Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Retina MacBook 2015 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Retina MacBook 2015 Teardown, Retina MacBook 2015 Teardown: adım 1, 2 resimden 1. Retina MacBook 2015 Teardown, Retina MacBook 2015 Teardown: adım 1, 2 resimden 2.
    • Since it was announced on March 9th, we've been eager to get our hands on the sleek new MacBook. Before we tear inside this beauty, we take a glance at its specs:
    • 12-inch, 2304-by-1440 pixel (~226 ppi) IPS "Retina" display
    • 1.1 GHz or 1.2 GHz dual-core Intel Core M processor (optional 1.3 GHz processor available)
    • 8 GB of 1600 MHz LPDDR3 memory
    • 256 GB or 512 GB flash storage
    • Intel HD Graphics 5300
    • Single USB-C port
  2. Retina MacBook 2015 Teardown: adım 2, 2 resimden 1. Retina MacBook 2015 Teardown: adım 2, 2 resimden 2.
    • While we want to commend Apple for adopting the new USB Type-C standard, they've done so in a way that makes it impossible to use old adapters on new devices. The MagSafe and Thunderbolt ports of old are gone. The new MacBook has one USB-C to rule them all.
    • For comparison's sake:
    • 10-watt iPad USB adapter (left)
    • 29-watt USB-C power adapter included with the MacBook (middle)
    • 60-watt MacBook Air Magsafe 2 (right)
    • This is the first MacBook in memory to ship without some form of MagSafe adapter. The breakaway nature of MagSafe made it less likely to damage ports and plugs when yanked.
    • Hopefully users will benefit from the standardization, and not trip over their cables too often.
    Can we heap some scorn on Apple for not also including/designing in a 1A USB Type A connector on this charger block? An additional 5W wouldn't have made the guts substantially bigger, if at all. Coupled with the ridiculously short Type-C cable that they ship it with, if a road warrior wants to charge their MacBook and iPhone "on the go", they're SOL. And since the Type-C cable is so short, the charger block is likely to be ON your desk, not under it; the exact same place you'd expect an iPhone charging block. Not seeing fit to put both functions in one block speaks multitudes to me about Apple's design philosophy towards its users: greedy contempt. They are, in effect, saying "We know you're going to have to buy another, 3rd party block. Haha."
    Scott - Yanıt
    @ScooterComputer,
    The one thing most folks are missing about this laptop - it is designed to be used on your lap! No cables, no cords, no restrictions on movement, the battery lasts all day. You use it like an iPhone or an iPad, carry it around, move it, take it here, take it there. You plug it in to charge at the end of the day.
    You do not leave it on a desk. Get an iMac or MacBook Pro if you want to leave it on your desk plugged in. "Think different."
    misc4brian - Yanıt
    Did "think different" magically become "defend whatever apple shoves down our throats" ?
    Cmon, sometimes they make stupid choices, and the reality here is that in their ecosystem those choices are forced onto their consumers because there is no "other makers" it's either use the device apple makes or move on.
    That being the case then this is a bad decision. Because it creates a situation that doesn't benefit their userbase in any way. It creates a situation of dissatisfaction with their products. They are basically forcing you to buy dongles for ports that cost ridiculous amounts of money when designing in even just a usb 3 port would have cost them pennies.
    Miguel Simoes -
    I want to be able to charge the stupid thing along with my iPhone without having to carry around two power bricks. Is that so much to ask? With older MacBook models I could plug in my MacBook and plug my phone into that and they'd both charge. What is the point of having an ultra portable if you're forced to carry around a 5lb gear bag to hump all the rest of the necess-ories??
    Scott -
    What an apple fan-boi comment. Just because you can sit it on your lap doesn’t mean that you won’t *ALSO* put it on your desk for part of the day. It never fails to amaze me how some people identify themselves so strongly with the brans they buy that they have to be unofficial spokesman and apologist. Sad.
    ndolam -
    USB-C doesn't rule them all. It just displaces them all...
    lemonlev - Yanıt
  3. Retina MacBook 2015 Teardown: adım 3, 2 resimden 1. Retina MacBook 2015 Teardown: adım 3, 2 resimden 2.
    • The new MacBook is less than half the thickness of its 2009 ancestor, measuring 0.52 inches at its thickest point.
    • At 1.08" thick, the 5 pounds of polycarbonate-swathed 2009 MacBook dwarfs our 2.03 pound Retina MacBook.
    • Apple probably shaved off a lot of that weight in removing ports. Back in 2009 we had MagSafe, ethernet, Mini DisplayPort, 2x USB, audio, and a security slot.
    • We'd also remind you to say goodbye to your optical drive, but that ship has pretty much sailed.
  4. Retina MacBook 2015 Teardown: adım 4, 2 resimden 1. Retina MacBook 2015 Teardown: adım 4, 2 resimden 2.
    • Those are pretty short keys. Bursting from its cocoon is Apple's newly-designed keyboard, equipped with a butterfly mechanism. Let's see if this keyboard will go twice as high as the traditional scissor-switch mechanism.
