Ana içeriğe geç
Retina MacBook 2017 Battery Replacement
Neye ihtiyacın var
    1. Retina MacBook 2017 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 1. Retina MacBook 2017 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 2. Retina MacBook 2017 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 3.
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      FixBot'a Sor
      Yorum Ekle
    1. Retina MacBook 2017 Battery Replacement, Unfasten the lower case: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      Magnetic Project Mat
      $19.95
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Remove the following eight screws securing the lower case:
      • Two 1.8 mm P5 Pentalobe screws
      • Four 2.9 mm P5 Pentalobe screws
      • Two 6.1 mm P5 Pentalobe screws
      • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      FixBot'a Sor
      Yorum Ekle
    2. Retina MacBook 2017 Battery Replacement: adım 3, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 3, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 3, 3 resimden 3.
      • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
      • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
      • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
      • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
      • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
      FixBot'a Sor
      Yorum Ekle
    3. Retina MacBook 2017 Battery Replacement: adım 4, 1 resimden 1.
      • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
      FixBot'a Sor
      Yorum Ekle
    4. Retina MacBook 2017 Battery Replacement: adım 5, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 5, 2 resimden 2.
      • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
      • It may be helpful to prop the MacBook open in this position for the next step.
      FixBot'a Sor
      Yorum Ekle
    5. Retina MacBook 2017 Battery Replacement: adım 6, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 6, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 6, 3 resimden 3.
      • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
      • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
      • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
      • This step ensures the MacBook is fully powered down and safe to work on.
      FixBot'a Sor
      Yorum Ekle
    6. Retina MacBook 2017 Battery Replacement: adım 7, 1 resimden 1.
      • Close the MacBook and carefully flip it upside-down.
      FixBot'a Sor
      Yorum Ekle
    7. Retina MacBook 2017 Battery Replacement: adım 8, 1 resimden 1.
      • Lifting from the front edge, open the lower case to an angle of about 45°.
      • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
      FixBot'a Sor
      Yorum Ekle
    8. Retina MacBook 2017 Battery Replacement: adım 9, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 9, 2 resimden 2.
      • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    9. Retina MacBook 2017 Battery Replacement: adım 10, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 10, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 10, 3 resimden 3.
      • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    10. Retina MacBook 2017 Battery Replacement: adım 11, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 11, 2 resimden 2.
      • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
      FixBot'a Sor
      Yorum Ekle
    11. Retina MacBook 2017 Battery Replacement: adım 12, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 12, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 12, 3 resimden 3.
      • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
      • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
      • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
      • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
      FixBot'a Sor
      Yorum Ekle
    12. Retina MacBook 2017 Battery Replacement: adım 13, 1 resimden 1.
      • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
      FixBot'a Sor
      Yorum Ekle
    13. Retina MacBook 2017 Battery Replacement: adım 14, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 14, 2 resimden 2.
      Battery Blocker
      $5.95
      • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
      FixBot'a Sor
      Yorum Ekle
    1. Retina MacBook 2017 Battery Replacement, USB-C and Audio Jack Disconnect: adım 15, 1 resimden 1.
      • Remove the two screws securing the USB-C port cable bracket:
      • 1.1 mm Phillips #00 screw
      • Some variations of this model may use a Tri-point Y00 screw.
      • 3.5 mm T5 Torx screw
      FixBot'a Sor
      Yorum Ekle
    2. Retina MacBook 2017 Battery Replacement: adım 16, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 16, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
      • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
      FixBot'a Sor
      Yorum Ekle
    3. Retina MacBook 2017 Battery Replacement: adım 17, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 17, 2 resimden 2.
      • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    4. Retina MacBook 2017 Battery Replacement: adım 18, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 18, 2 resimden 2.
      • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
      • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
      • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
      FixBot'a Sor
      Yorum Ekle
    1. Retina MacBook 2017 Battery Replacement, Lower Case Assembly Removal: adım 19, 2 resimden 1. Retina MacBook 2017 Battery Replacement, Lower Case Assembly Removal: adım 19, 2 resimden 2.
      • Use tweezers to peel back the tape covering the display cable connector.
      FixBot'a Sor
      Yorum Ekle
    2. Retina MacBook 2017 Battery Replacement: adım 20, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 20, 2 resimden 2.
      • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
      • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Retina MacBook 2017 Battery Replacement: adım 21, 1 resimden 1.
      • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
      • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
      FixBot'a Sor
      Yorum Ekle
    4. Retina MacBook 2017 Battery Replacement: adım 22, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 22, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 22, 3 resimden 3.
      iOpener
      $14.95
      • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
      • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
      FixBot'a Sor
      Yorum Ekle
    5. Retina MacBook 2017 Battery Replacement: adım 23, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 23, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 23, 3 resimden 3.
      • Hold the retaining flap open.
