Ana içeriğe geç
Yardım
Samsung Galaxy S7 Teardown
Adım 8 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Samsung got some flak from consumers for reducing battery capacity in last year's S6. It seems they took the hint and made up for it by including this 3000 mAh battery in the S7.
That's a significant boost over the Galaxy S6's 2550 mAh battery, and it even beats the much larger iPhone 6s Plus's 2750 mAh powerplant.
Sadly, as evidenced by this important warning label, the S7's battery does not work in the presence of puppies.
Although the battery upgrade means more time to binge on apps and games, the battery itself is well wedged and adhered in place, making extraction a little tough.
If it wasn't designed to be readily removed, then it wasn't intended to be repaired or replaced. Boo.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