    • We zoom in on the Retina display, described by Apple as the thinnest, most energy-efficient Retina display ever on a Mac. The pixels themselves have a larger aperture, enabling more light to come through, resulting in greater energy efficiency without compromising brightness.
    The "twice as high" link is linking to a Doors music video!
    Dev 4 iOS - Yanıt
    I was searching for the reference in this, what do they even mean by twice as high?
    Leigh Ellis -
    The keyboard has a "butterfly mechanism". The "twice as high" line is a reference to the Reading Rainbow theme song, which has the lyrics "Butterfly in the sky/I can go twice as high". The link is to Jimmy Fallon as Jim Morrison in The Doors, doing a parody cover of the referenced theme song.
    Steven Collins -
    Yes, them singing "you can fly twice as high."
    Calion - Yanıt
    Please take the screen apart and show how to update the webcam from 480p to some iSight thing using a spare part of an old iPod or iPhone with camera.
    mahal - Yanıt
  5. Retina MacBook 2015 Teardown: adım 5, 2 resimden 1. Retina MacBook 2015 Teardown: adım 5, 2 resimden 2.
    • We make a quick note of the newly-minted model number—A1534—before moving forward.
    • This may be the future of laptops, but Apple has stuck to their tradition of using tamperproof 5-point pentalobe screws for the new MacBook. Le sigh.
  6. Retina MacBook 2015 Teardown: adım 6, 3 resimden 1. Retina MacBook 2015 Teardown: adım 6, 3 resimden 2. Retina MacBook 2015 Teardown: adım 6, 3 resimden 3.
    • Time to rip off that boring, plain ol' aluminum lower case, and get to the good—
    • What is this new devilry? Cables!? A battery and logic board in the lower case?
    • The standard pop-open-at-the-hinge practice still holds, but then the cables go taut. Then you have to hinge the case back forward to access the connectors and open the case.
    • What is this, a mid-gen iPhone?
    • The standard plastic clips of old are replaced with futuristic pegs and weird spring clips.
    • "If it ain't broke, make it out of, like, three more metal pieces in funky shapes." — Some Apple designer, we assume.
    后盖8颗螺丝拧掉之后,拿吸盘都揭不下来。
    我确实是从凹槽口开始揭的,怎么办,急,在线等。
    黄奎元 - Yanıt
  7. Retina MacBook 2015 Teardown: adım 7, 2 resimden 1. Retina MacBook 2015 Teardown: adım 7, 2 resimden 2.
    • Reminiscent of the Macbook Pro 13" Retina released in March, this MacBook comes equipped with the fancy Force Touch trackpad. We disconnect the trackpad/keyboard cable for a little more maneuvering room.
    • With the springy trackpad/keyboard cable disconnected, we can fold the whole enchilada flat on the table. Time to survey the field and see what we're up against this time.
    So if the trackpad is shot the keybored will stop working ?
    tariqaa2001 - Yanıt
  8. Retina MacBook 2015 Teardown: adım 8, 3 resimden 1. Retina MacBook 2015 Teardown: adım 8, 3 resimden 2. Retina MacBook 2015 Teardown: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Battery Blocker
    $3.99
    • Wait, this is a notebook, right? Where's the battery connector?
    • At a loss, we play with this little yellow button for a bit. Boop.
    • We've seen something like this before—in the iPad, Apple loves to hide the battery connector under the logic board. This is the first time we've seen it in a laptop, so it looks like it's time for...
    • Our newly-minted battery isolation pick turns out to be just the trick we need to keep the juice away from the logic board's spring contacts.
    Did you guys ever find out what the button is for on the battery connection tab for the PCB?
    hakuriyellowsaber - Yanıt
    Yeah, it’s explained in the repair guide—just a way to power everything down for servicing without physically disconnecting the battery.
    Jeff Suovanen -
    It's a reset button. If your mac locks up you can press and it will operate normally again.
    Allen - Yanıt
    IMPORTANT: If you don’t press the yellow button before removing the trackpad cable on new models, it will KILL your Mac. This I’m reading from fellow contributors. Please tell me, I have not destroyed two MacBooks this way.
    Chris Leeds - Yanıt
  9. Retina MacBook 2015 Teardown: adım 9, 3 resimden 1. Retina MacBook 2015 Teardown: adım 9, 3 resimden 2. Retina MacBook 2015 Teardown: adım 9, 3 resimden 3.
    Flexible Extension
    $6.99
    • In our quest to begin the Great Cable Disconnect of 2015, we find a tri-wing screw!
    • Lucky for us, that's something we can handle.
    • We finally disconnect the 3-in-1 display/power/I/O port cable that runs to the MacBook's lone USB-C port.
    • It's funny because while there are three functions, there's only one port, and no I/O board.