      • Disconnect the display cable by gently pulling it straight out of its connector.
      • Immediately close the retaining flap. Keep it closed throughout your repair.
      • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
      FixBot'a Sor
      Yorum Ekle
    6. Retina MacBook 2017 Battery Replacement: adım 24, 1 resimden 1.
      • Separate the upper case assembly from the lower case assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Retina MacBook 2017 Battery Replacement, Logic Board: adım 25, 3 resimden 1. Retina MacBook 2017 Battery Replacement, Logic Board: adım 25, 3 resimden 2. Retina MacBook 2017 Battery Replacement, Logic Board: adım 25, 3 resimden 3.
      • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
      FixBot'a Sor
      Yorum Ekle
    2. Retina MacBook 2017 Battery Replacement: adım 26, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 26, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 26, 3 resimden 3.
      • Use the point of a spudger to flip up both ZIF connector retaining flaps.
      FixBot'a Sor
      Yorum Ekle
    3. Retina MacBook 2017 Battery Replacement: adım 27, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 27, 2 resimden 2.
      • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    4. Retina MacBook 2017 Battery Replacement: adım 28, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 28, 2 resimden 2.
      • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
      FixBot'a Sor
      Yorum Ekle
    5. Retina MacBook 2017 Battery Replacement: adım 29, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 29, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 29, 3 resimden 3.
      • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
      • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
      FixBot'a Sor
      Yorum Ekle
    6. Retina MacBook 2017 Battery Replacement: adım 30, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 30, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 30, 3 resimden 3.
      • Pry up the second antenna connector to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    7. Retina MacBook 2017 Battery Replacement: adım 31, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 31, 2 resimden 2.
      • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
      FixBot'a Sor
      Yorum Ekle
    8. Retina MacBook 2017 Battery Replacement: adım 32, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 32, 2 resimden 2.
      • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    9. Retina MacBook 2017 Battery Replacement: adım 33, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 33, 2 resimden 2.
      • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
      • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
      FixBot'a Sor
      Yorum Ekle
    10. Retina MacBook 2017 Battery Replacement: adım 34, 1 resimden 1.
      • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
      FixBot'a Sor
      Yorum Ekle
    11. Retina MacBook 2017 Battery Replacement: adım 35, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 35, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 35, 3 resimden 3.
      • Flip up the front edge of the logic board.
      • Handle the logic board only by its edges.
      • Lift and detach the EMI tape securing the logic board to the lower case.
      • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
      • Reattach the tape securely during reassembly.
      FixBot'a Sor
      Yorum Ekle
    12. Retina MacBook 2017 Battery Replacement: adım 36, 1 resimden 1.
      • Remove the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. Retina MacBook 2017 Battery Replacement, Battery: adım 37, 3 resimden 1. Retina MacBook 2017 Battery Replacement, Battery: adım 37, 3 resimden 2. Retina MacBook 2017 Battery Replacement, Battery: adım 37, 3 resimden 3.
      • Lift the back edge of the lower case assembly and prop it up at an angle using a book or foam block.
      • In the following steps, you'll apply liquid adhesive remover along the edges of the battery cells. Keeping part of the MacBook elevated will help the adhesive remover flow underneath the battery.
      • You can reorient the MacBook as needed throughout this procedure, but try to prevent the adhesive remover from touching any components other than the battery and metal chassis.
      • If necessary, add a layer of aluminum foil underneath your MacBook to protect your workspace from wayward drops of adhesive remover.
      FixBot'a Sor
      Yorum Ekle
    2. Retina MacBook 2017 Battery Replacement: adım 38, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 38, 2 resimden 2.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
      FixBot'a Sor
      Yorum Ekle
    3. Retina MacBook 2017 Battery Replacement: adım 39, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 39, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 39, 3 resimden 3.
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      FixBot'a Sor
      Yorum Ekle
    4. Retina MacBook 2017 Battery Replacement: adım 40, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 40, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 40, 3 resimden 3.
      • The adhesive securing the battery cells to the lower case is located in the areas marked in red.
      • You may use this step for reference when applying the adhesive remover in the following steps.
      FixBot'a Sor
      Yorum Ekle
    5. Retina MacBook 2017 Battery Replacement: adım 41, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 41, 2 resimden 2.
      • Apply a few drops of adhesive remover along the top edge of the front right battery cell.
      • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all six battery cells.
      • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
      FixBot'a Sor
      Yorum Ekle
    6. Retina MacBook 2017 Battery Replacement: adım 42, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 42, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 42, 3 resimden 3.
      Plastic Cards
      $2.99
      • After 2-3 minutes, slide one corner of a plastic card underneath the battery cell.
      • This should require minimal force. If you have trouble, apply more adhesive remover along the other edges of the battery cell and give it 2-3 additional minutes to penetrate.
      • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
      • It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook's case.
