Ana içeriğe geç
Yardım
Sony Alpha 5100 Teardown
Adım 11 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Gently pry the mid frame from the body. Make sure all the flex circuits are out of the way. This step might be tricky. The frame might be glued so take extreme care not to damage anything!
You probably do not have to remove camera mount. But I did so anyway!
You probably won't have to remove camera belt clip either. I would recommend using it as extra leverage while removing mid frame from the body.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