  10. Retina MacBook 2015 Teardown: adım 10, 3 resimden 1. Retina MacBook 2015 Teardown: adım 10, 3 resimden 2. Retina MacBook 2015 Teardown: adım 10, 3 resimden 3.
    • We guessed that the thinnest Retina display ever would come with some other changes—but this is one weird display connector!
    • We tweeze away the "audio board" connector that ties in the headphone jack and dual microphones.
    • Finally, the two halves are free to fly. Now it's time to get to that logic board!
  11. Retina MacBook 2015 Teardown: adım 11, 3 resimden 1. Retina MacBook 2015 Teardown: adım 11, 3 resimden 2. Retina MacBook 2015 Teardown: adım 11, 3 resimden 3.
    • We carefully lift the lovely logic board from its aluminum nest.
    • Apple points out that the logic board in the Retina MacBook is 67% smaller than the logic board in the 11-inch MacBook Air.
    • Apple's use of the new Intel Core M processors allows for smaller form factors and fun little heat sink covers.
    • More impressive than the updates is the conflict-free production of the Core M processors. Thanks, Dodd—Frank!
    • The heat sink is nicely machined to provide multiple points of contact on the logic board—perhaps even to cool the reverse side of the logic board a bit.
    I think the temperature will be around 60-70 degrees (Under load).
    Cooling is similar to Apple TV 3 generation.
    VISION463 - Yanıt
    Would you please measure the logic board? I'd like to know how small it actually is.
    plink53 - Yanıt
    It's about 4.5" x 1.5", not including the battery contact protrusion.
    Andrew Optimus Goldheart -
    I have a base model 1.1/256GB. Seems exporting 1080p video in iMovie generates the most heat. Mine hovered between 84-87C thru the 12 minute process with a high them reading of 88.20 Cooling was immediate after export was complete. Down to 54C within 10 seconds. Intel lists the high gem for the 5Y31 at 95C
    Michael Bell - Yanıt
    ugh.....did you have to get political????? stick to repairing things. and just FYI dodd-frank is directly responsible for raising my CC APR from 5% to 18% amongst other things. Thanks, Dodd-Frank!
    crevz - Yanıt
    Seems to be significant thickness of paste between the heat sink and the CPU.
    Yishai Sered - Yanıt
    Apple is going down, I better buy a few second hand 2012 model for the future, when mine will give up, no way I'm buying an no upgradable computer! I might have to think seriously to try to make a hackintosh also!
    tregouetsylvain - Yanıt
  12. Retina MacBook 2015 Teardown: adım 12, 1 resimden 1.
    • It's time to put the chips on the table! Let's see what this logic board has to offer:
    • Elpida/Micron FB164A1MA-GD-F 8 GB LPDDR3 Mobile RAM
    • Toshiba TH58TFT0DFKLAVF NB2953 128 GB MLC NAND Flash memory (+ 128 GB on the reverse side for a total of 256 GB)
    • NXP 11U37 microcontroller; 128 kB flash, 10kB SRAM
    • SMSC 1704-2 Temperature Sensor
    • Texas Instruments SN650811 (probably power converter related to SN6501)
    That can't be SLC but MLC or TLC, right? Also, where is the %#*@ SSD controller?
    Matthieu L - Yanıt
    SSD is scolded into logicboard. It's immovable. SSD controller is on the rear part.
    tonyadams66 -
    Toshiba TH58TFT0DFKLAVF is 128GB MLC NAND Flash
    JJ Wu - Yanıt
    Anandtech had found something.It is Apple own design SSD controller.
    JJ Wu - Yanıt
    I wonder how one would extract/recover data from a retina MacBook 2015 with a dead logic board (you know s..t happen)? On MacBook Pros/previous gen MacBooks you could simply remove the SSD and place it to another Mac or external enclosure (not to mention the older models with the usual SATA interface).
    It's OK if you backup your data regularly (most users don't hence the data recovery business is flourishing) what will you do if there is no backup? Sure sometimes logic boards can be repaired, but sometimes even L. Rossmann can't fix them...
    Bloob Box - Yanıt
    I need to restore my mail back from SSD drives. My logic board is dead. Is there a way I can do it. I am willing to remove SSD from the dead logic board. Any ideas on how I may do this.
    Simple Ply - Yanıt
    I need to replace Texas Instruments SN650811. I tried buying it online on their web, but they don’t sell the part. Any replacement or ideas on how to get it fixed?