      • Slide the card farther underneath the battery cell to separate it from the adhesive securing it to the case.
      FixBot'a Sor
      Yorum Ekle
    7. Retina MacBook 2017 Battery Replacement: adım 43, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 43, 2 resimden 2.
      • Lift the battery cell from the right edge to fully separate it from the adhesive, but don't try to remove it.
      • Leave the plastic card underneath the battery cell to prevent it from re-adhering as you proceed to the next step.
      FixBot'a Sor
      Yorum Ekle
    8. Retina MacBook 2017 Battery Replacement: adım 44, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 44, 2 resimden 2.
      • Repeat the previous three steps to separate the front left battery cell.
      FixBot'a Sor
      Yorum Ekle
    9. Retina MacBook 2017 Battery Replacement: adım 45, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 45, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 45, 3 resimden 3.
      • Repeat the previous steps to separate the large battery cell on the left side of the MacBook.
      FixBot'a Sor
      Yorum Ekle
    10. Retina MacBook 2017 Battery Replacement: adım 46, 2 resimden 1. Retina MacBook 2017 Battery Replacement: adım 46, 2 resimden 2.
      • Repeat the previous steps to separate the large battery cell on the right side of the MacBook.
      • Be careful not to damage the audio jack flex cable, near the back edge of the battery cell.
      FixBot'a Sor
      Yorum Ekle
    11. Retina MacBook 2017 Battery Replacement: adım 47, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 47, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 47, 3 resimden 3.
      • Lay the lower case assembly down flat, and apply adhesive remover to the two middle battery cells—at each side, and along the front edge (opposite the logic board area).
      FixBot'a Sor
      Yorum Ekle
    12. Retina MacBook 2017 Battery Replacement: adım 48, 1 resimden 1.
      • Apply some additional adhesive remover down the middle between the two battery cells.
      • Wait 2-3 minutes for the adhesive remover to penetrate before you proceed.
      FixBot'a Sor
      Yorum Ekle
    13. Retina MacBook 2017 Battery Replacement: adım 49, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 49, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 49, 3 resimden 3.
      • Insert your plastic card under the front edge one of the battery cells and separate it carefully.
      • If you're having trouble getting the card underneath the battery cell, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
      FixBot'a Sor
      Yorum Ekle
    14. Retina MacBook 2017 Battery Replacement: adım 50, 1 resimden 1.
      • Repeat the previous step to separate the final battery cell.
      FixBot'a Sor
      Yorum Ekle
    15. Retina MacBook 2017 Battery Replacement: adım 51, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 51, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 51, 3 resimden 3.
      • Remove the battery by lifting it away from the speaker and logic board area.
      • Take care not to drag the battery over the lower case assembly, or you may damage the speakers or flex cables.
      • Before installing your new battery, remove all the remaining adhesive from the MacBook's case.
      • Peel off larger pieces of adhesive using tweezers or gloved fingers.
      • Scrape away any remaining adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction, not back and forth, until all the adhesive residue is gone.
      • This can take quite a bit of work, so be patient.
      FixBot'a Sor
      Yorum Ekle
    16. Retina MacBook 2017 Battery Replacement: adım 52, 3 resimden 1. Retina MacBook 2017 Battery Replacement: adım 52, 3 resimden 2. Retina MacBook 2017 Battery Replacement: adım 52, 3 resimden 3.
      Tesa 61395 Tape
      $25.95
      • Test your new battery's fit and alignment carefully before installing it.
      • Unlike most laptop batteries, the MacBook's battery is precisely contoured to fit the "terraced" shape of the lower case. Each cell must be correctly positioned, or the MacBook may not close correctly and damage may result.
      • Your replacement battery may come affixed to a thick plastic top liner to help keep the individual cells in position as you install it. Don't remove this liner until after the battery is installed.
      • If your battery came with adhesive pre-installed on the bottom, peel away the bottom plastic liners to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to the lower case in the areas marked in red.
      • Carefully position the battery and set it into place. Press and hold each cell firmly for 5-10 seconds to secure it to the lower case. Afterward, peel off the plastic top liner along with any foam padding.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
40 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
453.807 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
43.609 adet Kılavuz yazıldı
24Kılavuz Yorumları
Un coñazo vamos :D
Hugo Angulo - Yanıt Paylaş
When will the battery Start to swell?
Any warning sign for emergency replacement?
Keyur chakurkar - Yanıt Paylaş
Is this Battery compatible with my Macbook 12-inch 2015 Retina?
Alberto Pomales - Yanıt Paylaş
Absolutely fantastic instructions. Just follow step by step. There will be no surprises. Took about 2-2,5 hours.
vanblerk123 - Yanıt Paylaş
Guys! I did it! took me 2.5 hrs. really appreciate the thorough instructions!
austenschultz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 185
Son 30 gün: 732
Her zaman: 117,036
