Ana içeriğe geç
iRobot Roomba 890 Charging Contacts Replacement
Neye ihtiyacın var
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: adım 1, 2 resimden 1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: adım 1, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: adım 2, 1 resimden 1.
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: adım 3, 1 resimden 1.
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: adım 4, 2 resimden 1. iRobot Roomba 890 Charging Contacts Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: adım 5, 2 resimden 1. iRobot Roomba 890 Charging Contacts Replacement: adım 5, 2 resimden 2.
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: adım 6, 2 resimden 1. iRobot Roomba 890 Charging Contacts Replacement: adım 6, 2 resimden 2.
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: adım 7, 3 resimden 1. iRobot Roomba 890 Charging Contacts Replacement: adım 7, 3 resimden 2. iRobot Roomba 890 Charging Contacts Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: adım 8, 2 resimden 1. iRobot Roomba 890 Charging Contacts Replacement: adım 8, 2 resimden 2.
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: adım 10, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: adım 11, 1 resimden 1.
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 farklı kişi bu kılavuzu tamamladı.
Devin Steiblin
442 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G3
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 46
Son 30 gün: 187
Her zaman: 5,311
