Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Lightsaber cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Lightsaber Teardown, Lightsaber Teardown: adım 1, 1 resimden 1.
    • Listen up, nerfherders: We've got a lightsaber on the teardown table. Before we dive in, let's take a look at the specs:
    • Manufacturer: Obi-Wan Kenobi
    • Crystal: single blue Adegan crystal
    • Production date: 22 BBY (Before Battle of Yavin)
    • Length: 15.8 cm
    • While historians debate which was the most effective saber design, our teardown unit hails from the old school: single blade, fixed length. No fancy crossguards here.
  2. Lightsaber Teardown: adım 2, 3 resimden 1. Lightsaber Teardown: adım 2, 3 resimden 2. Lightsaber Teardown: adım 2, 3 resimden 3.
    • Do you have the death sentence on twelve systems? Do you frequent wretched hives of scum and villainy? Then you probably don't want to see this saber firing up.
    • If only we were Force adepts, we could release this interior clasp with a simple wave of the hand. Instead, we nudge it free with the tip of a spudger, revealing the crystal chamber.
    • Seeing as this is his third lightsaber, Master Kenobi must have had long-term repairability in mind during its construction—it's incredibly easy to access the crystal chamber, with its single Adegan crystal.
  3. Lightsaber Teardown: adım 3, 3 resimden 1. Lightsaber Teardown: adım 3, 3 resimden 2. Lightsaber Teardown: adım 3, 3 resimden 3.
    • We'll get back to that crystal chamber a bit later. For now, we set out to open the saber itself.
    • Let's start by unscrewing this clamp pin that secures the switch housing cover.
    • With the pin removed, we're able to lift the clamp brackets out with no trouble.
    • It seems Obi-Wan saw fit to include a charging port on his lightsaber. Lucky for us, he decided to use a standard DC barrel jack connector.
    • Unscrewing this small retaining ring loosens the port from the housing cover.
  4. Lightsaber Teardown: adım 4, 2 resimden 1. Lightsaber Teardown: adım 4, 2 resimden 2.
    • We quickly dispatch a few tiny set screws securing the clamp to the body of the lightsaber.
    • With the set screws removed, we extract the activation stud.
    • Pro tip: Sith happens. Fortunately, it's now impossible to ignite this saber by accident. For safety's sake, those of you tearing down a lightsaber at home should follow a similar procedure.
  5. Lightsaber Teardown: adım 5, 3 resimden 1. Lightsaber Teardown: adım 5, 3 resimden 2. Lightsaber Teardown: adım 5, 3 resimden 3.
    • Turning our attention to the top of the saber, we release the emitter shroud for inspection.
    • The shroud appears to contain some sort of magnetic stabilizing ring.
    • We're not 100% sure what a non-magnetically stabilized lightsaber beam does, but we're guessing it would be wise to put this back when we're done.
  6. Lightsaber Teardown: adım 6, 3 resimden 1. Lightsaber Teardown: adım 6, 3 resimden 2. Lightsaber Teardown: adım 6, 3 resimden 3.
    • At first, we're a bit stumped by the crystal chamber cover. Turns out it's quite easy to remove with a half-twist and some well-targeted pressure.
    • We subject the cover to a small battery of tests; it's made of an unknown material that is both nonmagnetic and nonconducting.
    • With its smooth inner surface and segmented exterior, this looks designed to protect the wielder from the saber's extreme energy output, while possibly providing a small measure of cooling for the internals.
  7. Lightsaber Teardown: adım 7, 2 resimden 1. Lightsaber Teardown: adım 7, 2 resimden 2.
    • With the shroud removed, the blade emitter comes into full view.
    • Some say this ancient weapon is no match for a good blaster at your side. Whichever view you take, you have to respect this kind of craftsmanship.
    • At this point, we've cleared the way to slide the clamp free and expose the switch housing.
    • Being photography buffs, we can't help but notice this clamp bears a striking—but entirely coincidental—resemblance to a 3-cell Graflex flash handle.