    Santiago Maestri - Yanıt
  13. Retina MacBook 2015 Teardown: adım 13, 1 resimden 1.
    • Humming a logical tune, we peruse the back side of the most logical of boards:
    • Intel SR23G Core M-5Y31 CPU (Dual-Core, 1.1 GHz, Turbo Boost up to 2.4 GHz) with Intel HD Graphics 5300
    • SK Hynix H9TKNNN4GDMRRR-NGM 4 Gb (512 MB) LPDDR2-SDRAM
    • Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash
    • Elpida/Micron J4216EFBG-GNL-F DDR3 SDRAM
    • Broadcom BCM15700A2, appears to be a wireless networking chipset
    • Murata 339S0250 (Likely an iteration of the 339S02541 Wi-Fi module found in the iPad Air 2)
    • Texas Instruments/Stellaris LM4FS1EH SMC Controller (Replacement codename for TM4EA231)
    The Toshiba 128GB NAND Flash is not SLC. It is 128GB MLC NAND Flash. As the information Apple announced on the web site, MacBook uses PCIe-based SSD. There should be an PCIe-based NAND Flash controller. And, as the teardown result you did, there is an additional memory chip, SK Hynix H9TKNNN4GDMRRR-NGM. Can you recheck the chip? Is there a chip under SK Hynix H9TKNNN4GDMRRR-NGM? I guessed the PCIe-based NAND Flash controller is under SK Hynix H9TKNNN4GDMRRR-NGM which is PoP package.
    JJ Wu - Yanıt
    Should SK Hynix H9TKNNN4GDMRRR-NGM be LPDDR2?
    Refer to https://www.google.com.tw/url?sa=t&rct=j...
    JJ Wu - Yanıt
    The TM4EA231 is a Texas Instruments Tiva series ARM Cortex M4 microcontroller. It is the replacement code name for the LM4FS1EH.
    seandlh - Yanıt
    What is the 4Gb SK Hynix LPDDR3-SDRAM used for in Macbook?
    AnsonH - Yanıt
    it should the memory for SSD controller.
    JJ Wu -
    SK Hynix H9TKNNN4GDMRRR-NGM is not LPDDR3. It is 4Gb LPDDR2 with Apple customized PoP package.
    JJ Wu - Yanıt
    It would be interesting, if the components on the whole board are something new, or can be found in similar configuration in other models on the market.
    There are voices saying, that the hardware is highly overpriced. It would like to have objective comparisons or analyses, not emotion and religion-driven affects of the Apple haters and on the other hand of the fan boys.
    Is anybody here with real expertise?
    giuseppe naniscola - Yanıt
    Yes. It is something new. Mostly, PoP package is used on SmartPhone and Tablet. Apple should be the first one to use PoP package on the SSD controller.
    JJ Wu -
    where is the Graphic ic ?
    madushanka gamage - Yanıt
  14. Retina MacBook 2015 Teardown: adım 14, 1 resimden 1.
    • In 2011, Apple acquired Anobit, an Israeli flash memory controller designer.
    • Four years later, it looks like they might now have something to show for it—thanks to Anandtech's report that the MacBook's SSD looked a little unusual in the system profiler, we took our heat gun to the SK Hynix SDRAM to see what was hiding underneath.
    • Where we expected to see something by Samsung or Toshiba, we found an unbranded chip with a very Apple-esque part number: 338S00055.
    • Our friends at ChipWorks took a peek, and have confirmed this is definitely an Apple custom device, fabricated at TSMC. We'll have more details soon!
    Is it possible to remove the whole logic board and try to use As an external hard drive?
    Benjamin Taylor - Yanıt
  15. Retina MacBook 2015 Teardown: adım 15, 3 resimden 1. Retina MacBook 2015 Teardown: adım 15, 3 resimden 2. Retina MacBook 2015 Teardown: adım 15, 3 resimden 3.
    • It was too much to hope that the battery would be secured with a few screws, MacBook Air-style. Time to break out the heat and the cards.
    • Apple's new terraced battery technology is supposed to provide 35% more battery cell capacity than would have been possible before.
    • We had hoped this would have provided room for a few screws, or some of those fancy little clips we saw on the case. Apparently not.
    • iOpener on a lower case? This just feels weird...
    • Scrape, peel, scrape, peel. Look at all that nasty adhesive.
  16. Retina MacBook 2015 Teardown: adım 16, 2 resimden 1. Retina MacBook 2015 Teardown: adım 16, 2 resimden 2.
    • Ugh! Even the center cell of the battery is glued down, and we had hoped the sticky cells we found in the new 13" MacBook Pro wouldn't be a trend...
    • To complicate the procedure, the battery sits down in a well; the only safe place to pry is over this aluminum wall.
    • Apple says that they use photos from high-speed cameras to help align these batteries in their cases, accounting for variations at the microscopic level.
    • This level of precision works well for fitting the largest battery possible, but it doesn't bode well for the ideas of battery replacement.
    • Well, it's finally out—in all its multi-segmented glory.
  17. Retina MacBook 2015 Teardown: adım 17, 2 resimden 1. Retina MacBook 2015 Teardown: adım 17, 2 resimden 2.
    • In order to power this slender gadget, Apple produced this form-fitting 7.55 V, 39.71 Wh, and 5263 mAh battery.
