Ana içeriğe geç
why! W650SZ LCD Screen Replacement
Felice Suglia
Felice Suglia
En son August 23, 2022 tarihinde güncellendi
15 dakika
Kolay
Topluluk-Katkılı Kılavuz
Daha iyi giriş
  1. why! W650SZ LCD Screen Replacement, Battery: adım 1, 3 resimden 1. why! W650SZ LCD Screen Replacement, Battery: adım 1, 3 resimden 2. why! W650SZ LCD Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ LCD Screen Replacement, Remove the Bezel: adım 2, 3 resimden 1. why! W650SZ LCD Screen Replacement, Remove the Bezel: adım 2, 3 resimden 2. why! W650SZ LCD Screen Replacement, Remove the Bezel: adım 2, 3 resimden 3.
    • Although the photos are shown without a keyboard, it is not necessary to remove the keyboard to replace the screen.
    • Gently insert your fingernail between the display bezel and the LCD.
  3. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 3, 3 resimden 1. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 3, 3 resimden 2. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 3, 3 resimden 3.
    • Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
  4. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 4, 3 resimden 1. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 4, 3 resimden 2. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): adım 4, 3 resimden 3.
    • Remove the bezel surrounding the LCD.
  5. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: adım 5, 3 resimden 1. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: adım 5, 3 resimden 2. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: adım 5, 3 resimden 3.
    • Remove the two upper mounting screws securing the LCD to the lid.
    • Remove the two lower mounting screws.
  6. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: adım 6, 3 resimden 1. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: adım 6, 3 resimden 2. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: adım 6, 3 resimden 3.
    • Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
  7. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: adım 7, 3 resimden 1. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: adım 7, 3 resimden 2. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: adım 7, 3 resimden 3.
    • Note the location of the LCD screen connector.
  8. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: adım 8, 3 resimden 1. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: adım 8, 3 resimden 2. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: adım 8, 3 resimden 3.
    • Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
  9. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: adım 9, 3 resimden 1. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: adım 9, 3 resimden 2. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: adım 9, 3 resimden 3.
    • Unplug the connector.
    • The LCD screen can now be removed.
Sonuç
Bu çevirmenlere özel teşekkürler:
fr en
100%
Jerry Wheeler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
31.564 İtibar
264 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 209
