Ana içeriğe geç
Yardım
Chumby One Teardown
Adım 3 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Slide the lower case away from the front of the chumby, then tilt it away from the logic board to reveal the battery connector. Taking as many precautions as possible, we decided to disconnect the battery connector from the logic board assembly.
Use a plastic opening tool to dislodge the plug of hot glue holding the FM antenna wire in the lower case. At this point you can de-route the FM antenna wire and remove the lower case from the chumby.
chumby industries, inc. recommends using only a Fujifilm NP-120 battery.
The NP-120 is a rechargeable Lithium-Ion camera battery. The chumby is equipped with circuitry to charge the battery when it is plugged into AC power.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