    • According to the specs, this is just a hair more than you get from this year's almost-pudgy-by-comparison, 5100 mAh MacBook Air 11"—though Apple touts equal battery performance of up to nine hours surfing the net, or ten hours of iTunes video playback.
    • For comparison's sake: With its slightly larger 7.6 V, 5380 mAh (42.4 Whr) battery, Microsoft's Surface Pro 3 also promises "9 hours of web browsing."
  18. Retina MacBook 2015 Teardown: adım 18, 3 resimden 1. Retina MacBook 2015 Teardown: adım 18, 3 resimden 2. Retina MacBook 2015 Teardown: adım 18, 3 resimden 3.
    • We've struck gold! ...Or maybe just a dielectric coating on aluminum.
    • The treasure antennas sit in channels routed into each speaker assembly.
    • If this is a dielectric coating, some of Apple's recent patents could suggest that Apple is using the speaker assemblies to form a compound antenna, helping maximize power efficiency in this smaller form factor.
    What kind of speaker design is this? Why not traditional round speakers?
    Brad Fortin - Yanıt
  19. Retina MacBook 2015 Teardown: adım 19, 3 resimden 1. Retina MacBook 2015 Teardown: adım 19, 3 resimden 2. Retina MacBook 2015 Teardown: adım 19, 3 resimden 3.
    • Finally, we reach one of the most talked-about trackpads in town. As we could expect, the Force Touch trackpad in the Retina MacBook looks like a slimmer, daintier version of the one we found in the 13" MacBook Pro.
    • Once we cut away the bracket, we get a clear view of the Taptic Engine.
    Is that black cable to connect to whole keyboard module?
    jerrylrg - Yanıt
  20. Retina MacBook 2015 Teardown: adım 20, 3 resimden 1. Retina MacBook 2015 Teardown: adım 20, 3 resimden 2. Retina MacBook 2015 Teardown: adım 20, 3 resimden 3.
    • Only four strain gauges? Seems unlikely... Time to hunt around.
    • Ahah! Some strange rubbery glue was holding a cable over the second half of each strain gauge pair.
    • As we found previously in Apple's Force Touch, the strain gauges on this trackpad sense pressure from your fingers without really moving.
    • With the virtual feedback of the Taptic Engine, the new trackpad has essentially no moving parts, which usually makes for a more durable component.
    I'm sure the new strain gauge trackpads are more durable than the old diving board trackpads (which had a tiny dome switch + fragile plastic/rubber nub making up the physical button, mine failed there), but the strain gauges DO wear out, don't they?
    Is it likely to be something that people who press hard will see failing at some point during the Macbooks lifetime?
    Steve - Yanıt
  21. Retina MacBook 2015 Teardown: adım 21, 1 resimden 1.
    • With the strain gauge bracket removed, we take a closer look at the chips powering this newfangled trackpad:
    • Broadcom BCM5976 touchscreen controller
    • STMicroelectronics 32F103 ARM Cortex-M based microcontroller
    • Linear Technology LT3954 LED Converter with Internal PWM Generator
    What's the LT3954 on the trackpad for?
    adrianpike - Yanıt
  22. Retina MacBook 2015 Teardown: adım 22, 2 resimden 1. Retina MacBook 2015 Teardown: adım 22, 2 resimden 2.
    • Another tri-wing bites the dust, and the USB-C port cable turns out to be an interconnect cable.
    • And the dang port is trapped by the display hinge! How rude.
    • Someone really doesn't want us to replace our sole everything-in-one port...
    • We'll come back for you later, USB-C.
    • Dang it! We should have said "USB-C you later."
    There is metal shielding on the cable which is for USB Type C cable.
    Is there any chips under the metal shielding?
    JJ Wu - Yanıt
  23. Retina MacBook 2015 Teardown: adım 23, 2 resimden 1. Retina MacBook 2015 Teardown: adım 23, 2 resimden 2.
    P2 Pentalobe Screwdriver iPhone
    $11.99
    • Well at least the audio assembly is modular, allowing easy removal of the audio jack board. But that means the dual microphones are left behind.
    • Behind the keyboard that is—curses!
    • Wait, are those screws? No rivets? We can actually get in? Nice!
    • To be fair, that screw you see in the corner is a pentalobe—a P2. That's an iPhone-sized screw. Apple doesn't really want to let us in.
    What is the audio codec vendor?
    JJ Wu - Yanıt
  24. Retina MacBook 2015 Teardown: adım 24, 3 resimden 1. Retina MacBook 2015 Teardown: adım 24, 3 resimden 2. Retina MacBook 2015 Teardown: adım 24, 3 resimden 3.
    • Three pentalobes later...
    • ...and 10 Phillips screws with weird sloping spacers, allowing them to secure the keyboard at an angle...
    • ...and finally two screws that fit into the case clips (throwback to step 6).
    • We can't complain too much, I mean screws are better than adhesive—oh my goodness.
