Ana içeriğe geç
Yardım
Belkin F5L009 Network USB Hub Teardown
Adım 2 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
I began by flipping the F5L009 upside down.
The case is held together by small tabs all along the sides. Work the spudger between where the two halves meet. I started on the side with the ethernet port, since it seemed to be the most flexible.
Once you get a bit of the top and bottom halves separated on one side, start sliding the opening tool around the entire case until all the tabs are disengaged. I found them to be rather "soft" and easy to disengage without breaking them.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
