Ana içeriğe geç
iPhone XS Lower Speaker Replacement
  1. iPhone XS Lower Speaker Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone XS Lower Speaker Replacement, Opening Procedure: adım 2, 1 resimden 1.
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone XS Lower Speaker Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPhone XS Lower Speaker Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPhone XS Lower Speaker Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPhone XS Lower Speaker Replacement: adım 4, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 4, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 4, 3 resimden 3.
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. iPhone XS Lower Speaker Replacement: adım 5, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 5, 2 resimden 2.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone XS Lower Speaker Replacement: adım 6, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 6, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 6, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. iPhone XS Lower Speaker Replacement: adım 7, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 7, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 7, 3 resimden 3.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
  8. iPhone XS Lower Speaker Replacement: adım 8, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 8, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 8, 3 resimden 3.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  9. iPhone XS Lower Speaker Replacement: adım 9, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 9, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 9, 3 resimden 3.
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Again, don't insert the pick more than a few millimeters—about the width of the display bezel—or you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  10. iPhone XS Lower Speaker Replacement: adım 10, 1 resimden 1.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    • If you used an iSclack and it's still affixed to the iPhone, remove it now.
  11. iPhone XS Lower Speaker Replacement: adım 11, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 11, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 11, 3 resimden 3.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    • Remove five screws securing the logic board connector bracket, of the following lengths:
    • Three 1.0 mm Y000 screws
    • One 1.3 mm Y000 screw
    • One 3.7 mm Phillips screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  12. iPhone XS Lower Speaker Replacement: adım 13, 1 resimden 1.
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  13. iPhone XS Lower Speaker Replacement: adım 14, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 14, 2 resimden 2.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  14. iPhone XS Lower Speaker Replacement: adım 15, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to pry up and disconnect the front panel sensor assembly connector.
  15. iPhone XS Lower Speaker Replacement: adım 16, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 16, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. iPhone XS Lower Speaker Replacement: adım 17, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 17, 2 resimden 2.
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  17. iPhone XS Lower Speaker Replacement: adım 18, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 18, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 18, 3 resimden 3.
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  18. iPhone XS Lower Speaker Replacement: adım 19, 1 resimden 1.
  19. iPhone XS Lower Speaker Replacement, Lower Speaker: adım 20, 2 resimden 1. iPhone XS Lower Speaker Replacement, Lower Speaker: adım 20, 2 resimden 2.
    • Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
    • One 1.0 mm tri-point Y000 screw
    • Two 1.3 mm Phillips screws
    • One 1.7 mm Phillips screw
    • One 1.8 mm Phillips screw
  20. iPhone XS Lower Speaker Replacement: adım 21, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 21, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 21, 3 resimden 3.
    • The brackets are lightly adhered in place.
    • Gently lift to unstick and remove each bracket, being careful not to bend it.
    • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
  21. iPhone XS Lower Speaker Replacement: adım 22, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 22, 2 resimden 2.
    • Remove the 1.9 mm Phillips screw securing the speaker connector cover.
  22. iPhone XS Lower Speaker Replacement: adım 23, 1 resimden 1.
    • Remove the speaker connector cover.
  23. iPhone XS Lower Speaker Replacement: adım 24, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 24, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
  24. iPhone XS Lower Speaker Replacement: adım 25, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 25, 2 resimden 2.
    • When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker slightly.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
  25. iPhone XS Lower Speaker Replacement: adım 26, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 26, 2 resimden 2.
    • While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
    • If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
  26. iPhone XS Lower Speaker Replacement: adım 27, 3 resimden 1. iPhone XS Lower Speaker Replacement: adım 27, 3 resimden 2. iPhone XS Lower Speaker Replacement: adım 27, 3 resimden 3.
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  27. iPhone XS Lower Speaker Replacement: adım 28, 2 resimden 1. iPhone XS Lower Speaker Replacement: adım 28, 2 resimden 2.
    • Remove the speaker.
    • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
    • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
405.840 İtibar
258 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
138 Üyeler
17.031 adet Kılavuz yazıldı
2 Comments
hi there need a little help need the bracket part where the five screws go one of the tabs brock on the one i have
william albertson - Yanıt
Had the same problem. One of the little tab / springs was damaged on the bracket below the main speaker. Didn't think it would be that much of an issue until I started using phone. On occasion, pressure on the lower part of screen creates crazy phantom touchscreen activity. Cannot locate a replacement anywhere on the site.
ELLO WEE -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 127
Son 30 gün: 467
Her zaman: 22,116