    • The adhesive backing (a kind of layered tape) is stuck to the keyboard, and barely holds together upon peeling.
    • Under the blanket of tape is a field of disheartening stars. Two pentalobes per key, plus a row at the top and bottom, for a total of 83, plus the three from before.
    • "Look on my Macs, ye Mighty, and despair." — Jony Ive, probably.
    On either side of the keyboard are phillips screws which I assumed were 000 size because that is the only screwdriver of that size that was listed in your tools needed section - I even ordered the driver from ifixit but it does not work. Can someone please tell me the correct size driver for these screws - I ordered the JIS version of the 000 today - I think that might be it. Thanks!
    markpowers - Yanıt
  25. Retina MacBook 2015 Teardown: adım 25, 3 resimden 1. Retina MacBook 2015 Teardown: adım 25, 3 resimden 2. Retina MacBook 2015 Teardown: adım 25, 3 resimden 3.
    • Daunted by the pentalobe-packed rear panel, we opt for frontal access. The keys pop off easily enough and seem to simply snap in place.
    • With very few moving parts inside, is it possible that this plastic butterfly mechanism might actually be a repair win?
    • Although we're a tiny bit worried about the plastic hinge fatiguing and breaking at its flex-point, we'll give Apple the benefit of the doubt and assume they've thought of that and designed for it.
    • The bracket is held in with tiny little clips; so cute.
    How much pressure did you apply to pop the keys off?
    Matt Turner - Yanıt
    Not a lot. A pretty light flick with a thing plastic tool like our opening pick works well enough, once you get it jammed in the gap between the key and the aluminum frame.
    Do the keys go back on after doing this? Being able to remove keys could be useful for cleaning.
    Will Franzen - Yanıt
    How bout the plastic cup where the plastic butterfly mechanism can you able to detach it also?
    michaelhgabrielmg - Yanıt
    What mechanism controls the "spring" in the key (driving the key back up)? The hinge controls the up and down motion, but where is the spring that drives the key up? And is it easy to replace this spring portion for keys that appear slightly less responsive?
    John Jerney - Yanıt
    I can't put the shift key back in properly, it won't snap back to it's place. Do you have any ideas?
    siavashmsgh - Yanıt
    Me too OTL. Did you solve the problem?
    Wookjong Kim -
    "Although we're a tiny bit worried about the plastic hinge fatiguing and breaking at its flex-point, we'll give Apple the benefit of the doubt and assume they've thought of that and designed for it."
    I went back and watched the introduction keynote. It's not plastic, it's glass-filled nylon.
    bdfortin - Yanıt
    How do replace the Spacebar? Do I put in the hinge first than the key. Or do I put the hinge and key already attached together back into the Spacebar area and apply firm pressure?
    Adriel Lemus - Yanıt
    If you remove the butterfly mechanism, be very careful to not flex it the 'other' way. The plastic will become fatigued and you will lose the pop-up action of the key.
    Robert Vasquez - Yanıt
    Don't use the triangular spatula in the picture. I broke my keyboard's key and key thickness is under 1mm. You should use fiber cable and apply on the up corner of the key.
    Musto - Yanıt
    I feel I should point out that the removal of that key cracked one of the itty bitty plastic clips on its underside, no good.
    Adam Tolley - Yanıt
    so the spacebar on my mb12 became inoperable; the 1st attempt to remove it and clean the inside yield no results (lots of gunk went out and the plastic bits holding the key to the butterfly mechanism were intact though) so i tried again and this time, applying minimal force, some of the plastic bits gave and now the key is loose and won’t stay in place much; that being said, at least i can use it when typing!
    any thoughts on how to fix that? did anyone try using any form of adhesive perhaps? i don’t suppose one can simply buy the spacebar / butterfly mechanism as a replacement part? i want to avoid spending 200usd to replace an otherwise perfect and scratch free top chassis part… thanks!
    Mike - Yanıt
    @mikebppla The Bookyard has individual keys as well as full key replacement sets. The keys are pretty tricky to replace without damage in my experience, but definitely worth a shot before you resort to replacing the entire upper case.
    Jeff Suovanen -
  26. Retina MacBook 2015 Teardown: adım 26, 3 resimden 1. Retina MacBook 2015 Teardown: adım 26, 3 resimden 2. Retina MacBook 2015 Teardown: adım 26, 3 resimden 3.
    • Now to remove the display and get to that pesky multipurpose port!
    • Ahh, USB-C! This lil' guy combines charging, data transfer, and video output into a single port.
    • We can't help but wonder why Apple chose to only include a single USB-C port. This means that if you want to charge your MacBook and use a USB device at the same time, you'll need a $69 adapter. We're all for change Apple, but come on.
    • Some critics have also argued that while the single USB-C port helps to maintain the MacBook's sleek profile, it could leave the new notebook open to some serious security problems.
    • USB-C supports a top speed of 10 Gbps (this port maxes out at 5 Gbps), bi-directional 20V/5A power, and a reversible design aimed to solve all of your USB woes.
