Giriş
iPhone XS Max uses both the primary loudspeaker and the earpiece speaker together to produce stereo sound. Use this guide to replace the primary loudspeaker at the bottom of the phone only. Replacing this speaker can help resolve issues such as loss of sound, poor sound quality, and distorted sound.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
besteht da die Gefahr das sich das Displayglas vom lcd löst?
Besteht da die Gefahr das sich der Kleber vom Displayglas löst?
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Comment répare un Face ID XS max
Bonjour @jenkeydany62670 Les capteurs Face ID était appairés à la carte mère en usine, il n'est possible de les remplacer qu'avec une nouvelle "paire". Ou bien, il faut se tourner vers un centre de réparation Apple officiel.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
Two 1.1 mm screws
One 1.5 mm screw
One 3.7 mm screw
Remove the three Y000 screws securing the display connector bracket:
Two 1.5 mm screws
One 1.1 mm screw
I am replacing the screen for the 2nd time - the first repair was done by someone else, and the first 2 screws are 1.5mm and the last screw is 1.1mm… If I put the screw back in am I risking Long Screw Damage?
Thanks for all your comments! I'll amend this step.
Hi, I just changed the screen on my XS Max and for this bracket I used 2 x 1.1 mm and 1 x 1.5 mm.
Starting from left to right:
- left 1.1 mm (I tried with 1.5 mm like in the above picture but I felt that it didn't wanted to go deeper so I didn't forced and I tried it in the middle and it fit perfectly)
- middle 1.5 mm
- right 1.1 mm
For the two brackets I had 7 screws, I aligned them on the desk by length and I had 2 x 1.5 mm, 4 x 1.1 mm and 1 x 3.7 mm.
Good luck and I hope it will help someone!
Carefully lift the cable until the adhesive separates.
Remove the five 1.4 mm tri-point Y000 screws securing the bracket below the Taptic Engine and main speaker.
Remove the speaker.
Welche Dichtung soll hier verwendet werden?
20 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Mijn iphone bodem-speaker maakte af en toe ene krakend geluid of deze viel volledig uit. Ik heb de telefoon naar een reparateur gebracht… maar ook de nieuwe box die is geïnstalleerd doet het alleen als ik druk op het scherm uit-oefen. Het lijkt daardoor dus te komen, doordat de speaker niet of niet goed contact maakt met het punt waar het zijn stroom vandaan haalt. De medewerker van de reparatie-zaak heeft het de hele tijd over kortsluiting? Maar dat lijkt me sterk, daar een beetje druk zowel bij mn oude als de nieuwe speaker resulteert in een werkende box. Echter is dit niet ideaal voor het scherm, en ook niet de ideale oplossing als ik muziek of video’s afspeel. Hebben jullie tips waar het misschien aan kan liggen? Waar de medewerker naar kan kijken? De telefoon is nu al twee dagen bij die winkel met tot op heden nog niet een werkende onderspeaker tot resultaat.
Hopelijk heeft iemand de gouden tip.
Groetjes,
Wes