  8. Lightsaber Teardown: adım 8, 3 resimden 1. Lightsaber Teardown: adım 8, 3 resimden 2. Lightsaber Teardown: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • We carefully remove the activation stud control bar.
    • Stay on target...stay on target... We use our tweezers to make a trench run and take out a few nuts, loosening the next stage of the cylinder.
  9. Lightsaber Teardown: adım 9, 2 resimden 1. Lightsaber Teardown: adım 9, 2 resimden 2.
    • You won't find any regular old lithium ion batteries here! This lightsaber features a diatium power cell.
    • The Force is strong with this one—the recharge port seems a tad redundant, as a properly-maintained diatium power cell will last indefinitely.
    • The parabolic blade continuously recycles the power cell's energy output whenever the saber is not in contact with other objects.
  10. Lightsaber Teardown: adım 10, 3 resimden 1. Lightsaber Teardown: adım 10, 3 resimden 2. Lightsaber Teardown: adım 10, 3 resimden 3.
    • We had a slight weapons malfunction, but everything's perfectly all right now. We're fine—we're all fine here now, thank you.
    • In case of any more surprises, we get a hand from a friend.
    • Lightsabers are the leading cause of dismemberment in the quadrant; be sure to take precautions during repairs.
    • Next we unscrew the pommel cap, hoping to find a backup power cell.
    • No luck—we're able to remove an intermediary collar, but we don't find a reserve power cell.
    • Time to get a closer look at that crystal chamber.
    I couldn't belive, great job
    Jesus - Yanıt
    Brad I am blown away, you are a true artist! I went to your site and checked out some of your other work and am just in awe. The ROTJ Luke is one of the coolest things I've ever seen!
    Chad - Yanıt
    Nice! Where can I get one? May The 4th Be With You!
    MacBook1 - Yanıt
    I would love to get hold of a SlothFurnace saber... lol
    Khel - Yanıt
  11. Lightsaber Teardown: adım 11, 3 resimden 1. Lightsaber Teardown: adım 11, 3 resimden 2. Lightsaber Teardown: adım 11, 3 resimden 3.
    • That's no moon—it's the focusing crystal.
    • We gingerly remove both the cycling field energizer and the focusing crystal activator from atop the crystal chamber.
    • Misaligned crystals could cause a lightsaber to explode the instant it's powered on.
    • Excited to get an unobstructed view of the primary crystal, we pull back the energy modulation circuits—and lift away the crystal chamber cooling fins.
  12. Lightsaber Teardown: adım 12, 2 resimden 1. Lightsaber Teardown: adım 12, 2 resimden 2.
    • We finally arrive at the heart of the lightsaber, the primary crystal.
    • This particular lightsaber uses a blue Adegan crystal, typical of a Jedi. Sith lightsabers are commonly made with synthetic red crystals.
    • Arguably the most important component, Adegan crystals are known for their Force-sensitive properties. Once properly attuned to the Force, a crystal is built into the lightsaber. Over time, the crystal will form a special bond with its wielder.
    • We peel away the three neatly packed crystal energizers from the primary crystal housing.
  13. Lightsaber Teardown: adım 13, 2 resimden 1. Lightsaber Teardown: adım 13, 2 resimden 2.
    • We slide the rear grip and inert power insulator from the hilt.
    • Though the rear grip resembles a heat sink, this design avoids the dramatic overheating problems seen in early lightsabers.
    • Looks like the extra space down here might be for upgrades, or possibly for the expert balance Obi-Wan surely requires of his saber.
    • With the disassembly complete, how will this beautifully crafted weapon fare in the repair arena?
  14. Lightsaber Teardown: adım 14, 2 resimden 1. Lightsaber Teardown: adım 14, 2 resimden 2.
    • Lightsaber Repairability Score: 10 out of 10 (10 is easiest to repair)
    • Extremely durable components make the need for repair unlikely outside of severe combat damage.
    • Robust diatium power cell lasts the life of the device.
