Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Punkt MP02 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Punkt MP02 Teardown, Remove Sim card tray: adım 1, 2 resimden 1. Punkt MP02 Teardown, Remove Sim card tray: adım 1, 2 resimden 2.
    • Remove Sim tray
  2. Punkt MP02 Teardown: adım 2, 2 resimden 1. Punkt MP02 Teardown: adım 2, 2 resimden 2.
    • Using a knife start prying at the back in the top right corner. Then use a metal spudger to remove the back piece.
    • The back piece is held in place with a (not so strong) sticker and some hooks (see second picture for a side view of the hooks).
  3. Punkt MP02 Teardown: adım 3, 1 resimden 1.
    • Remove two screws.
    • in my case one of the screws was covered by a small white sticker
  4. Punkt MP02 Teardown: adım 4, 3 resimden 1. Punkt MP02 Teardown: adım 4, 3 resimden 2. Punkt MP02 Teardown: adım 4, 3 resimden 3.
    • using a metal spudger I started separating the two halves of the phone shell on the right of the USB port.
    • by carefully inserting and twisting the spudger I could unclip the two halves to separate them
    • be careful not to insert the spudger too deep, you could damage the mainboard or battery
    • as I wasn't careful enough, the frame broke in two places
  5. Punkt MP02 Teardown: adım 5, 2 resimden 1. Punkt MP02 Teardown: adım 5, 2 resimden 2.
    • now remove the back half
    • I looks like the back contains come antennas and a speaker
  6. Punkt MP02 Teardown: adım 6, 3 resimden 1. Punkt MP02 Teardown: adım 6, 3 resimden 2. Punkt MP02 Teardown: adım 6, 3 resimden 3.
    • now remove the spongy piece that sits ontop of the USB port
    • at this stage I noticed a screw falling on my table and the screw to the right of the USB port was missing
    • I also noticed the screw to the left being loose
  7. Punkt MP02 Teardown: adım 7, 1 resimden 1.
    • Now remove eight screws and the power button
  8. Punkt MP02 Teardown: adım 8, 1 resimden 1.
    • I unplugged the two antenna cables
    • unplug the battery connector
  9. Punkt MP02 Teardown: adım 9, 1 resimden 1.
    • now I opened the clips that hold the ribbon cables
  10. Punkt MP02 Teardown: adım 10, 3 resimden 1. Punkt MP02 Teardown: adım 10, 3 resimden 2. Punkt MP02 Teardown: adım 10, 3 resimden 3.
    • at this point the device felt loose and I didn't know how to continue - I noticed after beginning to pull on the battery pull tabs that the mainboard separated
  11. Punkt MP02 Teardown: adım 11, 1 resimden 1.
    • by gently moving the mainboard down (direction of USB port) the mainboard could be separated
    • notice the metal hook that prevents the device from being separated without downwards movement
  12. Punkt MP02 Teardown: adım 12, 1 resimden 1.
    • remove the middle screw
  13. Punkt MP02 Teardown: adım 13, 2 resimden 1. Punkt MP02 Teardown: adım 13, 2 resimden 2.
    • Now I could remove the screen and main board
Florian
353 İtibar
2 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you for posting this guide. It'll become more valuable as these devices age--I anticipate having to replace the battery sometime in the next two years.
vvaylon_k - Yanıt
thank you very much! I had water damage and could open and dry/clean the device before there was any irrevocable damage!
Peter van Mil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 40
Son 30 gün: 221
Her zaman: 2,112
