Ana içeriğe geç
Yardım
Sony Alpha 5100 Teardown
Adım 18 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Remove 5 screws
Remove Front Metal Frame
Remove Image Sensor Assembly
You can continue disassembly if you want to separate image sensor from the shutter. I have not gone that far but I am sure it should not be too difficult to figure out.
Last picture shows front case of the camera. It does not include flex circuit. You should have flex circuit still attached to the front case!
Note how camera belt clip is still attached to the front case of the camera. You don't have to detach it!
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
