Ana içeriğe geç
Yardım
Chumby One Teardown
Adım 11 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Get your groove on with the single 2W mono speaker mounted flush in the plastic chassis.
After removing the four Phillips screws securing the speaker to the chassis, use a sharp blade to carefully separate the speaker cables from the adhesive applied near the speaker opening.
The speaker wires are glued down to avoid any rattling noises from ruining your air guitar solo.
The speaker has a 7/8" concave aluminum diaphragm held to the frame with a foam rubber surround.
The white panel on the chassis is fitted with a conical port presumably to eliminate resonance.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
