Ana içeriğe geç
iPhone "L-Shaped" Battery Adhesive Strips Replacement
Neye ihtiyacın var
  1. iPhone "L-Shaped" Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: adım 1, 2 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: adım 1, 2 resimden 2.
    • Before you begin, it's a good idea to test-fit your new battery in the iPhone.
    • This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
    • Make sure the battery connector lines up correctly with its socket on the logic board.
    • Be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
  2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 2, 2 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 2, 2 resimden 2.
    • If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
    • If your battery came with new adhesive strips already installed, skip to Step 7.
    • If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
  3. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 3, 3 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 3, 3 resimden 2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 3, 3 resimden 3.
    • Peel off the blue plastic liner from your new set of adhesive strips, and discard it.
    • Some strips have a single large blue liner, while others have a two-piece liner. Either way, peel it all off.
    • Once the adhesive is exposed, be careful not to touch it.
  4. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 4, 2 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 4, 2 resimden 2.
    • Once the adhesive sticks to the battery, you can't peel it off or reposition it—if you make a mistake, you'll have to start over with fresh adhesive strips.
    • Double-check the orientation of the adhesive strips, and make sure your battery is still lying face-down (with the connector contacts facing up).
    • Carefully position the adhesive strips over the battery, and stick them in place as shown.
    • Place the strips slightly off-center, very close to the long edge of the battery.
    • The black pull tabs at each end should protrude equally far over the top and bottom edges of the battery.
  5. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 5, 3 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 5, 3 resimden 2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 5, 3 resimden 3.
    • Use your fingers or a cloth to press the strips firmly into place on the battery.
    • Press in the center to adhere the black regulatory label to the battery as well.
  6. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 6, 3 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 6, 3 resimden 2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 6, 3 resimden 3.
    • Roll your fingertip along the edges of the battery to stick down the black pull tab at the end of each adhesive strip.
    • Be sure to get all four tabs—three on the bottom edge, and one on the top.
  7. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 7, 3 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 7, 3 resimden 2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 7, 3 resimden 3.
    • Peel off and discard the pink liner, fully exposing the adhesive strips.
  8. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 8, 3 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 8, 3 resimden 2. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 8, 3 resimden 3.
    • When installing the battery, be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
    • Carefully position the battery and set it into the iPhone.
    • Make sure the battery connector lines up with its socket on the logic board.
    • It's okay to temporarily connect the battery to make sure it lines up correctly, but make certain it's disconnected before reassembling your iPhone.
  9. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 9, 2 resimden 1. iPhone "L-Shaped" Battery Adhesive Strips Replacement: adım 9, 2 resimden 2.
    • Press the battery firmly onto the adhesive strips to secure it in place.
    • If your battery came with an additional plastic liner on the top, peel it off and discard it before closing up your phone.
Jeff Suovanen
440.370 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 85
Son 30 gün: 479
Her zaman: 29,157
