Ana içeriğe geç
Yardım
MacBook Air 13" Retina 2018 Teardown
Adım 13 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Things are starting to look Air-y inside this golden chassis—we can almost see the finish line!
Still lingering above the battery cavern are the metal antenna bracket and the new (modular!) Touch ID sensor, each secured by Torx screws.
FYI, the Touch ID sensor can come out directly after the smaller audio board is removed—we just chose to let it linger.
A few more Torx screws later, the display is free! This new Retina panel is almost the same as the one found on the MacBook Pro line, differing mainly in peak brightness (a mere 300 nits vs. the Pro's 500) and P3 color gamut support.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