    I'd like to see a bit more contempt for Apple's decision to wedge that USB Type-C connector behind the display hinge. Looking at the design, by using the aluminum case as the connector body they clearly are -trying- to make that port robust; but in doing that they're pushing the failure point onto the plastic tongue. The amount of aluminum on the part shows they KNOW that. The design is clever, modular. But to then wedge the thing IN, that's just asinine. They're over-engineering one point in an attempt to compensate for poor design at another. Then again, can't knock 'em much more than the 1 out of 10.
    Scott - Yanıt
    Not sure what you're getting at - what would a solution be? Make the aluminum weaker? I think that the extra metal there is to keep the corner from denting during a drop. As for the "wedging the connector in" part, that's a non issue since it is probably installed before the display is attached.
    Jeffery Daniels -
    @Jeffrey Daniels: By removing MagSafe, Apple is necessarily making the user accept a greater risk of breaking the Type-C connector. That the connector is modular, and designed the way it is, pretty much reflects Apple understands that. However, instead of merely making the connector modular AND easy to replace (a fast repair job), they make it a substantially longer job requiring the removal of the display (and a bunch else to get that far). The one part that carries the most risk of causing repair...they then go and make replacing it puzzlingly more difficult than the part's modularity would convey. (If you have to do that much work to get it out, why bother even making the thing compactly modular at all?)
    Scott -
    USB 3.1 Gen 2 supports 10Gbps, however Apple's implementation is USB 3.1 Gen 1…which only supports 5Gbps (just 1 lane of HiSpeed USB). AKA USB 3.0. See http://www.apple.com/macbook/specs/
    Scott - Yanıt
    What Scooter said. Type-C is a form-factor.
    Stephen Jones - Yanıt
    How much stress / abuse / ware etc. do you think the hinges can take? Say repeatedly picking the computer up by the hinge while open.... I mean at the extreme corner only?
    Mark Huntemann - Yanıt
  27. Retina MacBook 2015 Teardown: adım 27, 2 resimden 1. Retina MacBook 2015 Teardown: adım 27, 2 resimden 2.
    • Apple has opted to transition from using a row of LEDs with a light guide panel, to installing individual LEDs beneath each key.
    • And behind those keys, we find:
    • An array of four Texas Instruments TLC5951 PWM LED Drivers
    • A pair of NXP PCAL6416A I/O Expanders
    • They claim that this new keyboard design provides even lighting across the whole keyboard, while maintaining a higher level of power efficiency than previous designs.
    • PCB maker Compeq reports increased revenues for March.
    Array of 4 Drivers for the keyboard LEDS, each supported 24 output channels. Someone's going to have to make a bit of software to led flash sequences of keys for alerting. Email from mom? M-O-M lights up, goes dark, lights up. etc. That would be awesome.
    chris - Yanıt
    That would be awesome. Im guessing theyre all wired in parallel to the same control signal and doubt they would be individually addressable.
    Christopher Johnson -
    It'd be cool, but I don't think each key has its own led. At least, in the past models there were 4 leds for the whole keyboard.
    enryko95 - Yanıt
    Each key has its own led. Apple has touted this itself.
    Any idea if Apple's design allow for the individual LEDs to be controlled by user programs?
    Since they use those TLC5951 LED drivers with 24 channels and that chip allows each channel to be adjustable individually, for 24 channels x 4 chips that's 96 channels total... is it possible to use them like disco lights? :D
    or maybe as a strobe / morse code blinker / other light games?
    JustMe - Yanıt
    One of the most common repairs we do in our shop is to replace the keyboard after failures. (Usually spills). It looks like this previously arduous but fairly inexpensive task will remain arduous but no longer inexpensive.
    Theo - Yanıt
    When repairing the keyboard after liquid damage, do you swap out the keyboard, or must you swap out the whole topcase?
    Audricus -
  28. Retina MacBook 2015 Teardown: adım 28, 2 resimden 1. Retina MacBook 2015 Teardown: adım 28, 2 resimden 2.
    • The MacBook 2015 Repairability Score: 1 out of 10 (10 is easiest to repair)
    • Proprietary pentalobe screws continue to make opening the device unnecessarily difficult, and new cable routing makes the procedure even trickier.
    • The USB-C port is secured by tri-wing screws, and buried under the display brackets, complicating replacement. Also, being the only port, it will experience more use and wear than a typical single-purpose port.
    • The battery assembly is entirely, and very solidly, glued into the lower case.
    • The Retina display is still a fused unit with no separate, protective glass. If the display needs replacing, it'll cost a pretty penny.
    • The processor, RAM, and flash memory are soldered to the logic board.
    Just replace the bottom case with the battery together. I don't see why you guys are so determined to pull the battery off the case when replacing it, it's just a cheap stupid metal bottom.
    Also pentalobe screws are no longer "proprietary" when you can get 10 for like 1 dollar.
