement, Rear Facing Camera: adım 19, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement, Rear Facing Camera: adım 19, 2 resimden 2.
    • Remove any tape covering the upper left rear-facing camera screw.
  20. iPhone 6 Rear Facing Camera Replacement: adım 20, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 20, 2 resimden 2.
    • Use the flat end of a spudger to lift the rear-facing camera connector up off of its socket on the logic board.
    • Pry only on the connector, not the socket itself or you risk damaging the logic board.
  21. iPhone 6 Rear Facing Camera Replacement: adım 21, 1 resimden 1.
    • Remove the following Phillips #00 screws from the rear-facing camera bracket:
    • One 1.5 mm screw
    • One 2.1 mm screw
  22. iPhone 6 Rear Facing Camera Replacement: adım 22, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 22, 2 resimden 2.
    • Remove the rear-facing camera bracket.
  23. iPhone 6 Rear Facing Camera Replacement: adım 23, 2 resimden 1. iPhone 6 Rear Facing Camera Replacement: adım 23, 2 resimden 2.
    • Remove the rear-facing camera from the iPhone.
Sonuç
135 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.822 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.146 adet Kılavuz yazıldı
22 Yorum
I replaced both cameras and now my phone won't power on. The apple logo comes on for a few seconds and then disappears. I have checked all the connections many times. What went wrong?
Hershel Weiss - Yanıt
just check battery connection .
otherwise low battery problem
ajmal -
excelente aporte
mygsys - Yanıt
Replaced this and the front-facing camera. Apple had told me that given both front and back were out, that it was a board problem. Incorrect. I successfully replaced the front facing and rear facing camera, and then the flashlight started working again too. Great stuff.
davidvincentiannelli - Yanıt
Wow, what did you do to your iPhone ??
tomwalsh395 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 40
Son 30 gün: 129
Her zaman: 204,365
