Ana içeriğe geç
This teardown will show you all removable components of the Humax IRHD 5000C and how to remove them.
Bu teardown bir tamir kılavuzu değildir. Humax IRHD 5000C cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Humax IRHD 5000C Teardown, open up case: adım 1, 2 resimden 1. Humax IRHD 5000C Teardown, open up case: adım 1, 2 resimden 2.
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: adım 2, 2 resimden 1. Humax IRHD 5000C Teardown, remove power supply: adım 2, 2 resimden 2.
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: adım 3, 2 resimden 1. Humax IRHD 5000C Teardown, remove front: adım 3, 2 resimden 2.
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 1. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 2. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 3.
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: adım 5, 2 resimden 1. Humax IRHD 5000C Teardown, remove mainboard: adım 5, 2 resimden 2.
    • Unscrew the screws and remove the mainboard from the case.
knipwim
11.274 İtibar
36 adet Kılavuz yazıldı
2 Yorum
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - Yanıt
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 1,542