    Apart from those. I agree this thing gets no more than 1 score on repairability though
    Tom Chai - Yanıt
    There's slightly MORE than the battery on the bottom case. Things you *might* need - like the logic board, speakers, antennae...
    It may not be as trivial as you seem to think.
    Craig B - Yanıt
    Just don't pull the battery off the case, replace those two as an assembly.
    Speakers and antennas are not so expensive either, but they are easily removable so not a problem.
    Tom Chai -
    то есть дисплей нельзя расклеить и поменять шлейф матрицы. эх, жаль, у меня как раз эта поломка.
    AkaDannnn - Yanıt
Evan Noronha
226.385 İtibar
168 adet Kılavuz yazıldı
24Kılavuz Yorumları
Hello,
Have you checked the content of the power adapters?
patrice Hamard - Yanıt
Le commentaire. As you say, pentalobe is tamperproof, and surely most of us now have a screw driver set? About time we forgave Apple, and it's good for your merchandising business ;-)
[deleted] - Yanıt
Yeah I'm thinking the same… I vaguely got the point behind the complaints when iPhone 4 came out, but that is now five years ago, and I am sure that anyone trying to fix the MacBook has ordered some part for one of the *last five iPhone models* and gotten the pentalobe screwdriver with it, so… And then the tri-wing screws just get a quick mention, although tri-wing screwdrivers are far less common by now, which just isn't fair :D
overtension -
About the battery in the lower case, I think it's a rather good idea (the MacBook Air way would have been better), you can just replace the bottom case. At least it's a compromise
nic - Yanıt
I could not find - what sound chip is used inside?
Yaroslav Serhieiev - Yanıt
Definitely not an upgradable computer. Even the little bigger MacBook Air offers easy battery, SSD and cpu fan replacement.
Agnostos Gnostos - Yanıt
Considering there is no fan in the new Macbook Retina. You can't really hold that against it.
Robert B -
I believe the BCM15700A2 chip is related to the camera:
02:00.0 Multimedia controller [0480]: Broadcom Corporation 720p FaceTime HD Camera [14e4:1570]
Leif Liddy - Yanıt
Thanks for the teardown, iFixit. Are the camera and microphone(s) unpluggable? I've been able to unplug my camera/microphones based on your teardowns of past Apple devices, but I can't tell from any of these pictures. Thanks!
wizfish mcfrabblegabben - Yanıt
Savvy comments - I learned a lot from the info - Does someone know where I could grab a template WI DoT MV2118 version to edit ?
harry ellis - Yanıt
It helps lot when you shown the repairing posts. I know that people can understand the problems they faced with apple products like phone, laptop etc. you given the guarantee to the people these apple products once problem gets can be replaced and repaired. Thanks for your efforts in showing interest for us.
tajsunil744 - Yanıt
Is there a tutorial to remove the space button? thank you
Kertvellesy Laszlo - Yanıt
Thanks You. very useful.
Reza Razmi - Yanıt
Any idea what this screw is for. It was rattling around my MacBook Air, https://imgur.com/gallery/hkYIK
Afisherman24 - Yanıt
How different is this from the 2016 model?
Moises - Yanıt
Physically the differences are very minor. We break them down for you in the Retina MacBook 2016 Teardown.
Jeff Suovanen -
It is very useful information. Thanks for sharing.
Bentec Components - Yanıt
Is the 2017 topcase similar to the 2015 or 2016 version?
Leo Alayon - Yanıt
Sehr schöner Bericht von euch, ich bin immer wieder erstaunt wie Ihr mit den teilen umgeht und es immer wieder auf die Reihe bekommt die Teile wieder zusammen zu bekommen irre Danke macht weiter so.
Gruss aus Hamburg Germany
Joerg Duenkler - Yanıt
I replaced the battery on my MacBook 12 2015 A1534, after the battery replacement, the power button key doesn't work, all other keys on the keyboard works except the power button. Please help
Kwame Darko - Yanıt
Hey there. I have spent more time working on this MacBook model than any other model Apple has made. If your power button does not work, the chances are your Palm Rest logic board (the logic board on the trackpad) has bitten the dust. You should consider replacing that.
Jadon Lyon -
Can you replace the motherboard in macbook 12 with the motherboard of macbook m1?
gagik topioka - Yanıt
That would be awesome! Highly doubt it's possible however. That is, at least without some serious hacking with the screen, keyboard, and all of those other components.
Jadon Lyon -
One year later. Not going to lie, this 12 MacBook is still my favorite Mac ever made by Apple. I know it has its issues, and I never use mine as my main computer. But, for traveling purposes, having a fully-functional computer is amazing. I am still hoping that this will be the year Apple brings it back, but with the M2 (the best chip ever in my opinion).
Jadon Lyon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 125
Son 7 gün: 1,191
Son 30 gün: 1,829
Her zaman: 616,237