    • Recharge port allows for topping up the power cell in extreme circumstances.
    • No adhesive anywhere; all components are removable with basic tools.
    • Replacing the rare Adegan crystal requires a trip to remote star systems, or paying a hefty fee to an enterprising smuggler.
    • Lack of published repair documentation means you'll have to rely on your Jedi abilities to figure all this out. (But the Force has a strong influence on our weak minds, so we're still giving it a 10/10.)
  15. Lightsaber Teardown: adım 15, 3 resimden 1. Lightsaber Teardown: adım 15, 3 resimden 2. Lightsaber Teardown: adım 15, 3 resimden 3.
    • And now for the bits we didn't show you—because while lightsabers exist in a galaxy far, far away, this particular piece of Jedi kit was built by a true sabersmith here on Earth.
    • Many thanks to the amazingly talented Brad Lewis, who generously loaned us one of his hand-crafted, better-than-movie-accurate lightsaber replicas for this teardown. You can see his complete build log for this lightsaber, and many others, at SlothFurnace.com—or, check him out on Facebook or Twitter!
    • Thanks Brad! And may the Force be with you—always.
Geoff Wacker
91.140 İtibar
89 adet Kılavuz yazıldı
20Kılavuz Yorumları
Where can I buy this lightsaber???
gladgura - Yanıt
There are a few websites with light sabers... www.ultrasabers.com or www.saberforge.com
Bill -
Nice Teardown. Have the tools but no Lightsaber :(
Bernhard Grohs - Yanıt
Finally, I found out how to repair mine!!!
May The Force be with you!
Adrian - Yanıt
A joke a day keeps the doctor away........This is good for 14 days :-)
info - Yanıt
You guys did a great job! Happy to be part of it.
-sloth
slothfurnace - Yanıt
Really nice work in the finishing. Was the crystal an original, or is it 3D made ?
Neil - Yanıt
Neil, the crystal is an actual aqua aura quartz crystal. Hand selected for this build, and the mount machined to fit it.
slothfurnace -
Thanks for the information about the crystal.. nice work for the hand also..
Neil -
The fix is strong with you
hectorlizarraga - Yanıt
No doubt - this is the art of teardown we want to see!!
Now the only question is: How long it will take to the teardown of the Millenium Falcon?!? And how is Han about it?!?
Oliver Ermonis - Yanıt
I like so much this site... and this saber!!!!
Juan Carlos Allo Navarro - Yanıt
I've gotten to hold this very lightsaber. It is a piece of art, and the build process was insane. This is one of my favorite sabers he has built.
rudimentz - Yanıt
Replace the focusing crystal w/ a Dilithium one, can now narrow beam down to micron diameters '-}
Mark Cob - Yanıt
Hi,
I'm having weird grounding problem with my lightsaber - the plasma beam shows light interference. I think the surge circuit is in ground loop with AC mains as this interference is much more prominent when placed near transformers (Desktop PSU or laptop power brick). I was not able to measure capacitance of the two inverting capacitors from the dilithium cell - their value is likely in kilofarads (both seem to overload my digital multimeter, but there is some sort of voltage difference between the body and negative terminals - upon connecting those to my oscilloscope, I measured 450mV slew at 150Hz with 5% THD+N, so it seems there is a grounding problem between the body and the internal electronics (I'm based in Europe, with 230V 50Hz mains). Any idea where the problem might be, or which components need replacing?
Andrew - Yanıt
Based on your description, I'd say the culprit is the dilithium cell. Building lightsabers is tricky business, so if you're going to use technology from another universe, you're on your own my friend!
Jeff Suovanen -
Amazing ! give me one of them and I will pay on soon...Okey
erwinwibawa - Yanıt
this was helpful thank you
anikin slaywalker - Yanıt
Where to buy it ? :(
laberintodepenumbra - Yanıt
Why not get one of the make it yourself light sabers from Disney’s Galaxy Edge and tear it down.
rm.marino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 70
Her zaman: 132,343
