Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Before you begin, it's a good idea to test-fit your new battery in the iPhone.
If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
Peel off the blue plastic liner from your new set of adhesive strips, and discard it.
Double-check the orientation of the adhesive strips, and make sure your battery is still lying face-down (with the connector contacts facing up).
Carefully position the adhesive strips over the battery, and stick them in place as shown.
Use your fingers or a cloth to press the strips firmly into place on the battery.
Press in the center to adhere the black regulatory label to the battery as well.
Roll your fingertip along the edges of the battery to stick down the black pull tab at the end of each adhesive strip.
Peel off and discard the pink liner, fully exposing the adhesive strips.
Carefully position the battery and set it into the iPhone.
Press the battery firmly onto the adhesive strips to secure it in place.
24 farklı kişi bu kılavuzu tamamladı.
