Giriş
Use this guide to remove or replace the power (or sleep/wake) button cover in your iPhone 6s. This guide is just for the physical button, and not the electronic switch beneath.
If you need to replace the power button control cable or electronics, follow this guide.
Neye ihtiyacın var
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
Bu adımda kullanılan alet:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the two 2.3 mm Phillips screws securing the upper component cable connector bracket.
Remove the two 1.5 mm Phillips screws holding the Taptic Engine in place.
Remove the Taptic Engine.
Pull one of the adhesive strips straight out, towards the bottom of the iPhone.
For best results, pull the strip at a 60º angle or less.
Continue pulling until the strip is fully removed.
If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then skip to Step 48.
Bu adımda kullanılan alet:Plastic Cards$2.99
If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
If your replacement part did not come with the mute switch cover, you will need to remove the switch cover and transfer It.
Use the flat end of the spudger to press down and hold the old bracket firmly in place.
Use tweezers or your fingers to carefully rock the switch cover such that the switch cover pins swing out of their clips.
Lift the switch cover straight up.
Grasp the metal bar on the back of the power button cover.
Remove the power button cover.
35 farklı kişi bu kılavuzu tamamladı.
