Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Vizio Co-Star cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Vizio Co-Star Teardown, Vizio Co-Star Teardown: adım 1, 1 resimden 1.
    • Providing the market with a $99 answer to the Apple TV (also $99), the Vizio Co-Star brings a refreshing reincarnation of Google TV to the world of set-top boxes.
    • Notable tech specs:
    • Google TV platform
    • Wi-Fi and Bluetooth enabled
    • Hot buttons for Amazon, Netflix, and M-Go
    • 720p, 1080i, and 1080p resolution support
    • MP3, AAC, and WMA audio playback
    • Universal QWERTY remote with trackpad
  2. Vizio Co-Star Teardown: adım 2, 2 resimden 1. Vizio Co-Star Teardown: adım 2, 2 resimden 2.
    • The rear side of the Vizio Co-Star includes an impressive lineup:
    • USB 2.0 port
    • HDMI-In port
    • HDMI-Out port
    • Ethernet port
    • DC-In Power port
    • On the bottom we see the reset switch and four suspicious-looking rubber feet.
    • Spoiler alert: the feet aren't hiding anything.
  3. Vizio Co-Star Teardown: adım 3, 2 resimden 1. Vizio Co-Star Teardown: adım 3, 2 resimden 2.
    • A little prying around the edge with a plastic opening tool, and we've got the bottom panel free.
    • Comparatively speaking, the Apple TV required two metal spudgers to open, as opposed to a single plastic opening tool here. No need to split hairs; they're both easy to open up, and we love it.
  4. Vizio Co-Star Teardown: adım 4, 2 resimden 1. Vizio Co-Star Teardown: adım 4, 2 resimden 2.
    • We pull off what looks like an EMI shield only to find a thermal pad sitting on top of a sea of small resistors.
    • It's not often that we encounter cooling for the back side of a motherboard, but Vizio took extra precautions as this Co-Star has no fans.
  5. Vizio Co-Star Teardown: adım 5, 3 resimden 1. Vizio Co-Star Teardown: adım 5, 3 resimden 2. Vizio Co-Star Teardown: adım 5, 3 resimden 3.
    • The only thing standing between us and the motherboard are some screws and two connectors. Say hello to our little friend!
    • For those of you tuning in at home, a grand total of five screws and two cables must be removed once inside the device to free the motherboard. That's going to give the Co-Star a nice ratings boost.
  6. Vizio Co-Star Teardown: adım 6, 2 resimden 1. Vizio Co-Star Teardown: adım 6, 2 resimden 2.
    • And here comes the Co-Star's motherboard strolling down the red carpet:
    • Marvell Armada 1500 1.2 GHz Dual-Core Processor
    • Marvell 88DE2755 QDEO Video Processor
    • Nanya NT5CB256M8GN-DI 2 Gb DDR3 SD RAM (2 Gb x 4 for 1 GB total RAM)
    • Samsung K9GBG08U0A-SCBO 32 Gb (4 GB) NAND Flash
    The RAM specs are quite confusing - 2GB x 4 for a total of 1GB?
    Dan Scott - Yanıt
    The chips are 2 gigabits (Gb) each, and there are 8 gigabits to a gigabyte (GB).
    Andrew Optimus Goldheart -
  7. Vizio Co-Star Teardown: adım 7, 2 resimden 1. Vizio Co-Star Teardown: adım 7, 2 resimden 2.
    • We're used to the innards of devices being dominated by a single component, but those space hogs are usually batteries or power supplies.
    • Over a third of the real estate in the Co-Star is inhabited by the aluminum heat sink.
    • You may be asking yourself why the Co-Star has such a huge heat sink?
    • The answer lies in air movement. Without fans to circulate air, there is no forced convection. Therefore, the Co-Star must rely on conduction and natural convection to keep the processor cool.
  8. Vizio Co-Star Teardown: adım 8, 3 resimden 1. Vizio Co-Star Teardown: adım 8, 3 resimden 2. Vizio Co-Star Teardown: adım 8, 3 resimden 3.
    • We remove an additional board to reveal a whole lot of nothin' underneath.
    • The board houses the USB port and, well, nothing else.
  9. Vizio Co-Star Teardown: adım 9, 3 resimden 1. Vizio Co-Star Teardown: adım 9, 3 resimden 2. Vizio Co-Star Teardown: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    Satın Al
    • We use our always-trusty spudger to disconnect the Bluetooth and Wi-Fi antenna cables from the wireless board.
    • A Marvell Avastar 88W8787 WLAN/Bluetooth/FM Single-Chip SoC brings life to what would otherwise be a very bland and boring board.
  10. Vizio Co-Star Teardown: adım 10, 2 resimden 1. Vizio Co-Star Teardown: adım 10, 2 resimden 2.
    • A plastic opening tool and a steady hand are all we need to separate the Bluetooth and Wi-Fi antennas from the Co-Star's lower case.
    • This antenna cable is too short.
    • This antenna cable is too long.
    • This antenna cable is just right!
  11. Vizio Co-Star Teardown: adım 11, 2 resimden 1. Vizio Co-Star Teardown: adım 11, 2 resimden 2.
    • That's pretty much it for the Co-Star, but we do like to do a thorough teardown here at iFixit, so we took a quick look at this flashy silver bezel. It sadly revealed nothing more than a flashy silver bezel.
    • Modders, take note: the bezel comes off easily and would probably look pretty slick when painted neon green.
  12. Vizio Co-Star Teardown: adım 12, 2 resimden 1. Vizio Co-Star Teardown: adım 12, 2 resimden 2.
    • Just like the Boxee Box, the Co-Star comes with a neat two-sided remote.
    • Unlike the Boxee Box though, this Vizio controller is universal and features a touch-sensitive trackpad. Point, Co-Star.
    • As a finishing touch, the Co-Star remote has ABXY buttons and a directional pad for OnLive gaming. Not only is that an incredibly unique feature, it gets us all nostalgic and stuff.
  13. Vizio Co-Star Teardown: adım 13, 2 resimden 1. Vizio Co-Star Teardown: adım 13, 2 resimden 2.
    • The battery tray comes right out, but this isn't much of a surprise. How often did you try to "fix" your TV remote by pulling out the old batteries and just switching them around?
    • A pair of AA batteries were included for the remote. That's a legitimate selling point right there.
  14. Vizio Co-Star Teardown: adım 14, 3 resimden 1. Vizio Co-Star Teardown: adım 14, 3 resimden 2. Vizio Co-Star Teardown: adım 14, 3 resimden 3.
    • Here's another opportunity for the modders out there. How cool would it be to have a neon green keyboard bezel to match your Co-Star?
    • Whether you're painting it or not, the bezel pries off the keyboard quite easily.
    • Following suit, the rubber button cover peels off without a problem.
    • Since the button cover and the bezel are the components that usually get the dirtiest, it's great they are easy to remove.
  15. Vizio Co-Star Teardown: adım 15, 2 resimden 1. Vizio Co-Star Teardown: adım 15, 2 resimden 2.
    • Buttons on both sides mean lots of data transfer. Luckily, the data cable slides out from connectors on both PCBs.
    • The Co-Star's remote looks to be as easy to take apart as the media player itself.
    • Once again, this isn't really a surprise. Remotes, unlike smartphones or laptops, aren't subject to strict space constraints.
  16. Vizio Co-Star Teardown: adım 16, 2 resimden 1. Vizio Co-Star Teardown: adım 16, 2 resimden 2.
    • The keyboard backer sports a couple of ICs:
    • Maxim MAXQ610 16-bit Microcontroller with Infrared Module
    • Broadcom BCM20733 Human Interface Device Bluetooth 3.0 single chip
  17. Vizio Co-Star Teardown: adım 17, 3 resimden 1. Vizio Co-Star Teardown: adım 17, 3 resimden 2. Vizio Co-Star Teardown: adım 17, 3 resimden 3.
    • A few Phillips #0 screws and some prying and the lower case of the remote is gone. See ya!
    • With the case removed, we learn the screws were pulling double duty and holding the motherboard in place.
  18. Vizio Co-Star Teardown: adım 18, 3 resimden 1. Vizio Co-Star Teardown: adım 18, 3 resimden 2. Vizio Co-Star Teardown: adım 18, 3 resimden 3.
    • Yoink!
    • We grab a handy pair of tweezers and gently pluck out the trackpad data cable before removing the other board.
    • This board is powered by a Renesas R5F2133 16-bit microcontroller.
    • No flash photography, please, but this PCB does host the two IR blasters, with one conveniently on the side for the QWERTY keyboard.
  19. Vizio Co-Star Teardown: adım 19, 3 resimden 1. Vizio Co-Star Teardown: adım 19, 3 resimden 2. Vizio Co-Star Teardown: adım 19, 3 resimden 3.
    iFixit Opening Picks (Set of 6)
    Satın Al
    • Peeling back the remote's keypad is as easy as peeling a banana. Underneath is the capacitive touch trackpad.
    • A lot of strong adhesive is used to hold this board in place.
    • If this comes loose, your movie night will be gone with the wind, hence the generous amount of adhesive.
    • Excess adhesive usually doesn't get in our way. With a little bit of patience, our iFixit guitar picks, and a spudger, we free the trackpad from the frame.
  20. Vizio Co-Star Teardown: adım 20, 2 resimden 1. Vizio Co-Star Teardown: adım 20, 2 resimden 2.
    • The trackpad is controlled by the popular Synaptics T1021A Touch Controller, also used in the Logitech Revue.
    • Which reminds us, it's time to revue the Vizio Co-Star's repairability.
  21. Vizio Co-Star Teardown: adım 21, 2 resimden 1. Vizio Co-Star Teardown: adım 21, 2 resimden 2.
    • Vizio Co-Star Repairability: 8 out of 10 (10 is easiest to repair)
    • The outer case only requires a little bit of prying with a plastic opening tool to open.
    • The only screws used in the Co-Star are standard Phillips #0.
    • Most of the components are easily accessible and thus easily replaced in case of failure.
    • Removing the remote's QWERTY keypad is painless, making regular cleaning a relatively simple task.
    • An abundance of glue securing the trackpad to the front of the remote makes removal difficult.
Jake Devincenzi
117.301 İtibar
57 adet Kılavuz yazıldı
2 Yorum
I have an inquiry not so much related to fixing procedures but to functionality. The important question for me is, if it is compatible with Apple Mountain Lion-based computer equipment? I had a Western Digital WDTV Live Plus I recently sold on auction because Apple mucked around with the network layer stack, or some unfamiliar jargon like that as explain a while back by WD support staff. Other then that, if the Vizio Co-Star does functionally work similar to an Apple TV, but provides greater connectivity in home network with Apple computers and more versatility in video codec playback I may want to get one of these.
Thanks for the guide teardown. You folks do a terrific job at ifixit.
Jerry - Yanıt
I want to use an adapter I have to power the VAP430.
Anyone know the dimensions for the plug that connects to the back of the VAP430?
iamenergy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 41,893
